Old 10-12-2010, 08:52 AM
ahmadj ahmadj is offline
Mein Auto: 04 745li
Bass problem 2004 745li not amp related!!
Ok, so at one point I noticed that I had a crackling noise coming from my driver door speaker, I purchased a new speaker and installed it. Problem was still there. So I did some research and found out that the ask unit was bad, so I purchased a new ASK unit. Installed it and the noise was gone.
Then about 3 months later I noticed my bass was missing, I wasn't feeling the bass. So I did some research and figured out the logic 7 amp was bad. Luckily since I own a bodyshop a totalled 750 came along, I switched amps, and I still dont have bass, logic 7 works fine, but not the bass I used to have.
There's bass, but I don't feel the woofers vibrating in the seats. I am lost. What is wrong with my bass??
Thanks Guys
Old 10-12-2010, 08:57 AM
csmeance's Avatar
csmeance csmeance is offline
Mein Auto: 760Li
the ask from the 745 is different from the 750, did you recode the new one? Also the amp on the 750 may be different due to a different ask system.
Old 10-14-2010, 11:08 AM
Mein Auto: 04 745li
the ask was from a 745 but the new amp was from a 750. could that be the problem?
Old 10-14-2010, 01:20 PM
MakaveliFaison's Avatar
MakaveliFaison MakaveliFaison is offline
Mein Auto: Bmw E64/5, Maserati GT
There is an option in inpa to enable loud speakers or disable them. If a code was thrown you have to clear the code and then enable them. If you don't believe me ill take a pic when I get off of work. Go to e65 in inpa then communications system. And then top Hugo amp to clear codes. Then go to e65 then communication systems the ask to enable loud speakers.
650i sport hud ac schnitzer eibach resognator delete m6 quads akebonos
Old 10-14-2010, 02:32 PM
joej85 joej85 is offline
Mein Auto: 2004 745Li, 1989 735i
No bass could also be battery/alternator/power module related. The power module will shut down the bass if it thinks the battery power is low.
Old 10-14-2010, 02:56 PM
irokdastar383 irokdastar383 is offline
Account Under Review
Mein Auto: 745li
the amp from the 750 might not work with 745 . check the part numbers i think its diffrent.
Old 10-15-2010, 11:53 PM
Mein Auto: 04 745li
ok I am lost, I don't understand anything of what you just said
Old 10-20-2010, 08:54 PM
Mein Auto: 04 745li
Thanks Guys
I am lost, help guys
