E36 (1991 - 1999)
Old 05-04-2012, 11:16 AM
cj.surr's Avatar
cj.surr cj.surr is offline
some kid
Mein Auto: whiny 318
^I hear you on that. I want the same.
-CJ
Old 05-04-2012, 11:33 AM
cj.surr's Avatar
some kid
Price is fair if the floormats are included
http://newhaven.craigslist.org/cto/2996104501.html
-CJ
Old 05-04-2012, 11:43 AM
B1MM3R's Avatar
B1MM3R B1MM3R is offline
Jesse Moon Bayne
Mein Auto: e36, e46 & e70
Originally Posted by SlimKlim View Post
I don't feel strongly one way other the other about the new 7 speeds coming out. I am all about having a good overdrive though. I hate that my car spins over 3k on the interstate in 5th. I want my exact same final drive ratio (well, maybe a 3.38) with a super overdriven 6th that I can kick it into and cruise at like 1800 rpms at 65mph.
This would be nice so I could get 30 mpg vs 22 highway lol.
Jesse
"Cassie"///Mpowered 93 318is 5speed (S/C'd 95 m3 swap)
2007 X5 3.0si (Wifes)
2001 330i DD
Old 05-04-2012, 12:07 PM
SlimKlim's Avatar
SlimKlim SlimKlim is offline
Speed is Zen
Mein Auto: Bavarian Bombshell
Right?!
I wonder if an E46 330i 6 speed would bolt up to an S50?
I think 5th in my trans is 1:1, and 6th on the E46 is a .85 ratio, so it would defintely help a little, especially if I kept the 3.15 final drive.
I probably wouldn't bother trying to do it soon, since I'm trying to buy another car to daily anyway, but when I get around to motor pullin time in a few years maybe I'll drop one in.
Old 05-04-2012, 12:18 PM
Hellawut??
Mein Auto: who knows?
http://rochester.craigslist.org/cto/2995590535.html
So temptng.
-Franklyn
Old 05-04-2012, 12:20 PM
cj.surr's Avatar
some kid
Do it
-CJ
Old 05-04-2012, 12:21 PM
SlimKlim's Avatar
Speed is Zen
^ Do it, you won't.
That looks remarkably similar to my car when I bought it and presumably it's in equally sh!tty condition, but back in my day you had to pay $7k for a crappy M3.
*fixes suspenders* *mumbles about kids on my lawn*
Old 05-04-2012, 12:43 PM
B1MM3R's Avatar
Jesse Moon Bayne
Originally Posted by eight thirty View Post
dooooo eeettttt!
Jesse
2001 330i DD
Old 05-04-2012, 12:44 PM
hornhospital's Avatar
D'oh, You Kids!
When did you turn into me? Seriously.....
Quotes to live by:
Old 05-04-2012, 12:47 PM
SlimKlim's Avatar
Speed is Zen
I dunno, I've always been about 20-30 years too old for myself.
Like Chad.
Old 05-04-2012, 02:07 PM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
Back in my army days my senior instructor told me I was the youngest old guy he had ever met one day he"caught" me shaving with a straight edge.
Originally Posted by hnaz View Post
I grew up in a time when the internet was just a baby. Grammar back then versus now... holy cow. You could watch the degradation of society as the internet became more mature.
HAS KEN HAD HIS MEDS YET?
Old 05-04-2012, 02:25 PM
B1MM3R's Avatar
Jesse Moon Bayne
You are one bad *** motha******
Jesse
2001 330i DD
Old 05-04-2012, 02:44 PM
Moeman10's Avatar
Moeman10 Moeman10 is offline
hookersandblow
Send a message via AIM to Moeman10
Mein Auto: '99 M3
Right?!
It does. I can't remember the exact details of what else is needed. But the E46 6's do bolt up.
Found it. This is what's necessary.
Conversion Kit Includes:
6SP001 Transmission GS6-37BZ (1)
6SP002 Bolt - Knurled (2)
6SP003 Pivot - Nylon (Clutch Fork) (1)
6SP004 Sping - Clutch Fork (1)
6SP005 Switch - Reverse Light (1)
6SP006 Wire - Jumper (Reverse Light) (1)
6SP007 Fork - Clutch Release (1)
6SP008 Slave - Hydraulic Clutch (Alloy) (1)
6SP009 Line - Hydraulic Clutch Slave (1)
6SP010 Bolt - 12 X 1.5 X 62 (6)
6SP011 Nut - 12 X 1.5 (6)
6SP012 Drive Shaft - Propeller (C.V. Joint) Or
6SP013 Drive Shaft - Propeller (Universal Joint)
6SP014 Joint - Flex (1)
6SP015 Nut - M105W16 (6)
6SP016 Crossmember (Floor to Trans) (1)
6SP017 Bracket - Trans to Rubber Mnts (1)
6SP018 Mount - Rear Trans (2)
6SP019 Bolt - M10 X 35 X 10.9 (3)
6SP020 Nut - Hex (Plate) (2)
6SP021 Washer - Flat (2)
6SP022 Nut - Hex (2)
6SP023 Bolt - Hex with Washer (4)
6SP024 Handle - Shifter (1)
6SP025 Support - Shifter Handle (1)
6SP026 Joint - Rod (1)
6SP027 Rod - Selector (1)
6SP028 Ring - Spacer (4)
6SP029 Circlip (2)
6SP030 Pin - Dowel (1)
6SP031 Sleeve - Bearing (Ultra Oval) (2)
6SP032 Pin - Bearing (L) (1)
6SP033 Pin - Bearing (R) (1)
6SP034 Bearing - Shifter Handle (1)
6SP035 Flywheel (1) *
6SP036 Screw (8)
6SP037 Set - Clutch Repair (1) *
6SP038 Shift Knob (1)
6SP039 Bolt - Torx (2)
6SP040 Bracket (1)
6SP041 Reinforcement (1)
6SP042 Nut (2)
6SP043 Bolt - Hex (1)
6SP044 Clamp (1)
6SP045 Bolt - M8 X 45 (1)
6SP046 Washer A8.4 (1)
6SP047 Support (1)
Also, this is the transmission. It was found in z4's, 330's, and E60's
ZF model GS6-37BZ
Originally Posted by petriej View Post
You can sleep in your car, but you can't race your house!
