E30 (1982 - 1993)
Old 10-06-2010, 10:21 AM
mbb3 mbb3 is offline
Mein Auto: 325 ic
E30 water pump
How difficult is changing the waterpump? Dealer wants $500 labor + parts. 1993 E30 ic
Old 10-07-2010, 01:42 AM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
93 is not E30, that would be an E36.
In either case, and no matter what engine, its piss easy to do and catalouged a million times on here.
If your car looks like the one in my signature then it is an E30. If it has rectangle headlights then its E36
E30 above Sold
E34 V12 Project Thread Here: http://www.bimmerfest.com/forums/sho...=502437&page=4
Last updated 2nd January 2014
Old 10-07-2010, 05:53 AM
bimmeupscottiee's Avatar
bimmeupscottiee bimmeupscottiee is offline
Send a message via Yahoo to bimmeupscottiee
Mein Auto: 1987 325is
They made the verts till 93
"I knew a guy who bought a used car through a newspaper. Ten years later...bam...Herpes."
Old 10-07-2010, 08:07 AM
1991318i 1991318i is offline
Mein Auto: BMW E30 0011-0001-1000
+1
dat E30
Old 10-07-2010, 09:40 AM
anstead610 anstead610 is offline
dream chasin'
Send a message via AIM to anstead610
Mein Auto: 24v e30 -88 toyota pickup
there are 93 e30 verts, they're pretty rare.
This e30 is now being parted out. NO body panels are for sale, bumpers/fenders/hood/mirrors/valance or front turn signals. Everything else is up for grabs. Euro grills/cluster are sold, suspension/brakes/LSD/rear tails are already spoken for.
Old 10-09-2010, 10:52 PM
bimmerboy08's Avatar
bimmerboy08 bimmerboy08 is offline
Mein Auto: 1988 BMW 325i
didn't they make tourings until 94?
The E30 is what all actual driving enthusiasts are after. It's an unpretentious machine, quietly capable of spectacular feats of handling. It's light, simple design is rugged enough to run against $400k rally cars, but on the street it' communicative chassis delights even the most disinterested driver. It really is one of the world's ultimate driving machines
Old 10-15-2010, 12:31 PM
damalex's Avatar
damalex damalex is offline
Mein Auto: 89 E30
any how i find the water pump to be vary easy to do but when you have every thing takin apart i would pick up a timing belt an put a new one is seeins how you already in there
Old 11-09-2010, 10:01 PM
Try&CatchMy325's Avatar
Try&CatchMy325 Try&CatchMy325 is offline
E30's,Work,Eat,Sleep
Mein Auto: 1997 328i
I just changed my water pump and it took time but not hard. I also own a Bentley 3 series book that helped. Need lots of tools torque bits and 1/4 wrench, good time to replace tensioner and timing belt while the cam casing is off.
Old 11-10-2010, 06:16 PM
e^2 e^2 is offline
Mein Auto: '84 325e, '00 323i
Just putting mine back together tonight. Most difficult part was the damn fan. Ended up wedging a 1/4" ratchet handle between the crank and water pump pulley. If you do the pump you might as well do the timing belt.
Old 11-10-2010, 07:03 PM
SWISS SWISS is offline
On Top
Send a message via AIM to SWISS Send a message via Yahoo to SWISS
Mein Auto: E30 S52 / S52 M roady
You do know with the correct tool it takes all of 7 seconds right?
Old 11-10-2010, 09:52 PM
cyberkaa cyberkaa is offline
:facepalm:
Send a message via ICQ to cyberkaa Send a message via AIM to cyberkaa
Mein Auto: E46 332i, M3; E30 325i
DIY and save yourself a bundle. It's something I think every M20 owner should learn how to do.
Change the timing belt while you're in there. The whole thing is a little tricky the first time, but gets much easier the next time you have to do it!
-Kalim
(klx photo studio)
M3 drive train conversion (S54 Swap, LSD, 6MT, suspension linkage) | UUC Stg 2 Organic Clutch | OEM M-Tech II Kit
KW V2 | BBS GT4 RE | Falken FK452 | Alcon 6-pot 365mm BBK | M3 steering wheel | Powerflex bushings
Old 11-11-2010, 02:55 PM
e^2 e^2 is offline
Ya. But you have to have one first.
Old 11-11-2010, 03:35 PM
Make one that's what I did get a nice piece of plate steel and cut it out. Cost me about 8 bucks.
Old 11-11-2010, 04:22 PM
e^2 e^2 is offline
I just moved to a new state and I had to toss out all of my scrap steel. Something tells me I'll have to build one shortly though.
Old 11-11-2010, 09:08 PM
noexceptions325's Avatar
noexceptions325 noexceptions325 is offline
East Bound And Down
Send a message via AIM to noexceptions325
Mein Auto: 325e,Jeep,240z,528i
yep.. flat steel with a half circle ground out of the side and two holes to go over two of the four bolts
Built 325e too much to list, Heavily modified Jeep, Datsun about to get a 351, and now a 528i
