Old 10-21-2010, 03:26 PM
beemster's Avatar
beemster beemster is offline
In the drivers seat
Mein Auto: 540i sport dinan
Car won't start "sometimes"
2003 540 sport m package with about 40,000 miles on the clock.
Sometimes when trying to start the car, it will just click when I try the key. It might take two or three turns of the key and then it will turn over. My first thought is the starter, only because when it does turn over it starts right up, doesn't sound like the battery is straining to start it. On the other hand the battery is original. Any thoughts would be great appreciated.
Old 10-21-2010, 03:29 PM
dboy11 dboy11 is offline
Mein Auto: 99...540i
Ignition switch sounds like what happened to mine.
Its Going To Cost How Much???????
Old 10-21-2010, 03:36 PM
borderchris's Avatar
borderchris borderchris is offline
Was ist los? Der Hund!
Mein Auto: F10 528i
Most likely ignition switch, but do you have any other odd electrical gremlins with any dash stuff (visor lights, indicators or other wise)? Typically a bad ignition switch will start manifesting itself in really odd stuff before totally failing...
2012 F10 528i . Sport . Premium . Technology
2007 E92 335i . Space Grey . Premium . Sport
2006 E85 M Roadster . Alpine White . 6MT
2006 E60 550i . Sapphire Black . A5 . Sport . Premium
2003 E39 530i . Titanium Grey . 5MT . Sport . Premium
1989 E34 535i . Black . A4 . Premium . RIP
1981 E28 530 . Grey . A4 . German Specs .
1977 E21 320 . Light Blue . 4MT . German Specs .
Old 10-21-2010, 03:37 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
Dunno if these are the best links to put in the bestlinks thread, but for what it's worth, here they are:
- hhWhat to do when the lights all work, the key turns, solenoid clicks, but the engine won't start (1) (2)
If you have BETTER links for this symptom, let me know so I can add it to the bestlinks thread.
Old 10-21-2010, 03:47 PM
16valex's Avatar
16valex 16valex is offline
Mein Auto: 530I/Stick Blown
40K miles that's it! You don't drive your car enough, I think it's your battery, you need to drive it more often think of ice cream, donut or go for desert after diner, just find a reason to drive, your car hates to be left alone.
Old 10-21-2010, 03:54 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
Measure the battery voltage after the car sets overnight, and before you start it. S/b 12.5 V min. If much less, the battery is dead. The alt should put out 14+ V at 1500 RPM.
You can measure the voltage if you have the high cluster. Search this site for info on how to do that.
The ignition switch may also be faulty.
Old 10-21-2010, 04:28 PM
beemster's Avatar
In the drivers seat
I know, I know.... she doesn't like to sit.....sometimes I'll have a chance to drive it a couple of times a week and then she'll be on her own of a week or two. I am fortunate enough to own a couple of different rides. It depends on the weather and what I feel like driving.
Old 10-21-2010, 04:35 PM
beemster's Avatar
In the drivers seat
It "feels" like it could be the ignition switch to me as well. I usually leave it on a trickle charge if I don't drive it for awhile, which is sometimes the case with only 40 on the clock. I will check the voltage of the battery. Is the ignition switch a relatively easy fix and do I have to change the key? Thanks
Old 10-21-2010, 08:20 PM
sealbeach740 sealbeach740 is offline
Mein Auto: 2000 740iS, 2003 540iS
You don't have to change the key - it's not the mechanical key switch they are talking about, it's an electrical ignition switch. Not to hard to change it out, see the link below:
http://www.bimmerboard.com/forums/posts/244045
FWIW, when my ignition switch went bad, I didn't get any "clicks" when turning the key - I got nothing. I would try 2, 3, 4 times, and then it would finally start like nothing was wrong. Clicking usually means your starter is trying to engage the engine, but there isn't enough power to turn the engine over (battery not strong enough).
2000 740iS. MKIV, 16x9, DDEs controlled by Euro fog light switch, reversed steptronic +/- pattern, paddle shifters, clear corners, Basslink, iPod video with stereo audio, TV tuner, gauge rings, ///M pedals, backup camera with 'on demand' switch, quad brake lights, Dinan engine & tranny software, windows/sunroof close via remote.
2003 540iS. MKIV, 16x9, PDC, CWP, TV tuner, backup camera with 'on demand' switch, paddle shifters, windows/sunroof close via remote, iPod video & audio.
Old 10-22-2010, 07:40 AM
blubyu blubyu is offline
Mein Auto: 2001 530i Sport
FWIW, I had a very similar problem where car would start after repeated tries. Dealership fixed problem saying they replaced the ring antenna... Part of the ignition switch?
Old 10-22-2010, 08:04 AM
QSilver7's Avatar
QSilver7 QSilver7 is offline
To the OP...I would suggest unlocking your OBC and running TEST 9 (with ignition in POSITION 1)...this will give you your batterys' voltage (if you don't have a multi-meter). At 11.89 volts...your car's battery is at 0% state of charge...and if this is the original battery...and you don't drive the car much...the battery is probably done. Does it have one of those "eyes" that indicate if it is dead?
Here's a video of Cliff (visionbmw) running TEST 9 on one of his bimmers...EXCEPT he is looking at the charging system (alternator) since the engine is RUNNING...if you do this with the ignition in POSITION 1 or 2...then you will see the voltage output of the car's BATTERY:
Here's a video by BIG E on how to UNLOCK the HIGH instrument cluster:
Originally Posted by blubyu View Post
...they replaced the ring antenna... Part of the ignition switch?
No, the Ring Antenna surrounds the ignition lock cylinder...the ignition switch is on the lower LEFT side of the steering column...the ignition cylinder IS attached to the switch (by way of the steering interlock (#1 in diagram below)...but they are not the same thing.
  • #2 = ignition switch
  • #6 = ignition lock cylinder
  • #7 = ring antenna
Q {BMW CCA Member #191509}
(SOLD)
Old 10-22-2010, 02:32 PM
beemster's Avatar
In the drivers seat
Thanks for all your posts and ideas. I am working on her this weekend to find and correct the problem at my buddy's shop. I will post results later.
