Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series > 7 Series - E23 / E32 (1977 - 1994)
Old 10-18-2010, 03:56 AM
joeotoo joeotoo is offline
Mein Auto: 1994 740iL
94 740iL - Transmission fill? GEAR?
Hello,
I drive a 1994 740iL with the "LIFETIME FILL" A5S 760Z Transmission.
I need to add some fluid, I have the proper fluid, know where it is filled, and how to fill it except for ONE MAJOR FACT . When topping it off during the fill I need to find out ----what position the transmission needs to be in when checking for the proper level (with engine running, and correct fluid temperature etc) I realize it will overflow at the proper fill level.
But is that when transmission is in Drive, Neutral, or Park?
The Bentley Service Manual does NOT specify a TRANSMISSION LEVER GEAR POSITION to place car in when refilling/checking for the proper fluid level and I do not have access to a real BMW shop manual. I have 103,000 miles on the car and I have a "Transmission" warning light on. The Bently Service manual suggests the problem is due to low fluid. I do see evidence of a small leak at the front of the case.
So guys please tall me , What position to place the transmission gear level in?
Thanks, and where is the E 32 forum located?
Thanks,
Joe
Old 10-18-2010, 06:00 PM
TerryY's Avatar
TerryY TerryY is offline
Old Fogey
Mein Auto: BMW '95 840
BMW pdf I found says to check level in Park after running thru each gear-(pausing in each one to fill the passages)- then pulling the plug while in in Park with the AC on to raise the idle.
PDF is too big to attach.
Terry
Woodland Washington
'95 840Ci
'98 740i
'00 Range Rover Vitesse
www.wuffer.net
www.8coupe.com
www.8er.org
Old 10-19-2010, 07:12 AM
Thank you
GREAT Thanks alot!
Joe
