Tire Size - Bimmerfest - BMW Forums
Old 10-13-2010, 08:26 AM
X3forlife X3forlife is offline
Mein Auto: 2005 X3
Tire Size
So the 28i will have 17 inch tires while the 35i will have 18 inch tires.
Could one of you car geniuses please explain in English what effect tire size has on driving? Is bigger better?
Old 10-13-2010, 11:40 AM
Huey52 Huey52 is offline
Mein Auto: X3 (in 2011)
No, bigger wheel size is not necessarily better, especially in winter driving where you want a tall tire sidewall (profile). Bigger wheels do tend to look better however as they better fill the wheel wells. So, it really depends on your climate and intended use.
Old 10-13-2010, 12:40 PM
Mein Auto: 2005 X3
So are you saying that bigger tires are worse in winter (snow) or is this more theoretical?
Old 10-14-2010, 05:31 AM
You're confusing wheel (rim) size and tire size (profile or aspect ratio).
Again, for winter snow driving (and poor pot-holed roads) you want a smaller rim (in this case 17") with a narrower and taller tire profile. For summer driving (and aesthetics) you want a larger wheel (18") with a lower profile tire.
The narrower tires cut through snow more easily and the taller sidewall provides more clearance and shock absorption. Larger wheels with low profile tires and pot-holes don't play nice together.
So again, you have to determine your climate and typical driving regime.
Of course in snow country the best option is to have dedicated snow wheels/tires.
In Maryland you should do fine on the 18" rims with all season tires, unless your local roads are very poor.
Old 10-14-2010, 03:32 PM
Mein Auto: 2005 X3
I knew we were talking about rims but maybe I used it interchangably because i figured 17" tires go on 17" rims and 18" tires go on 18" rims. lol
Thanks...so 17 is better in the snow it sounds like. The reason I ask is in case it becomes a tiebreaker and I decide to go for the 35i, I'd like to know the extras are better for me, not worse. Also I'd hate for the snow capability to somehow get worse than the current model.
I get it that 18" is for looks but has a stiffer ride.
Thanks for your help.
Old 10-21-2010, 07:01 AM
vrrooom's Avatar
vrrooom vrrooom is offline
Vorsitzer
Send a message via AIM to vrrooom
Mein Auto: Bummers, porkys
Talking Tire and wheel size
In my E86 X3's I have had both 17 and 18 inch diameter wheels with different tyre sizes. The 17's were 235X55 and the 18's were 235X50 Scorpions. The rolling diameter was 27.2" for the 17's and 27.3" for the 18's. These diameters are almost identical and considered interchangable as long as all 4 wheels are identical. I suspect the new F X3 will have similar sized tyres.
Current Rides *Retired Rides
E90 2009 335ix
F25 PCD 2011
E86 ED 2006
911 Turbo Cab
*E86 ED 2004
*E86 ED 2008
*E46 M3 2001
*E36 ED M3 1995,
*E36 325IS 1992
*E34 ED M5 1991
*E30 318ISLemon Lawed
Porkies*924,*944 ED
Benzies*ML430,*E300 ED
Old 10-31-2010, 05:40 AM
Mein Auto: 2005 X3
Everytime it crosses my mind that the 18" wheels/tires on the 35i might make for stiffer ride and might not be good in the snow, I have to remind myself that all of this talk is theoretical hocus pocus and BMW has likely adjusted for all of this.
For one, they are not likely to ignore the dynamics on their higher end model of the two.
Secondly, and most importantly, the X5 comes standard with 18s and nobody is worried about how that handles in the snow or if the ride on the X5 will be too stiff. They have made their adjustments and know what they are doing.
Old 11-01-2010, 06:12 AM
Yep; 18" with all season run-flat tires will be fine for you.
Old 11-01-2010, 08:01 AM
Mein Auto: 2005 X3
It should be fine for most I would think. Again, the most powerful argument in my mind is that those are the wheels/tires that are standard on the X5. If the 17s were so much better in snow or comfort, they would find away to get it on the X5. That is their flagship (for the X series).
