Old 10-11-2010, 03:09 PM
Ken W Ken W is offline
Mein Auto: 2002 530i
E39 Valve Cover Gasket Replacement
Hi...have a 2002 530i (E39) with about 117k miles..have an oil leak and I believe it to be a valve cover gasket issue....I am looking for good "how to" guide to replace the gasket ... Thanks!
Old 10-11-2010, 04:12 PM
pleiades pleiades is offline
Mein Auto: '99 5-spd
It's pretty straightforward, you'll just maybe want to move a few things out of the way.
Here's a DIY on Vanos seal replacement that covers valve cover gasket replacement along the way.
I recently did the Vanos procedure and the only thing that held me up half a day was that the valve cover gasket had plasticized and practically welded itself to the cylinder head. Assorted putty knives and similar bladed objects in various places later, I got fed up and yanked in a couple locations I felt certain wouldn't crack the cover. It popped right off at that point, though I'll underline here, you may not face the same problem.
Old 10-11-2010, 04:43 PM
agent15's Avatar
agent15 agent15 is offline
Mein Auto: 87 325is, 02 530i Sport
I used that same guide, and also had a plasticized VCG when I replaced it this past weekend. I used a hair dryer on high heat aimed at one spot for about 90 seconds. This softened it up just enough to allow me to separate the brittle gasket from the valve cover, and I was able to work my way around that way. This method worked especially well on the hardened spark plug seals that were stuck to both the car and the valve cover.
Originally Posted by Fudman View Post
For me, the e39 is the ... best balance of luxury ... performance ... good looks and class. Sort of the Catherine Deneuve of cars, if you get my drift.
Old 10-11-2010, 04:52 PM
I have a good heat gun (or two), just didn't think to try that.
Old 10-11-2010, 05:50 PM
MatWiz's Avatar
MatWiz MatWiz is offline
Psychology Reversalist
Mein Auto: 528
Check this link out. Step by step instructions with picture for each step.
Fantastic DIY instructions.
http://www.pelicanparts.com/bmw/tech...alve-Cover.htm
mw
MatWiz
"The greatest thing about the internet, is that you can quote something and totally make up the source." - George Washington.
Old 10-12-2010, 07:35 AM
GSA1's Avatar
GSA1 GSA1 is offline
Mein Auto: '01 & '02 E39 530i Sports
You may want to clean your injectors and replace your plugs (real easy) while in there. otherwise you'll do it twice. If you are really looking for a winning day, do the vanos seals too.
Old 10-12-2010, 08:41 AM
Fudman's Avatar
Fudman Fudman is offline
At your mileage, that is a good recommendation. Cooling system should be next on your list.
Old 10-12-2010, 02:00 PM
morrisroad's Avatar
morrisroad morrisroad is offline
Mein Auto: BMW 530
Does the valve cover require RTV sealant other than in the corners by the vanos? Looks like it could go on without sealant.
Old 10-12-2010, 02:28 PM
MatWiz's Avatar
Mein Auto: 528
http://www.bimmerfest.com/forums/sho...38&postcount=5
mw
MatWiz
Old 10-12-2010, 02:38 PM
dalekressin's Avatar
dalekressin dalekressin is offline
Mein Auto: 2010 M3
The hair dryer is a great idea.
94 530i sold (That was difficult for me)
01 530i >144,500+ miles SOLD
06 330XI winter's especially fun drive (SOLD)
10 M3 Sedan (sweet)
13 Nissan GT-R Black Edition
14 Porsche Cayenne Platinum Diesel
15 Porsche GT3
16 Porsche GT4
BMWCCA 4215
Old 10-12-2010, 03:07 PM
agent15's Avatar
On the recommendation of a local BMW Master Tech I met recently, I used Hylomar, and that's the only place I used it.
Old 10-12-2010, 04:08 PM
Thanks for the help.....
Old 10-12-2010, 04:12 PM
Thanks alot MatWiz...
