Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Car Navigation, Audio & Electronics by BAVSOUND
BMW navigation, audio upgrades, XM Radio, Sirius, Bluetooth, and Radar Detector discussions here!
Sponsored by BAVSOUND
Old 12-29-2003, 01:22 PM
Fritz Fritz is offline
Mein Auto: '04 325i PP SP CW
Thumbs up My New ICE in 325i w/ HK (Stealthbox & Phatbox)
So I caved in a couple weeks ago and ordered some stuff for my new '04 325i. I have the upgraded HK system, but I found the Bass to be dissapointing. As such, I got the following...
JL Stealthboxes
JL 250x1 Amp
And just because I couldn't resist
PhatNoise Phatbox
Man.... What a difference!!! The Stealthboxes sound great IMO. It isn't gonna blow the windows out of the car, but it fills in that missing bass and has a surprising punch for two 8"s. All in all, great clean sound.
********Box is pretty awesome as well. I look forward to never fumbling through a CD case again looking for a CD, and crossing my fingers that I won't get into an accident w/ my eyes off the road. It is very easy to use and quite intuitive. I can't tell the difference in sound quality between actual CDs and this (I encode at 192 or 224).
I had the work done at Myer-Emco in Arlington, VA. They did a great job. Very helpful, and did a very clean install (i'll post pics when I get home from work). The installer built an amp rack and mounted the amp and ********box onto it.
If anyone is considering either one of these products, I give them my thumbs up. Now hopefully i can resist the urge to spend any more money in the near future.
Old 12-29-2003, 02:15 PM
Dr. Phil's Avatar
Dr. Phil Dr. Phil is offline
The Original Dr. Phil
Send a message via AIM to Dr. Phil
Mein Auto: 2012 135 coupe
Where are the pictures to prove this
2012 X5 Premium, Sparkling Bronze/Sand/lLight Poplar, Premium Sound, 20 Way Seats, Head Up, Comvenience, Surround View, Sirius, Heated Seats
Old 12-29-2003, 04:19 PM
I'll post some pics tonight when I get home from work
Old 12-29-2003, 07:07 PM
Jon325 Jon325 is offline
Mein Auto: 325ci
Fritz,
Hey could you post up where you got the stealth boxes at and how much? I saw the JL site and it stated that for cars with the factory cd changer/nav compartment needs to me altered so I was wondering if your car came with the CD changer compartment and also does the car sound different since they had to take out the two back speakers? Thanks in advance. I am really thinking about putting in the stealth boxes so that I can still get to my spare tire.
Jon325
Old 12-29-2003, 09:01 PM
Dr. Phil's Avatar
Originally Posted by Jon325
Fritz,
Jon325
When finalizing my ICE plans today, we discussed using stealths. But since I want a deep punch and the ability to hit real lows, we opted for a single aluminum 12". But the installer was pleased with stealth installs he has done.....you will not be unhappy
Old 12-29-2003, 11:21 PM
Mein Auto: 325ci
Thanks Dr. Phil,
I feel like I am on Oprah. Now I just need to find a place to install the stealths. I am thinking about HiFi Buys (Tweeters) but when I go back to Augusta when winter holidays are over I won't have access to the Atlanta HiFi Buys. I guess I can either come back or shop around the local stereo shops in Augusta. Really worried about stereo installs since my old car was screwed up by poor installation. Any recs on install shops here in Atlanta or Augusta Ga? Thanks in advance.
Jon325
Old 12-30-2003, 06:44 AM
Dr. Phil's Avatar
Thanks Dr. Phil,
Jon325
A stealth only install would not be too difficult to undertake yourself. Since they bolt on to facotory locations the hardest part would be grabbing the signal from the OEM line. If you search here you will find some write ups on how to grab the signal from the h/k "sub" amp area and run it into your replacement amp. I believe the amp of choice for the Stealths is a JL 250/1.
Good luck!!!
Old 12-30-2003, 02:07 PM
Mein Auto: 325ci
Thanks again Dr Phil,
I don't have H/K in my car....this might be a stupid question but do I have a separate amp in my car or does it all run off of the Head unit? Thanks ......I might consider putting it in myself now....but now I gotta get a good DIY....Thanks again
Jon325
Old 12-30-2003, 08:26 PM
Dr. Phil's Avatar
Jon325
No HK then only one amp, nothing runs off head unit.
Old 12-30-2003, 08:30 PM
Mein Auto: 325ci
Thanks Dr Phil,
Anyone know where the amp is and also where this infamous white wire for the amp start is at as well. Sorry for the newbie questions
Jon325
Old 12-30-2003, 08:46 PM
Here's some pics of the setup
ID:	24159   Click image for larger version
ID:	24160   Click image for larger version
ID:	24161   Click image for larger version
Old 12-30-2003, 08:47 PM
Dr. Phil's Avatar
Thanks Dr Phil,
Jon325
The amp is located in the back left side of the trunk. Do a search for the DIY on amps and you should find a picture. I have a PDF file of the lay out but not on this computer...sorry
Old 12-30-2003, 10:00 PM
Mein Auto: 325ci
Fritz
Could you post up the websites on where you got your equipment and how much (Stealthboxes and JL 250/1). Thanks and also I see that you have the Nav/CD trunk compartment, did the installers cut into that or did they modify ur Stealthboxes to fit the driver side slot. THanks in advance
Jon325
Old 12-31-2003, 07:59 AM
Fritz
Jon325
Jon,
The JL 250x1 Amp cost me $329 and the JL Stealthboxes cost $369. I bought both of them at Myer-Emco in Arlington, VA. They did the install as well.
They modified the left stealthbox (you can see in the picture above) so that it fits over the Nav unit.
Old 02-07-2004, 04:32 PM
Boston Bimmer Boston Bimmer is offline
Mein Auto: 2004 330xi
Rear speakers and Stealthbox
I want to use the stealthbox, to conserve trunk space. But if the rear speakers come out, what/where do you replace rear fill speakers with? I have the upgraded H/K system and plan on ripping the entire atonal system out.