Old 05-04-2012, 05:10 PM
FenderBender's Avatar
FenderBender FenderBender is offline
Needs Boost
Mein Auto: Red Sled
I'll be doing a 6 speed eventually. I'll use the 3.15 for a while but eventually probably go to a 2.93.
What's nice about the current Covettes is you hit 60mph in first gear, something I would love. Not feasible with V8 torque though.
I think 7 speeds will be the limit, if they do come.
Everything will be going automatic, at minimum 8 speeds there, which they already have. Look a all the "supercars" these days. All autos. Junk.
Turbo Build Here
Old 05-05-2012, 12:06 AM
Hellawut??
The newer autos can WAY outperform the manuals....
-Franklyn
Old 05-05-2012, 12:43 AM
DEATH2000's Avatar
DEATH2000 DEATH2000 is offline
Mein Auto: 1998 BMW E36 328i,
Yes, but repairing them can be more expensive.
ProjectTechnik.com - Alberta based BMW Community
See My car on Project Technik HERE!
| OE M3 Bumper | M3 Mirrors | Jim Conforti CF CAI | UUC Motorwerks Underdrive Pulleys | 18x8 ASA AR1's | Koni Sport Springs & Shocks |
Founding Member of the Canyonrot Club! #343!
Old 05-05-2012, 11:18 AM
Moeman10's Avatar
hookersandblow
Mein Auto: '99 M3
Originally Posted by DEATH2000 View Post
Yes, but repairing them will always be waaaaaaay more expensive.
ftfy
Old 05-05-2012, 02:19 PM
wag-zhp's Avatar
wag-zhp wag-zhp is offline
Mein Auto: 97 White 328iC
What does everyone think this one is really worth?
http://sfbay.craigslist.org/sby/cto/2990837175.html
When it absolutely, positively, has to be destroyed overnight! OohRaah!!!
U. S. M. C.
Semper Fidelis
Old 05-05-2012, 03:54 PM
Shigeta's Avatar
Shigeta Shigeta is offline
Old Soul
Seems to be kinda sketchy. I like to buy cars where the owner seems to know about his car and put effort in the advertisement. I would pay maybe $2100 for it if he's got records.
Big flags, for me, are the spelling, amount of information given (or omitted), and descriptions of exterior, interior, suspension, engine, any rust, etc...
Stuff like "lil rip in the seat" pushes me away really fast...
Sent from the back of my Economics class...
Old 05-05-2012, 04:30 PM
OV2310's Avatar
OV2310 OV2310 is offline
Mein Auto: 97 M3
How much do style 5s usually go for?
There was some local for 400 with tires. I didnt have the money at the time so bummer for me
D'oh, You Kids!
On a Saturday?
Wag, it's worth about a grand less than his asking.
Quotes to live by:
Old 05-05-2012, 05:59 PM
wag-zhp's Avatar
Originally Posted by hornhospital View Post
On a Saturday?
Yeah, I was thinking 1700 or 1800. He said it has tein suspension, but didn't say how long it's been on the car. Not even sure if it's worth the time to go look at it...*
Sent from my HTC Inspire, with DSC & spellcheck off!
U. S. M. C.
Semper Fidelis
Old 05-05-2012, 07:18 PM
jonesin's Avatar
The Canadian Prick.
Well, the front half of the car being replaced would account for the salvage title. I'd stay well clear on that one.
Old 05-05-2012, 08:02 PM
dunne44 dunne44 is offline
Banned
Mein Auto: 540i6
http://westernmass.craigslist.org/pts/2997707727.html
What you guys think. I want to flip this for some cash how much does a used e36 tranny cost?
Old 05-05-2012, 08:04 PM
jonesin's Avatar
The Canadian Prick.
He'd be lucky to get $2500 parting it out. I'd not consider paying more than $1-1.5k for a not drivable car.
:3
