The X5 SAV Forum
Old 10-21-2010, 06:58 AM
gearjam gearjam is offline
Mein Auto: AUDI
2D03 code 2005 X5 p1721
2005 x5. Battery went dead now I have p1721 code and car won't run. You can hear the throttle opening and closing when the key is on. If you get it to run the check engine light and battery light are going on and off. You can not drive it the engine speed is going up and down till it dies??????
Old 10-21-2010, 06:30 PM
Jetblackstreak Jetblackstreak is offline
Mein Auto: 2001 X5, 1996 328is
Did the battery go completly dead? If so, did you replace it or just jump start the vehcile?
Old 11-02-2010, 08:36 PM
m5james's Avatar
m5james m5james is offline
Send a message via AIM to m5james Send a message via MSN to m5james Send a message via Yahoo to m5james
Mein Auto: 98 740iL - Tweaked a bit
You'd be surprised the issues bad batteries can cause with BMW electronics. Hold the battery cable together overnight (clearly detached from the battery) to kind of force reset the ECU, Replace the battery ($80 from Autozone), and let us know what happens.
New here? Please visit www.e38.org, THEN you ask questions
325hp 98 740iL, black/black - Eatin 540's & $hittin 318's
PERFORMANCE:///M5 6spd conv., Iron sleeves, L/W Teflon coated pistons, 3 angle valvejob, P&P head, cams, electric fan, CF intake tube w/aluminum heatshield, Magnaflow 14816'd
INTERIOR:
Hardwired V1 above rearview, 12" RE Audio DVC sub, MTX 81000D, silver trim, 5% tint
EXTERIOR:19" Beyern Mesh staggered, Shadowline kidneys, Axxis pads
01 X5 4.4 - F90BT, L5
Old 06-15-2012, 07:40 PM
Totalfixation Totalfixation is offline
Mein Auto: 545i
Just curious gearjam how were you able to fix the problem?