It's probably true that given the same suspension...but they just adjust the suspension for it.
Old 11-01-2010, 04:14 PM
Mein Auto: 2005 X3
So...I just watched a video of the X6 in the snow and it looked good to me...and that has 20" tires.
So i think this tires size only matters if the car cannot adjust suspension and handling to account for it. If it is thought about ahead of time and BMW adjusts handling, suspension, the X-drive, Dynamic dampening etc. to that particular tire (while testing ride quality), it probably doesn't matter.
Their mother of all flagships the 760Li has 19 inch tires yet is comfortable and probably handles well in the snow (I watched a video but I'm not sure how much spinning the driver is trying to do on purpose). They just need to adjust things.
Old 11-01-2010, 05:04 PM
raleedy's Avatar
raleedy raleedy is offline
Mein Auto: 2016 228i 6-speed
Wheel size = aesthetics. Tire size =performance. A wide tire with a big contact patch spreads the weight of the car over more road surface. This is great in the dry and (depending on tread compound and pattern) wet, bad in the snow. A skinny tire with a smaller contact patch won't handle as well in non-winter conditions, but it will be better in the snow (and maybe in standing water that could cause hydroplaning). A low-profile tire (say, aspect ratio of 40 or 35) may affect the car's ride by providing less cushioning over the road surface, and may expose wheels and suspension parts to damage from potholes, as well as exposing wheel rims to "curb rash" because there isn't enough tire there to protect the wheel from curb contact. A low profile tire may also produce more road noise, higher rolling resistance (and inferior fuel economy as a result) and some handling problems like "tramlining" and pulling to the outside on crowned roads. Of course, on a given car, there are limitations for the circumference of the mounted tire, for the combined diameter of the mounted tire and wheel combination, and for the width of the tire.
Old 11-01-2010, 05:54 PM
Mein Auto: 2005 X3
Interesting...sounds like you are saying we should be focused on the width (and thickness) of the tire when considering weather. I haven't been paying much attention to the width but again, if the higher end cars can handle it, then an X3 should be able to handle it too.
So it sounds like the two components of the tire are the width and the "thickness" of the tire (I don't want to say radius or diameter since that will depend on the wheel size).
I wonder if most people even know these numbers. I'll try to pay attention next time I look.
Old 11-01-2010, 06:07 PM
Mein Auto: 2005 X3
Pretty cool explanation
http://www.tinytears*****Technical%20Tips/tire_size.html
I never understood the numbers before.
Old 11-01-2010, 06:21 PM
Mein Auto: 2005 X3
So looking at it the tires on the X3
28i = 245 mm wide, 134.75mm tire thickness
35i = 245 mm wide, 122.5 mm tire thickness
So for the X3, the width is not adjusted, only the tire thickness. I'm sure they will adjust the suspension to account for this as far as ride. How would tire thickness affect snow/ice?
By comparison, the 18" tires on the X5 are wider and thicker than both of these.
255 mm wide, 140.25 mm thickness
Old 11-01-2010, 07:21 PM
raleedy's Avatar
I think it doesn't. But most low profile tires are wide, and width does.
Old 11-01-2010, 08:39 PM
Mein Auto: 2005 X3
Oh OK. You saw my numbers above. You see that the X3 has tires that are less wide than the X5. Are you suggesting that the X3 should handle snow better than the X5 (they both have the x-drive, HDC, etc.)?
Old 11-01-2010, 09:27 PM
raleedy's Avatar
No. They're different cars.
Old 11-02-2010, 12:05 PM
Mein Auto: 2005 X3
Even thought they have all the same X-drive and stability systems, i guess one could argue that weight, wheel axle length anfd other factors make a difference.
All in all it seems like the cars they have been testing the most are the 35i and 20d. I have not seen any reviews of the 28i or seen it out being tested anywhere.
I can't wait until somebody compares the 2 cars. I just didn't want to give up snow handling for looks.
