Old 03-16-2013, 11:50 PM
Dynamicfigure Dynamicfigure is offline
Mein Auto: 2005 - 645 Coupe
Knocking
This problem honestly made me second guess everything. The BMW regional mechanic even came in, looked at the car and said it was "normal." I can say after driving the car for another 40K miles that the sound is still there - not much worse, not better in any way at all and the engine still seems sound. I get the occasional increased emissions warning that everyone seems to get (ethanol free gas seems to usually cure it), and have had a couple small things done, but the knocking sound is obvious as ever w/no adverse effect (that I can tell) yet to the engine...
Old 03-18-2013, 11:12 AM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
Wow old thread! Check your spark plugs.
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by hornhospital View Post
Jared, why don't you just put "It's Giubo" in your sig? Save a lot of typing.
Originally Posted by e36 miguel View Post
this jared guy sounds intimidating lol.
2005 X5 4.8is Le Mans/Black/6spd Steptragic
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual
1997 328iC Schwarz II/K/K 5MT SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6MT RIP 04/2011
Old 01-26-2014, 01:22 PM
hammerhead75 hammerhead75 is offline
Mein Auto: 2004 645ci
The TICK
Im an engine builder from the marine and nascar world and just bought a 2004 645ci and it too has the "tick" this one ticks at an idle but goes away around 1200rpm which doesnt really raise any alarms with me but for a so called luxury car I agree it shouldn't be there so its back to basics to find this "tick". If it disappears at a higher rpm that indicates oil pressure to a loss pump lifter. If a bearing is going out it will go out very quickly not in thousands of miles. If it is a valve train issue after the engine is brought to temperature if a valve cover is removed a infared heat detector pointed at each lobe will tell you yes or no instantly if theres a issue. There are also oil additives that make your oil slippery slimey I wouldnt recommend leaving this oil slime in but for trouble shooting absolutely these are things to do at home so Joe mechanic doesnt want to replace your brakes for this "tick". Im gonna do these ecact things and tell the results
Old 01-08-2015, 05:55 AM
osc osc is offline
Mein Auto: e38, e65, e83
Have subscribed to the thread, hoping for something to help pin point this one. I have the same tick on my 745i (euro spec).
If it helps, the tick fades away for a few days after adding Liqui Moly Hydraulic Lifter Additive. Also, if the oil level get a bit low, then the tick get worse.
This makes me think it's something to do with the oil pressure operating the hydraulic lifters, or a sticky / lazy lifter.
Old 01-08-2015, 06:12 AM
645/333's Avatar
645/333 645/333 is offline
Michael
Mein Auto: BMW 640i SE Convertible
these engines do not like being run on low oil levels!!! I always kept mine topped up........
Always said I would go back to a 6 series
