Brake rotor and pad minimal thickness - Bimmerfest - BMW Forums
Old 10-21-2010, 11:48 AM
kenza kenza is offline
Mein Auto: 2007 X3 2.0d MT
Hey guys, does anyone know what is the minimal brake pad and rotor thickness (when they need to be replaced)? Thanks!
Old 10-21-2010, 03:59 PM
X3-po's Avatar
X3-po X3-po is offline
Mein Auto: 2009 X3
Hi Kenza,How's the Xenon project going ?
As far as the brakes;the min rotor thickness is marked on the rotor and the pads (according to the dealer) should be replaced at 3mm
Old 10-21-2010, 11:52 PM
Hey X3-po, how have you been?
Xenon is waiting for a weekend with some free time (new 20 days old baby at home is the reason why I am still trying to have some sleep in free time, instead of replacing headlights , but I got all the hardware, including the leveling sensors).
Thanks for the rotor and pad info, will have to visually inspect the brakes
soon.
Old 10-22-2010, 10:10 AM
enamoured enamoured is offline
Mein Auto: 2005 BMW X3 3.0i
Hey Congrats on the new baby
(OO \ (|||) (|||) / OO)
Old 10-23-2010, 12:26 AM
Thanks Enamoured!
Old 10-23-2010, 06:49 AM
X3-terrestrial's Avatar
X3-terrestrial X3-terrestrial is offline
Aficionado
Mein Auto: '05 X3, '02 M3, '91 E30
soon.
Congrats on the baby too! IIRC rotors min thickness is 19mm, but don't quote me, it's engraved on them. 2-3mm is about right for pads, or when the sensor goes off
Old 10-23-2010, 11:25 AM
Mein Auto: 2004 X3 2.5i
The numbers I have seen are:
FRONT ROTOR
Normal: 25.0, Min.: 23.4 mm
REAR ROTOR
Normal: 21.9, Min.: 20.5 mm
(I presume "Normal" means the new thickness.
And all model years use the same rotors?
The rear rotors are smaller and thus thinner than the fronts.)
Old 10-23-2010, 06:30 PM
Thanks x3-t thanks for the numbers too.
Old 10-25-2010, 07:49 AM
I have visually checked the pads and it seems I will have to replace the front pads soon (they are at 3-4 mm at the moment). I will see if rotors are due for replacement too when I take off the wheels.
What about bedding the brakes? Are there any specific instructions?
Old 10-25-2010, 06:11 PM
Aficionado
There's mixed opinions about brake bedding, from "not needed" to the "speed up to 60 miles, the brake hard, then repeat ten times"
I just do a couple of medium to hard stops from 15-20 mph going forward and a couple in reverse. The real bedding happens during normal braking over the first 200 miles.
Old 10-25-2010, 11:16 PM
Old 10-26-2010, 09:31 AM
hmjfrank hmjfrank is offline
Mein Auto: 2006 X3 & 2010 335xi
Rotor Replacement
How do you know if the rotors need to be replaced?
Brake pads are @ 3mm in front and 3.5mm in rear. My X3 has 41K miles. Dealer is recommending replacement of pads, rotors and sensors - at dealer prices. They visually inspected brakes when rotating the tires, but provided no info on the rotors other than to say they recommend replacement.
Is this overkill or can just the brake pads be replaced?
Old 10-26-2010, 10:17 AM
Aficionado
If they don't meet the min thickness. Are you out of free maintenance I suppose?
BMW rotors, usually will have 1 1/2 the lifespan of a set of pads, so if you keep the same rotors, they will be wear at less than expec when the new pads wear 50%, risking damaging other components (like brake calipers.)
Old 10-26-2010, 10:27 AM
Yes, I am 3 months out of free maintenance, of course!
Thanks for your input. I read a few other threads after posting this and saw that it does seem like a good idea to do both unless you are doing maintenance yourself and are keeping a very close eye on things.
Old 10-26-2010, 12:57 PM
I am having the same doubts. I am at 70K kms and I guess I will have to replace both rotors and pads. What is the average life of rotors? Experiences?
Old 10-30-2010, 10:33 AM
Just checked and I still have 23.6 mm on the front rotors. As my car has 70.000km, it seems
rotors wear 0.2mm per 10.000 km, so I should be ok for more or less 10.000 km more.
Pads have to be changed now.
Now: what would happen if one does not change the rotors when they are at 23.4 mm, but continues to use them
until they are at 22.4 mm? Has anyone done that? I will not try it, but it seems that 1mm is not a big deal...
Old 10-30-2010, 11:38 AM
X3-po's Avatar
Mein Auto: 2009 X3
The reason for minimum thickness on brake rotors and pads is because you loose some of
your stopping power because of lost heat disipation and also the caliper and piston would be out of its designed travel range.1 mm could be a big deal.
Belated congrats on the baby
Old 10-30-2010, 11:48 AM
Thanks X3-po
I can understand the heat dissipation but piston and caliper should be much more extended with 3mm pads than with 23mm rotors and brand new pads. The problem would be when both rotors and pads are below minimum. Does it make sense?
Anyway, I'll change my rotors in 10.000kms more, when they reach the minimum.
Old 10-30-2010, 12:00 PM
X3-po's Avatar
Mein Auto: 2009 X3
Yes it makes sense when both pads and rotors are below min.Manufacturers have to publish a guideline to cover their a$$(etts)
Old 10-30-2010, 12:16 PM
Well said
Old 10-31-2010, 07:04 PM
Anyway, I replaced the pads today and will replace the rotors in 10k kms more.
Old 11-01-2010, 06:11 AM
madurodave's Avatar
madurodave madurodave is offline
BMW Enthusiast!
Mein Auto: 2007 Z4+X3, 2006 530Xi
I guess I have been "lucky". I had my rotors and pads changed underwarranty due to warpage. I had the X3 in twice because 1st they did the fronts then the rears.
75k miles and no change having to pay for anything yet. However, I do a LOT of highway driving in relatively low traffic.
Madurodave
My garage: 2013 BMW 550xi GT, 2007 BMW Z4 3.0si Manual, 2006 BMW 530xi
Retired: 2007 BMW X3, 1998 BMW Z3
Member of BMWCCA!
