pcv-diagnosis - Bimmerfest - BMW Forums
Old 10-27-2010, 04:53 PM
yellowwing7 yellowwing7 is offline
Mein Auto: 530i
pcv-diagnosis
sort of tearing into the pcv valve, control valve for emission control, or whatever the bloody thing is called and looking for the "goo" or simply relying on a decrease in mileage, how do you know if you need to replace your pcv unit?
Old 10-27-2010, 05:03 PM
wolfen wolfen is offline
Mein Auto: 97 BMW 540i
BMW has a oil separator valve or diaphram. When it fails you'll pull oil into the intake and have a huge smoke screen out the pipe. When it fails, you KNOW
Old 10-27-2010, 05:05 PM
JimLev JimLev is offline
Mein Auto: 540/6, '16 Highlander XLE
If you can measure the vacuum level in the crankcase, it should be between 3 to 4.5" of water column if I remember correctly.
If the CCV isn't working properly you could have much higher vacuum level which can suck oil out of the engine.
Most DIY guys don't have a manometer, you can make one, just google "manometer"
Get another oil cap, drill a hole in it and screw a "1/8" NPT to hose barb" fitting into the hole. Or get a big rubber stopper that will cover the oil fill hole and put the fitting in it.
Connect the hose barb to the manometer and measure the vacuum in the crankcase.
Old 10-27-2010, 05:07 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
A quick, and rather good, test is to place you palm over the oil fill hole while the engine is idling. You should feel a very slight vacuum. If it REALLY sucks on your hand, chances are good that the diaphragm in the valve has failed.
Old 10-27-2010, 05:14 PM
Fudman's Avatar
Fudman Fudman is offline
Or you can do the balloon test over the dipstick hole. If it inflates, you need to replace your CCV. Here's the DIY for the M54: http://www.bimmerfest.com/forums/sho...240&highlight=
Old 10-27-2010, 08:44 PM
Fudman,
Will a condom work?
Old 10-28-2010, 04:09 AM
Fudman's Avatar
Originally Posted by edjack View Post
Fudman,
Will a condom work?
My understanding is it must be a lubricated one.
