X5 E53 (1999 - 2006)
The X5 SAV Forum |
2003 X5 Radio keeps shutting of on it's own
I recently purchased a used 2003 X5 3.0. I have encountered several problems. The most annoying one is the radio turning off by itself. It seems to act very erratically. It also appears to be affected sometimes by lifting the arm rest and turning down the interior dimmer. But that is only the case at night.
Also, the BC function occasionally stops working. Should I look at replacing the radio or is the problem more computer based. I also have an issue with missing pixels on the main display below the speedometer/Tach. Are they related? Thanks for any help. |
Oddly, sounds like you might have a battery issue...you'd be surprised. Try getting a replacement battery @ Autozone for around $80, keep the receipt and see if that fixes it. Burnt pixels are typical for BMW OBC and MID clusters, the ribbon cable can be replaced for about $50 on eBay OR the wild change that you can get in touch with BMWNA and ask about their replacement, but sometimes their labor and parts costs can outweigh the saving of just getting the ribbon replaced.
New here? Please visit www.e38.org, THEN you ask questions 325hp 98 740iL, black/black - Eatin 540's & $hittin 318's PERFORMANCE:///M5 6spd conv., Iron sleeves, L/W Teflon coated pistons, 3 angle valvejob, P&P head, cams, electric fan, CF intake tube w/aluminum heatshield, Magnaflow 14816'd INTERIOR:Hardwired V1 above rearview, 12" RE Audio DVC sub, MTX 81000D, silver trim, 5% tint EXTERIOR:19" Beyern Mesh staggered, Shadowline kidneys, Axxis pads 01 X5 4.4 - F90BT, L5 |
Got the same problem with the radio on my 4.4 getting annoying now did the new battery solve the problem?
bump
Try wigglng the ignition switch and see if anything happens. There have been instances where heavy and bulky keyrings cause the contacts inside the lock tumbler to get screwed up and cause erratic issues as well.
its your bm 54 unit radio module is dodgy
X5 radio problem
Hi Guys
Buying a 2002 X5 3.0ltr diesel, the radio is jammed on the MW wavelength can it be fixed or will I need to replace ?: ::
Check out this thread from Xoutpost:
http://www.xoutpost.com/bmw-sav-foru...dio-issue.html |
Thanks for link, unfortunately it's a separate issue. Additional info is that radio will turn off or on but only when the vehicle has been turned off, key removed and vehicle locked ! Then when you re enter the radio can be turned on or off ( depending on the last mode) but only once , you then have to go through previous process, in any case it will only function on MW band ( as I gather that it remembers which mode was last used and you cannot select Cd mode either. Other info is that the time display is blank , the year is set to 2007 and can't accept input. The mileage and avg speed function is working ok
Try a battery disconnect/reconnect with a few minutes in between.
Hi
Thanks for suggestion, but already tried this method no better Any other suggestions welcome Best regards Alwyn |
dont know if anyone can help me, my radio will not turn on, i did have a new battery fitted a couple of weeks ago
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
