F10 / F11 (2011 - Current)
The new chapter in the highly successful story of the BMW 5 Series Sedan (F10) and wagon (F11) |
Dashboard speaker?
Hi,
I've just bought a 520dSE with the standard stereo. I thought long and hard about the £400 plus upgrade but decided the basic was probably ok. However, even with bass on max, it's a little underwhelming and I'm beginning to regret not forking out. I've noticed a large grille in the middle of the dashboard and thought this was a bass/sub as the door speakers are pretty small but no sound comes out of it. Does anyone know if this is indeed a speaker and whether it can be enabled or without an upgrade, is it just a blank? Many thanks, Ian |
More than likely, that speaker is blank if you did not order a system upgrade. It will be expensive to upgrade, and most likely needs to be aftermarket.
I'm not sure about the UK specs for the 5-series, but in the states the standard audio is:
High-fidelity 12-speaker sound system, including 2 subwoofers under the front seats, and digital 7-channel amplifier with 205 watts of power The upgraded system is: Enhanced Premium high-fidelity 16-speaker sound system with Digital Sound Processing (DSP), 2 subwoofers under the front seats and digital 9-channel amplifier with 600 watts of power In both cases the sub's are mounted under the seats. That said, the grill on the dash is for a speaker, the question is going to be if it's pre-wired on your car or not. Even with the additional speaker you're still dealing with almost 400 watts difference between the standard and premium systems |
Thanks. Have just checked the base spec and it should come with 6 speakers but I can only trace 4 (1 in each front door and 1 each behind each rear headrest) unless they have a tweeter and mid/bass side by side and count them separately?
Coincidentally, dealer rang me today to check all ok so I mentioned the middle dash speaker- will get back to me. Cheers for comments. |
Perhaps two speakers underneath the seats functioning as bass.
