E90/E91/E92/E93 (2006 - 2013)
remote doesn't work
I have a 2008 328i convertible and the remote key stopped working. The spare doesn't work either. I read that the battery might run down on short trips and will need to be recharged during a longer trip. I live in Hawaii so there are no really long trips so I ran the car in my driveway for two hours. Immediately after the key worked fine, but the next morning it didn't work again. I tried this one more time running the car for four hours this time. Same result: worked fine immediately after but didn't work in the morning. Since it did work at least once I don't think it's a programming or note an issue. Puzzled.
Do you have comfort access?
1997 328i- retired ![]() 2007 328i- retired ![]() 2006 X5- retired ![]() 2006 330xi- retired ![]() 2011 X5 -retired ![]() 2011 335xi-PCD-12/13/10 Dinan stage 3, intercooler, oilcooler, and exhaust.bmw cca#443379 |
You're proabbly going to need the dealer's help on this. If you had Comfort Access, you would have replaceable batteries in the remotes, and that would solve the problem as you describe it. Without comfort access, the remote batteries are rechargeable and not replaceable. They shouldn't fail, but sometimes they do, and in that case replacement remotes (which have to come from BMW) are the best -- and perhaps only -- solution.
Could be a weakening battery in the car itself. If so, idling in the driveway won't solve that. You need to take it for a extended drive with higher revs. If it's not too late.
Ordered: March 7, 2008 Built: March 17, 2008 At port: March 19, 2008 Shipped on Graceful Leader: March 21, 2008 Arrived Port Hueneme: April 11, 2008 At dealer's: April 19, 2008 Delivered: April 21, 2008
Get a battery tender such as a Ctek 3300
Get a battery tender such as a Ctek 3300 for the battery in the car.
Running the car in idle for extended periods is really not a good idea plus its not a good way to charge a battery. A Ctek battery tender will cost you about 50 bucks on the internet for the basic model , well at least in the the 48 states. About as much as a Tank of Gas. If you have comfort access there is a 2 dollar battery in the Key Fob you can change. The non comfort access key has a rechargeable battery . There is a place you can send those to have the battery replaced that was posted here awhile ago . Or there are DIY's on replacing the battery if you are skilled. Do this search on google bmw keyfob battery replacement bmwgm5 I think is the guy that fixes these his site comes up on the search. http://www.bmwgm5.com/kf_repair.htm Last edited by ctuna; 04-24-2013 at 08:31 AM. |
