Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series / 4 Series > E30 (1982 - 1993)
E30 (1982 - 1993)
Old 04-21-2011, 09:39 PM
First time's Avatar
First time First time is offline
INSANELY UNPREDICTABLE!
Mein Auto: 1984 318i
Here are the pictures of whats going on right now.
Here it was after a few things were fixed. Finally outside running!
The only thing I cleaned was the Valve cover here
Old 04-21-2011, 09:42 PM
First time's Avatar
I re-painted a few pieces:
Side mirrors
Window trim and door handles
Straightened up my bumper a little and got a used iS lip from the local junkyard for $13! with all new clips from pelican
Old 04-21-2011, 09:53 PM
First time's Avatar
As mentioned before I started taking things apart to clean them and now I just cant seem to stop pulling things apart. Considering the age of the car (27 years old) and the PO poor care for the car. I am replacing every gasket/seal/and sensor that I pull off (of course if it isnt operating fine) I really will have my work cut out for me.
Here are some pictures of my current "teardown" process and the nasty condition of the engine.
WORN out hood seal
Shot with Intake manifold/PS pump/altenator and brackets off
Brand new water pump (notice how dirty the block is and rusted heater pipe)
Started cleaning the passenger side
Cleaned the hood (new insulation will be ordered)
Notice the old dirt built up on the hood
New battery and ground cable (new power cable will be ordered)
New pads and rotors all the way around (swaped to 325i rear disc) along with a complete fluid flush (also all new radiator hoses and T-stat)
Old 04-21-2011, 09:58 PM
First time's Avatar
Cracked/bad condition of the windsheild gasket (will be replaced along with the rear seal and sunroof seal)
Look at the build up of oil on the top of the oil pan
More oil built up on the side of the pan (i semi cleaned the bottom to show the difference)
Oil build up on the head (again I started cleaning some)
Oil on the Steering rack (yes that little gold you see is the clean part of the rack!)
New water pump
Pieces from the intake manifold (things will be cleaned and some stuff replaced)
Already cleaned the Valve cover
Old 04-21-2011, 10:01 PM
First time's Avatar
More oil build up around the Crank pulley
That is all the pictures I have, will post stuff up as I get to them. Thanks
Old 04-22-2011, 08:12 AM
markseven markseven is offline
an audience of One
Mein Auto: BMW M Power
Nice work!
WTB:
Minty Seat Belt Receptacles - Front
Old 04-22-2011, 12:37 PM
First time's Avatar
Thanks! It will take some time, but i will try and get on it when i can.
Sent from me, who else?
Old 04-22-2011, 04:16 PM
First time's Avatar
Well I got around to pulling the A/C compressor off and the bracket. I also was able to take off the distributor housing and replace the gasket and the distributor shaft o-ring.
I moved around to the bottom and pulled the lower half of the oil pan to start the cleaning process and was very disappointed at what I saw
This is what I was greeted with, it looks as though the oil hasnt been changed in years! And im thinking that the car either had or has a blown headgasket in the past considering how milky/pudding like the oil is. However when I drained the radiator and the block the coolant was very green and didnt have oil floating around in it. So I am debating whether or not to pull the head off and find out
What do you guys think?
Old 04-22-2011, 05:50 PM
downhiller's Avatar
livin large
if youre goin that far in, i would pull the head and replace the gasket anyway. you can also get the head resurfaced and check the cylinders walls for wear.
Old 04-22-2011, 05:54 PM
fcsteve's Avatar
fcsteve fcsteve is offline
610EUROs
Mein Auto: 90' 24v, 89' 325is
coolant in the oil doesnt mean there will be oil in the coolant. all of that milky sludge is coolant mixing with oil. id replace the hg
if you want to lead the orchestra, you must turn your back on the crowd
build: http://www.bimmerfest.com/forums/sho...d.php?t=382667
Old 04-22-2011, 06:32 PM
First time's Avatar
why not? that doesnt make sense. Usually the signs of a blown HG are oil in the coolant floating around, or white smoke from the exhaust constantly or overheating.
