Welcome to Bimmerfest -- The #1 Online Community for BMW related information! Please enjoy the discussion forums below and share your experiences with the 100,000 current, new and past BMW owners. The forums are broken out by car model and into other special interest sections such as BMW European Delivery and a special forum to voice your questions to the many BMW dealers on the site to assist our members!
You are currently viewing the forum as a guest which does not give you access to all the great features at Bimmerfest including the ability to search, interact with existing members and the option to turn off contextual advertising in posts. Registration is fast, simple and absolutely free so please, join our community today! |
5 Series DIY
Knowledge Is Power! ~ The place for do-it-yourself threads on a variety of topics. Start a thread describing a particular job (oil change, cooling system overhaul, brakes, shocks and springs, etc.) or search for one you need help with! |
E39 540i front swaybar upgrade instructions - upgraded
After following my own instructions this weekend to perform the third M5 front swaybar transplant into a 540i, I updated the web page to correct a couple of errors and to make it easier to follow. Placing a piece of wood under the floor jack in order to gain another inch of lift really made a big difference when it came time to pull the old bar out and snake the new bar into place!
With two people who have done a couple of these before, it's possible to crank one out in under three hours. Plan on seven to eleven hours if you're doing it by yourself. Some of the steps really require two people and are MUCH harder with one. http://www.zeckhausen.com/howto/bmwe...eplacement.htm
Dave Zeckhausen Owner, Zeckhausen Racing 2001 540i 6-Speed StopTech 4-wheel big brake upgrade M5 3.15 Limited Slip Differential M5 Front Swaybar Dinan Stage 3 Suspension Dinan Front Strut Tower Brace Rogue Octane Short Shifter Rogue Performance Transmission Mounts European Dash Conversion CDV Deleted (of course!) Last edited by DZeckhausen; 01-12-2004 at 01:50 PM. |
Dave,
Would you consider refining that procedure a bit more with a fourth install. I have the bar and mounts ready to go and am only 40 miles or so from you. Steve D
Just so others know, I paid 5 hrs/$375 in labor to have my Eibach front+rear 540i sways installed. Sounds like Dave has it down to a science, so paying the same amount or even slightly more for his expertise would be completely worth it. |
I am off to begin my install. Hopefully I can finish before dark!!!
JB |
Old stuff is out. Now to put this stuff in!
JB |
$375 is what I would pay someone to shoot me for starting this nightmare.
Done. Holy crap... that is by far the most difficult undertaking on a car I have ever done. That includes my racecar. I cannot believe what a bear that subframe was to get back in. And then the stupid steering gear.
However, it was all worth it. Not only am I now a member of the "been there done that M5 install myself" club, but the car handles great. More about that on the main board. Oh by the way... Dave, I owe you a huge thanks for that install instruction page. I followed it step by step and it was a tremendous help!!! |
Congratulations on doing this modification! I'll bet you are going to be sore today.
Dave Zeckhausen Owner, Zeckhausen Racing 2001 540i 6-Speed StopTech 4-wheel big brake upgrade M5 3.15 Limited Slip Differential M5 Front Swaybar Dinan Stage 3 Suspension Dinan Front Strut Tower Brace Rogue Octane Short Shifter Rogue Performance Transmission Mounts European Dash Conversion CDV Deleted (of course!) |
This morning I feel like I spent the day yesterday benchpressing my car... oh yeah, I did do that
![]() Anyway,for a more productive response... 1. The removal instructions were perfect... I would not change a thing except to say that it is highly recommended that TWO people do this job. While it is not impossible for one person, it was EXTREMELY hard. 2. After getting the sway in/out, then the subframe decided to drop the four inches you mentioned. It had decided to move a little but as I was trying to put the front bolts back in, it decided to drop like described. After it dropped it seemed like everything shifted. It was inches from lining up with any holes. First I tried to line up the drivers side but that damn steering pump was so heavy that I would have to hold that up then push up on the subframe and then use my third arm to put the bolt in... Anyway, I moved to the passenger side and for some reason the subframe would not clear the pass side motor mount. After I pulled out the motor mount things went much easier and I was able to get the front pass bolt in and pivotthe subframe on that. Reinstalling the engine mount was a biatch but for me there was no way around it. Once I got that first bolt in and 3/4 way tight, I was able to pivot the subframe and get the driver front bolt in. I had to pretty much tighten the four front bolts snug before the back bolts were anywhere near being lined up. Plus since I had the car jacked up so high, I had to fully extend my arms to exert pressure on the subframe so you get tired very quick unless you have Arnold like upperbody strength (I don't). 3. I would change the order of putting the exhaust shields back in until one of the last steps. I would not have been able to get the stubby 21mm wrench on the traction strut if those were reinstalled. 4. I would emphasize having two people when turning the steering wheel to get stuff to move. Every time I turned it, the linkage would get kinked and make the steering pump impossible to move. I had to keep getting in the car and turn the wheel a little then get back under the car to see if I had turned it the correct direction and if I had turned it enough/too much. 5. I used Blue locktite on everything but the instructions did not say anything about that. 6. The exhaust shield are sharp and easy to cut yourself especially when it is 41degrees outside and your hands are numb. 7. Bolts and wrenches will observe the laws of gravity and fall straight out out there hole and pop you on the forehead as you are trying to be right under them to get a good line of sight... I have a few lumps on my forehead. Oh yeah, the rotors hang low and really hurt when you knock your head into them. 8. Getting the motor mounts to align with the subframe was not that bad, just lower the engine slowly and have your prybar in hand. 9. The only instruction I would add at the beginning would be... "Print out these instructions and hand them to your mechanic!!!" It took a lot of total time but included in that was: 1. Trip to Sears for a set of stubby wrenches, 18mm wrench (could not find mine) and a nice set of prybars. 2. Trip to FLAPS to purchase some locktite. 3. Lunch 4. Dinner 5. Lots of cleaning as can be seen in the attached photos!!! Thanks again Dave!!! JB |
Glad to hear it's done! |
JB,
I am ! You sound a bit like Dave Barry...believe he writes for the Miami Herald but I love his columns; funny as hell.I might be taking on a front sway-bar install soon with my buddy jvr530i but he thinks he can get some cheap time at his buddy's lift. However, we have I6s so we'll be somewhat venturing into semi-uncharted waters. Frankly, I think it should be easier since there is more room in the engine bay...in fact, I PRAY it's easier. I have some stuff you can apply to your chest that will encourage a third arm to grow out of it but I guess you don't really need it now, eh? ![]() Chris |
Yeah, but they don't have the cool write-up on how to do it. I tell you what, just looking under the car, I thought the front swaybar change was gonna be easy... we all know how that worked out. Oh yeah, Bentley says to remove the links and the brackets and then remove the swaybar. Maybe, just maybe the I6 guys will get lucky here.
JB |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
