E90/E91/E92/E93 (2006 - 2013)
Old 10-25-2010, 11:54 AM
joletzring joletzring is offline
Mein Auto: 2007 BMW 328i wagon
BMW 328i Day-Time Running Lights Question
I have a 2007 BMW 328i sports wagon with xenon headlights. I have a question about the day-time running lights on the car.
From the outside of the article, looking straight at the headlights, it is apparent to me that the day-time running lights on one side of the car are brighter than on the other side. There is no light on in the car indicating that a bulb has burned out.
Just the other day, I looked in my rear-view mirror and saw an X5 behind me. That car also had the same "issue"--one of the day-time running lamps was brighter than the other.
What could be causing this issue? Is one of the lamps about to burn out and is that why it is more dim than the other? Or is all of this just normal and the way it is supposed to be.
Thanks for any insight.
Old 10-25-2010, 12:43 PM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
Send a message via Skype™ to petriej
Perhaps they are angled differently like the headlamps. The Driver's side lamps are aimed lower than the Passenger side lamps. YesNo?
Old 10-25-2010, 01:20 PM
angle
It could be the angle. You may be right. Has anyone else noticed this?
Old 10-25-2010, 02:46 PM
AzNMpower32's Avatar
Tar Heel Faithful
Send a message via AIM to AzNMpower32
Mein Auto: X3
The left headlight unit should be aimed slightly lower, but only slightly. It should not be significantly off. Often, hitting a pothole or severe bump may cause headlight misalignment. If it is under warranty, I suggest taking it to the dealer for realignment.
A way to check is to park a medium distance (about 10-15m away) from a wall, garage door, or other flat surface so that the low-beam xenon cutoff pattern is discernable. If the two sides are significantly out of alignment, that's your cue.
Old 10-25-2010, 05:36 PM
Lights
I bet you are right and they are misaligned. Unfortunately car is not under warranty. I wonder how much they will ding for something like tins.
Old 11-01-2010, 08:58 AM
Edgy36-39's Avatar
Edgy36-39 Edgy36-39 is offline
Constantly Learning
Mein Auto: 1999 M3, 2002 M5
Close enough topic to not be thread jacking!
Hello from the M3 and E39 side of the boards. I have a related question from a friend with 2007 E93.
His driver side running light is out, and he's getting quoted $130 from dealer to replace.
How difficult is this to DIY? Anyone have first hand knowledge?
I LIKE OLDER BMWS, PLEASE HELP ME:
Fern Green 99 M3, Conforti Shark Software, Conforti CAI, Dinan Exhaust. Stamped LTWs, 235x40 square, OE Hella heads, ///M Pedal Kit, Clear Corners, OEM Rear Spoiler, CD43 stereo. MRegistry listing here.
Le Mans 2002 M5, Black/Titanium, Rogue SSK, Dinan exhaust, PSS9 coilovers, Euro rotors, iPod integration. MRegistry listing here.
Old 11-01-2010, 09:08 AM
SYN ACK SYN ACK is offline
Just a 328i
Send a message via AIM to SYN ACK
Mein Auto: 328i
I noticed this as well...does anyone know if it's something from the factory?
Fear the slushbox.
Old 11-01-2010, 09:20 AM
E92Submarine's Avatar
E92Submarine E92Submarine is offline
Officially Contaminated
Mein Auto: 2009 E92 335i
If its just the bulb then it should be pretty easy.
2009 E92 335i | 6MT | Black Sapphire | Black Dakota | Aluminum Trim | Premium | Sport | Heated Seats | PDC | iDrive | HD Radio | M-Sport Shift Knob |
Old 11-01-2010, 09:22 AM
335i Pal 335i Pal is offline
Mein Auto: 335i Sedan
I just replace my AE and my fog lights and wanted to replace the running lights but it was so much of a pain that I decided to forget about it and just do the other bulbs.
The reasoning is that the running light are placed very deep in the headlight assembly and not easy to access. I even had the inner fender wells off and still didnt have luck.
Old 11-01-2010, 09:26 AM
On the sedan it's a pain in the a$$, but on a coupe or convertible it isn't that bad.
Old 11-01-2010, 09:43 AM
Edgy36-39's Avatar
Constantly Learning
Thanks Sub, any details? And question -- so there is a difference between sedan and coupe/vert, AND a difference between early E90s and later?
Why does BMW make this so complicated huh?
Old 11-01-2010, 09:51 AM
Unfortunately that's really the extent of my knowledge. I have seen some DIY guides on E90post. I think the difference between the coupe/vert and the sedan is simply with how things are arranged.
The E90 (sedan) has two versions. The 2006-2008 models are the so called pre-LCI's. The 2009+ models are considered LCI's.
The E92 and E93 is the same way. Pre LCI is 2007-2010. LCI is 2011+
Old 11-09-2010, 01:13 PM
Edgy36-39's Avatar
Constantly Learning
Closure - I suggested my friend have the dealer do it.
I reference this thread in my latest post -- asking BMW for less complexity, more transparency: http://cparente.wordpress.com/2010/1...-transparency/
Old 11-10-2010, 07:39 AM
clayjones19 clayjones19 is offline
BimmerDallas90
Send a message via Yahoo to clayjones19
Mein Auto: bmw 328i 2007 e90
the drl bulbs are a pain in the ass to change..if that clip is not on there just right it will be a little off...took me about an hour for both lol first time...
