Old 01-19-2012, 10:37 AM
jamesfr jamesfr is offline
Mein Auto: E46 M3
no - didn't realize this you make any difference... Would it not clear the lin bus if the battery was not disconnected??
Old 01-19-2012, 11:29 AM
can0n4 can0n4 is offline
Mein Auto: '04 BMW X3, '04 330xi
It probably won't, but its a free try. This isn't based on the old school methodology of resetting the car by disconnecting the battery, its based on the fact that I have had multiple electronic and sensor issues with my X3 and its become habit now. Somewhere I did read this though.
Other than that, lets assume it doesn't change anything...
1. You replaced your switch? (This just fixed mine with same symptoms as you)
2. You disconnected your mirror motors (behind the triangle door trim on interior)?
3. Reset Battery
4. Still no changes??
Old 01-20-2012, 08:27 AM
Mein Auto: E46 M3
thanks Can0n4...
I will disconect again and then disconect battery and see if this makes any difference.
Yes I have tried a new switch unfortunately
Old 01-20-2012, 01:07 PM
Mein Auto: E46 M3
Thanks looks like the reset made the difference - I now have power windows working but no mirrors...
I assume if I connect them back up I can see which one is broken causing the fault.
What is the actual part I need to order for the mirror - is it the motor or curcuit board?
Old 01-20-2012, 07:54 PM
Wow. I really didn't think that would make a difference, just a a hunch based on what I've recently dealt with.
You need the mirror motor. See post #12 in this thread and the ones before and after them which discuss the parts number. Make sure you trouble shoot which mirror it is, let me know if you pinpoint the actual mirror causing the problem, im curious to see if this method works. But make sure to do the battrery reset in between tests. After you plug a mirror in, youll, have to reset the battery again. Then again disconnect the battery and connect again to do the other side. I assume this would go for other electrical fixes as well not just bad switches for future reference to other x3 owners.
Also , just thought of this, you may want to take the mirror apart from the outside and trace the wire to see where it goes, nothing can guarantee its the motor, but I think that is what it is based on what Ive read in this thread.
Old 01-21-2012, 12:56 AM
Mein Auto: E46 M3
Thanks - will let you know
Old 02-29-2012, 02:22 PM
jasonkp1978 jasonkp1978 is offline
Mein Auto: X3
2005 x3 driver window switch stopped working.
Hello I know this is an old post but I recently bought a X3 and now I am having trouble with operating my windows and mirrors from the driver side. At one point I thought I wouldn't be able to get the driver side window in the closed position. Can anyone tell me exactly what their problem is and what parts I should order?
Thank You
Jason
Old 02-29-2012, 02:58 PM
Mein Auto: E46 M3
problem could be either the swtich unit or one of the mirrors....
Disconect both mirrors when you have the battery disconnected. connect battery back up and try windows. If they work as expected you have a problem with one or both of your mirrors. They the problem is the same order a new switch.
Old 02-29-2012, 03:08 PM
Mein Auto: X3
Thanks for the fast reply. This is a new vehicle to me so I don't exactly know how to disconnect the mirrors. I see where underneath the mirrors is a panel I can pry off and then it exposes the wiring, but I didn't see where to disconnect it. Also, it seems that everything works sometimes, and then sometimes nothing works. So I think its going to be difficult to tell what is bad or needs replacing. Also, if my window does get stuck in the down position, is there anything I can do to get it back up?
Thanks again!
Jason
Old 02-29-2012, 03:16 PM
Mein Auto: E46 M3
to unplug the mirrors remove dorr panel from inside and then disconnect mirror plugs where the mirror bolts onto the door (from inside)
If the mirrors are the problem you can try to get the passenger window down and up from the drivers switch - you need to hold it down for ages!! if it goes down you can put it back up using passengers switch!
Old 02-29-2012, 03:22 PM
Mein Auto: X3
Okay I will see if I can get the door panels off. I have never taken those of before either, so I hope I dont mess anything up! If there is any special technique please let me know. Also, I forgot to mention but all the other switches (passenger and rears) all work, its just the driver side that I am having issues with. All the other windows I can get up from using the other doors, just not driver side. I wonder if I should just order both mirror units and the master switch, that way I should have it all covered. Just not sure how expensive that would be. I bought this at a wholesale dealer for cheap...so I knew there might be some issues. After owing a Audi for my wife, I had to get another European car...nothing else drives the same.
