Old 10-05-2010, 09:14 AM
X5_Rob X5_Rob is offline
Mein Auto: '11 X6 50i; '05 X5 4.4
2005 530 Transmission hesitates to shift
The car rides fine at slow speeds but under heavy acceleration the car starts to buck like a bronco when the tranny is trying to shift gears. It does not happen at any specific speed just nearly at any speed when you floor it.
I have searched and saw some folks with similar issues but only at certain speeds (the fix was suggested to be software related...).
Any thoughts would be appreciated. I've had a similar issue with a Toyota and the fix was a simple transmission flush/clogged filter.... I am hopeful that cheap fix could be used again!
Thanks again,
Rob
Old 10-05-2010, 12:24 PM
silverbimmer3's Avatar
silverbimmer3 silverbimmer3 is offline
Mein Auto: '05 M3 ZCP; '06 530 XIT
you can try resetting the transmission's 'memory'.
- power on the car (everything on, except engine)
- press the accelerator all the way down to the floor, hold it for 45-60 seconds.
for the next couple thousands miles the transmission will 'adapt' to your driving style.
acceleration issue, transmission, transmission clunk, transmission jolt
