Old 10-20-2010, 03:14 PM
Quick11 Quick11 is offline
Mein Auto: 2011 535i
Where's The Battery?
Embarrassing to ask; however, where's the battery in an 2011 F10 535I? I just had mine replaced but have no idea where it is.
Old 10-20-2010, 04:01 PM
jwrtiger jwrtiger is offline
Mein Auto: 2011 528i
What battery???
Just kidding and a fair question. I believe that many if not all of the BMWs have the battery in the trunk area. I was told that the battery is under that small storage compartment in the rear center area of the trunk and you have to unscrew the two fasteners. If you check the engine compartment you will find two large metal studs for both the positive terminal (RED) and negative terminal for making external connection to the car. If I am in error someone jump in.
Old 10-20-2010, 04:08 PM
jeffhoff jeffhoff is offline
Mein Auto: 2012 X5 5.0
Conventional wisdom (for BMW) would put it in the trunk or under the rear seat. I looked in the trunk of my car and can see the fasteners jwr is talking about, given the size of the cover for the storage compartment and the much smaller available space under this cover it seems reasonable that this is where the battery is likely located.
What I find odd is having to replace a battery in a F10 already.
Old 10-20-2010, 04:21 PM
Battery Replacement
I agree but it failed never the less. It took my BMW dealer two days to open a PUMA case and run the necessary tests to determine the battery was dead.
Thank everyone for the replies. I'll go try to find the battery. I've already had to jump the car via the two lugs in the engine compartment to get it to the dealer.
Old 10-20-2010, 04:35 PM
raleedy's Avatar
raleedy raleedy is offline
Mein Auto: 2016 228i 6-speed
It's in the owner's manual.
Old 10-20-2010, 05:14 PM
The owners manual is too small to hold the battery
Actually the information is not in the owners manual.