Jason
Old 02-29-2012, 03:26 PM
Mein Auto: E46 M3
Do a search on here for info to remove door panels and there is a vid on youtube I think - disconnect battery 1st and watch the airbags in the doors
Old 03-01-2012, 08:23 AM
Mein Auto: X3
I was able to get the door panels off but I was wondering if everything works sometimes from the master switch, wouldn't that be a sign of the switch not working properly all the time? When it is working the mirrors move just fine along with the windows. Makes me think the motors are okay but not the switch.
Thanks again
Jason Poole
Old 03-01-2012, 11:19 AM
Mein Auto: E46 M3
I have a switch pack forsale...
£75 delivered in the UK - BRAND NEW!!
For RH drive cars with 4 power windows and electric wing mirror adjusts (Not Power fold mirrors)
BMW Part number 61313414354
Old 03-01-2012, 11:42 AM
Mein Auto: X3
I wish I could take you up on the offer, but I live in the states and its a left sided driver. To you does that sound lile it should be the switch? Like I said its all working fine now. My radio does cut out like every 30 mins though, then I have to turn it back on. I wonder if its related?
Old 03-01-2012, 11:53 AM
Mein Auto: E46 M3
I would think it was worth getting one to rule it out mate
Old 03-03-2012, 10:51 AM
Mein Auto: X3
Hello again,
I was hoping I can use your expertise again. I think I am going to replace the mirror (actuator) that's just the motor correct? What's the best way to take apart one of those mirrors?
Thank You
Jason Poole
Old 03-10-2012, 09:29 AM
Espen Lysholm Espen Lysholm is offline
Mein Auto: 04 BMW X3 2,5IA
Had the same problem until today...
I found out how to remove the master control unit or rocker switch for power windows and mirrors without removing the door panels:
http://www.autozone.com/autozone/rep...00c152801b2896
Pulled out the unit, opened the unit and cleaned the print card. Mounted the unit back together.
Now the mirrors and windows workes again :-)
Kind regards
Espen Lysholm
Old 03-10-2012, 03:53 PM
Mine did too for two weeks
Old 03-10-2012, 03:59 PM
Mein Auto: X3
Mine is weird though. It has been working just fine now for the past week or so. I never know whechn the switch won't work. Its very confusing. I havnt ordered a new switch yet, I will let you guys know once I have tried it!
Thank you very much
Old 03-10-2012, 08:05 PM
Mine was similar, took the mirrors apart, the door panels, all of it. A new switch fixed it.
Old 03-19-2012, 02:44 PM
Mein Auto: E46 M3
Switch just pulls out of teh door without removing anything... Its the door cards you need to remove to disconect mirrors.
Thank you very much
Want to buy mine - Now @ £50??
Looks like its the same part number for LHD & RHD
NOW REDUCED TO £50
Old 03-19-2012, 03:03 PM
Mein Auto: X3
Hello,
How much would shipping be to the states? I can get here for about 100 bucks. Do you have the cover also? If so what color?
Thanks jason
Old 03-20-2012, 02:04 PM
Mein Auto: E46 M3
Hello,
Thanks jason
Hi Jason,
Use your orginal cover mate - if you can get a new one for a hundred bucks its has to be better to buy one in the US. Thanks for ask though
Old 09-04-2012, 03:41 PM
sayemthree's Avatar
sayemthree sayemthree is offline
Mein Auto: 2008 M3
to disconnect the mirrors, do i have to remove the door panels or can if be done by removing the black triangle on the inside where the mirrors attach ?
BTW all my windows work fine but neither mirror works, and no tilt. its not a fuse and I do have poert to the drivers door swicth.
2008 GTI 4 dr. 6MT
2008 535xit Sportwagon 6MT Deep Sea Blue, Cream Beige,sport-premium-cold weather.
2008 M3 Coupe 6MT Jet Black
2004 X3 3.0i 6MT
power window switch's, window problems