Old 10-12-2010, 04:15 PM
CCV or Valve Cover Gasket
Hi...have a 2002 530i (E39) with about 146k miles (sorry my fat fingers typed incorrectly yesterday ) ..have an oil leak and I believe it to be a valve cover gasket issue....(thanks for the how to guides), but now... what is the best way of determing if the problem is a a leaking valve cover gasket or a problem with the CCV system?
Old 10-12-2010, 04:31 PM
bmw_n00b13's Avatar
bmw_n00b13 bmw_n00b13 is offline
Freude am Fahren
Mein Auto: 99 528iA
Replace the VANOS seals and the VCG while you're at it
Where is the leak? What leads you to believe it's a CCV problem?
'99 528i ('98/12 build). 282,000km BY29428/Royalrot
Breaking My Wallet since 2009
Mods: Stoptech SS brake hose, 280piece toolkit resting on trunk floor, Beisan VANOS seals, increasing amounts of duct tape and glue
'99 540i (grandfather's)
Old 10-12-2010, 04:53 PM
agent15's Avatar
On my car, the seeping VCG was exacerbated by inclines. If it sat for a while facing uphill, apparently the seeping oil would form drops which then fell onto the exhaust manifold. So if it's indeed a VCG, you will probably be able to smell and/or see burning oil under that scenario. You might also be able to see wet oil which has collected on the top of the rear O2 sensor.
Old 10-12-2010, 05:11 PM
morrisroad's Avatar
Mein Auto: BMW 530
Where do you buy this stuff? never hear of it...
Old 10-12-2010, 05:31 PM
agent15's Avatar
Actually he let me use his. Google shows a number of products with that name, but this one is called Hylomar Universal Blue. Holy crap it's expensive!
Old 10-12-2010, 06:09 PM
MatWiz's Avatar
Mein Auto: 528
Run your finger along the line of the gasket and underneath it. There is a ridge-like about 1/4" below the gasket. Run your fingers there. If it's wet, you got a leak.
If you're not sure, clean it dry with paper towel or a rug. And then check again after a drive. Don't forget to check on the rear of the engine. And don't forget to let the engine cool down...
mw
MatWiz
Old 10-12-2010, 06:55 PM
thanks matwiz....I will have to wait until this weekend to execute the feel test.....
Old 10-12-2010, 06:56 PM
...its just I have not replaced the CCV after 145k miles and it could causing the "oil leak" issue...????
Old 10-12-2010, 07:09 PM
air_cooled air_cooled is offline
Mein Auto: E39 / E30 / E53
ahhh yes I remember that stuff from my days of 'SPEY'.
Great for gaskets. Found some in my toolbox....cool
Old 10-16-2010, 05:58 PM
morrisroad's Avatar
Mein Auto: BMW 530
Replaced with Victor Reinz VCG and 15 washers, I changed the oil cap gasket as well, the old one was ok. Wouldn't bother next time.- overall no gasket fusing, center spark plug wells brittle as glass basically fell apart on removal. The perimeter dry, still some elastic there, and wasn't falling apart. Checked the spark-plug well, and there was a a drop, so the seeping I had would be landing in there over a period of time. Anyways all needed to be replaced.
Another item checked off the list. Thanks!
Old 11-01-2010, 02:28 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
There is a beautiful online TIS listed in QSilver7's thread today (1).
For example, for my vehicle, here are the TIS' for replacing the cylinder head and cylinder head cover.
File Type: pdf bmw_525i_tis_removing_cylinder_head_cover.pdf (509.8 KB, 850 views)
File Type: pdf BMW_525i_TIS_replacing_cylinder_head.pdf (583.3 KB, 1137 views)
Old 04-29-2011, 10:21 AM
QMAX1234 QMAX1234 is offline
Mein Auto: 1997 BMW 528I
http://www.pelicanparts.com/BMW/tech.../tech_main.htm
This is a great link. Thanks.
