Do-It-Yourself H.Q.
Share your DIY projects that have helped you keep your BMW running. For questions about how to fix your BMW use the model specific forums. All BMW DIY tips, tales, and projects discussed inside. Learn to work on your car and know the right BMW parts you will need!
Old 04-05-2002, 02:36 PM
Clem's Avatar
Clem Clem is offline
The Corruptor
Mein Auto: ACS 323i
31st330i and others interested. E46 M3 Xenon ballast bracket and cover WORKS........
in a 1999 323i
Old 04-05-2002, 03:05 PM
31st330i 31st330i is offline
Now with Nano
Mein Auto: 2001 330i
sweet! I was about to order them myself for my ESIS. cheep too, no? less than $15 or so for bracket and cover?
Old 04-05-2002, 05:14 PM
Clem's Avatar
The Corruptor
Mein Auto: ACS 323i
Something like that I have to check, but buy one of the nuts that is displayed with it on the ETK, you can use one of the bolts from the airbox for the bottom part of the bracket
Old 04-09-2002, 02:08 PM
Now with Nano
I'm going to order the bracket, cover and hardware myself. not bad for ~$10.
hereare the part numbers in case anyone else is interested:
61 12 7 893 034 xenon ballast bracket
61 12 7 893 035 xenon ballast plastic trim
72 12 8 244 154 xenon ballast screw (qty 2)
51 11 8 362 524 xenon ballast nut (qty 2)
Old 04-09-2002, 02:35 PM
webguy330i webguy330i is offline
Head-In-Sand Dumbass
Mein Auto: BBY Evo VIII
Forgive me for asking, but why is this relevant? I'm just not understanding that's all.
tia!
2006 GG Evo IX GSR
got acronyms?
"Bbbzzzzzst and all that..." - rost12
Old 04-09-2002, 02:42 PM
Now with Nano
well, if you have the Dinan or perhaps even the Motronix CAI, it looks better than the Dinan supplied bracket. you need to relocate the xenon balast with these CAIs so that the tube can fit down into the cavity.
I'm looking at this for my ESIS idea. while you can sneek the the radiator hose (the new inlet) past the ballast, it's a tight squeeze at first. 323/328 owners with xenons looking to possible modify the stock air box will need to do a cross between my ESIS mod and shawn fogg's "fogged" airbox mod. since the 323/328 only has one inlet to begin with, the secondary inlet will need to be larger than the one I use with the ESIS. 323/328 owners will need to move the ballast.
BTW, the total cost of the bracket, the plastic trim and the screws is only like $11.
Old 04-09-2002, 04:17 PM
And it all becomes clear... thanks!
2006 GG Evo IX GSR
got acronyms?
Old 04-11-2002, 11:56 AM
Clem's Avatar
The Corruptor
Mein Auto: ACS 323i
FYI:
You only need 1 nut and you can reuse one of the screws/nuts from the OEM air box.