This is the first time I pulled the pan, When i first got the car I simply replaced the water pump put in new coolant and started it up and it never smoked. And now that I am around to tearing down the motor, when I drained all of that brand new coolant I put it from the water pump, none of it had any traces of oil. So It wouldnt appear to have a blown HG, but I think I will be pulling the head off and just replacing the HG and every other seal while Im at it. Thanks for the input guys.
Old 04-22-2011, 06:53 PM
fcsteve's Avatar
610EUROs
ive seen blown headgaskets many times. never once saw oil in the coolant. you have that backwards its coolant in the oil/smoke in the exhaust almost all of the time. 100% of my first hand expierences have been that way.
sometimes you can get condensation under the oil cap and it will cause a little milky subastance under the fill cap. as much milk as is running down your pickup is signs of a problem.
Old 04-22-2011, 07:39 PM
First time's Avatar
Hmmm, well in may experiences some of the time the gasket would be so bad that there would be oil in the radiator that i can see floating around when i opened up the cap and when i would drain the block. Not huge amounts, but more than should be there.
So I wouldnt say in my experiences that im backwards. but we all have different sightings now dont we?
So I have broke down to just pulling the motor out and doing a complete rebuild. It does have 250k miles on it, and if they have been this harsh in the past, a little refreshing wouldnt hurt it. of course if I had the extra money lying around I would just pull out the M10 and go with a S50(2) motor. But ill dream some other day.
Old 04-22-2011, 07:42 PM
an audience of One
The white smoke is from coolant getting into the combustion chamber.
WTB:
Old 04-22-2011, 08:35 PM
First time's Avatar
yes i know. LOL thanks though. HG will be ordered.....ummmm. Maybe tomorrow.
Old 04-22-2011, 08:38 PM
an audience of One
Sorry to state the obvious, but this threw me off:
WTB:
Old 04-22-2011, 08:39 PM
eieio4tn's Avatar
eieio4tn eieio4tn is offline
BMW...riceless
Mein Auto: 1987 325is
you could buy a decent m20 for less than a rebuild. much quicker...and more power. you might even dream of turbo later...
Old 04-23-2011, 12:05 AM
Kamakazi21 Kamakazi21 is offline
Cool Story, Bro.
Mein Auto: '87 325i, '68 Nova
I would just like to throw this in there. Didn't the BMW F1 cars used to run M10's with 1,000+ hp? and Group 5 cars with M10's as well?
1991 318is (Daily Driver)
1983 E21 320i (Chumper)
1968 Chevy Nova/Chevy ll (383 stroker)
Old 04-23-2011, 12:51 AM
First time's Avatar
Yes they did up until turbocharging was outlaw around 1988 or 89ish? iirc.
It was a M12 motor (based on the M10) and displaced 1.5L and in some case made around 1200+ HP.
Old 04-23-2011, 12:55 AM
First time's Avatar
Yea but then I would want to pull apart and rebuild the M20 as well because it is already out of the car and a rebuild would be very easy at that point. As mentioned before, I want to try and get this car as close to OEM as possible. It has been abused quite thoroughly from the PO and it could use some TLC. I plan on picking up another FL car soon anyway. That one can be my track whore.
Old 04-23-2011, 07:54 AM
fcsteve's Avatar
610EUROs
the ONLY piece of the f1 engine was the block . all other parts were completely different. f1 used DOHC , fully built turbo race engines. they used to run 50-60 psi and would detonated within a few laps. they were also laggy as could be.
the m10, while it shares the same block, is still nothing like the f1's motor.
f1 race engine :
Old 04-23-2011, 08:20 AM
Cool Story, Bro.
f1 race engine :
I understand that, but its still damned impressive to get 1,000+ hp out of any 4cyl.
Old 04-23-2011, 10:53 AM
First time's Avatar
f1 race engine :
i dont think any of us was expecting to make those HP levels with my M10. Come on thats laughable.
Old 04-23-2011, 10:54 AM
First time's Avatar
especially back in the early to mid 80's
Old 04-23-2011, 05:41 PM
downhiller's Avatar
livin large
you guys clearly havent read about the rally group b cars. sad.
