95 540i auto transmission problem. Please HELP!! - Bimmerfest - BMW Forums
E34 (1989 - 1995)
Old 10-12-2010, 07:59 PM
traiconghoa traiconghoa is offline
Mein Auto: 540i
Just replaced new motor, and driving good for couple weeks. However, this morning the car start but won't go anywhere when I put in drive (none of the gears are working) except reverse. Please help to figure out the problem and how to fix it. Thanks
Old 10-12-2010, 08:11 PM
Banned
Mein Auto: car
Disconnect the battery and unplug the ecu for 1 hour, then plug everything back in again and try. Before that, use the stomp test (search for it on bimmerfest) and pull out the error codes on your vehicle. You can use it to clear the error codes as well after you've pulled them out. Oh, you're driving a 95 vehicle, so there should be no need to disconnect the battery and ecu to reset the computers, but maybe its a good idea anyway as I'm not sure if the transmission computer can be reset via the stomp test's code clearing mechanism.
After all this, fix everything back again, start the car and see if the gears work.
Old 10-15-2010, 11:15 AM
Mein Auto: 540i
Is there a obd on a 95 540i, and where it located? Thanks
Old 10-16-2010, 05:11 PM
fabi fabi is offline
mama toto
Mein Auto: 5series
there is no obd on it...it take a cirlce plug from a scan tool under the hood like the newer ones
Old 10-17-2010, 04:55 AM
mikes95540i mikes95540i is offline
Mein Auto: 1995 540i V8 Auto Trans.
My 95 540i auto trans has an obd plug. WRONG!
As I started righting my comment I questioned myself and went out to look. Fabi is correct, it does take the circle scan tool. The location is on the right side next to the negative terminal located at the firewall. Right side meaning the passenger side on US cars.
Damn... that's another tool I need. :-)
1995 E34 BMW 540iA M60 V8 Auto Trans.
668 Schwartz II Black II Standard Black 51 91 1 052 171
Old 10-18-2010, 10:34 AM
Mein Auto: 540i
Thanks for the useful informations. Just wonder if I can purchase a BMW circle 16 pins adapter to use it with my Actron OBD II to reset the transmission code?
