Problem with Towbar wiring - Bimmerfest - BMW Forums
The X5 SAV Forum
Old 10-05-2010, 01:13 PM
gerto99 gerto99 is offline
Mein Auto: x5 4.4i
My X5 E53 did not have a towbar fitted, but I got one in the classifieds.(South Africa)
I had it installed, but they could not get the wiring sorted. The cable plugs into the socket inside the car( looks like a 13 socket) and have a adapter next to the towbar with a 7 socket plug. Do I need a module installed in the car to get it to work?
Old 10-05-2010, 04:51 PM
Speedo6 Speedo6 is offline
Mein Auto: X3 2007 3.0d
You will need BMW to do the wiring connection to the CAS system. Otherwise you risk all sort of electrical faults if not connected properly.
Old 11-02-2010, 09:30 PM
m5james's Avatar
m5james m5james is offline
Send a message via AIM to m5james Send a message via MSN to m5james Send a message via Yahoo to m5james
Mein Auto: 98 740iL - Tweaked a bit
I wired in a $30 Module Master wiring harness myself that I got on eBay, took about 45 minutes. Let me know if you need more information....and you don't need to goto the BMW stealership for this either.
640hp 10 X5///M, Alpine White/Sakhir Orange - Gutted cats, muffler delete, Eurocharged tune
325hp 98 740iL, black/black - Eatin 540's & $hittin 318's
PERFORMANCE:///M5 6spd swap, Iron sleeves, L/W Teflon coated pistons, 3 angle valvejob, P&P head, cams, electric fan, CF intake tube w/aluminum heatshield, Magnaflow 14816'd
INTERIOR:
Hardwired V1 above rearview, 12" RE Audio DVC sub, MTX 81000D, silver trim, 5% tint
EXTERIOR:19" Beyern Mesh staggered, Shadowline kidneys, Axxis pads
Old 11-04-2010, 02:17 AM
Mein Auto: x5 4.4i
I would like some help.
I am staying in a rural area in South Africa and the closest dealership is 120 km (60 miles) away
Old 11-07-2010, 12:16 AM
m5james's Avatar
If you can get mail, you can get the same wiring harness I did. You don't need the dealership at all for this.
INTERIOR:
