Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series / 4 Series > E30 (1982 - 1993)
E30 (1982 - 1993)
Old 04-23-2011, 11:00 PM
First time's Avatar
First time First time is offline
INSANELY UNPREDICTABLE!
Mein Auto: 1984 318i
What should we have read?
Sent from me, who else?
Old 04-23-2011, 11:04 PM
First time's Avatar
Well I go around to pulling apart the motor some more today. I will try and post pics up tomorrow though. Sorry, it would appear that the PO must have known about the blown HG and just kept driving it for who knows how long. When I pulled out the head bolts on at least 4 of them, there was pudding like oil just slathered all over the bolts. I havent yet pulled the head off but will do so tomorrow and show you guys.
Old 04-25-2011, 04:34 PM
First time's Avatar
Well i got the head off today, the head gasket was completely blown out on three cylinders. Upon inpection of the valvetrain and the head, it seems as thought I will be reusing the camshaft and rocker arms. I will be purchasing all new valves/valve guides/valve stem seals/valve springs/etc.. I took the head to the machine shop today to make sure that it can be resurfaced(who knows how long the PO was driving around like this) and he said it will be fine. Resurface and cleaning is only $50 so cant go wrong there. Here are some pics of the head.
Notice the black rings around the combustion chambers showing where the headgasket gave way.
Pistons appear to be in good condition, those will stay. But when i pull the block out i will inspect everything anyway.
And just a pic of the dirty block
Old 04-25-2011, 04:41 PM
First time's Avatar
I cant seem to get the rocker shafts out of the head in order to get to the valve springs. Anyone have some insight? It appears that they just slide out of the head, but not without putting up a fight. I will be getting a bently manual soon.
Old 04-25-2011, 09:04 PM
downhiller's Avatar
livin large
if i remember correctly those are pressed in. cause the only way to replace them is to drill and tap and put a threaded one in
Old 04-25-2011, 10:25 PM
First time's Avatar
So that means that I cant buy an OEM piece, it would have to be an aftermarket piece because the OEM pieces arent threaded. Am I understanding that correctly?
Old 04-25-2011, 10:46 PM
First time's Avatar
Well, It just doesnt make sense that BMW would still have the OEM rocker arm axle even though you say a new arm axle must be threaded into the head. Because I want to get to the valves, but currently cant because of the dumb rocker arm axles. Does anyone else have any experience with the M10 valve train?
Old 04-26-2011, 01:09 PM
noexceptions325's Avatar
noexceptions325 noexceptions325 is offline
East Bound And Down
Send a message via AIM to noexceptions325
Mein Auto: 325e,Lifted Jeep,240z
i would not put this much effort into an M10 engine, because after all this work you will still have Slow, unreliable, Slow car..... SLOW
buy an M50... or even an m20 and call it a day, your car will thank you
(1986 BMW325es -MSD ignition coil/ebach springs/bilstein sport shocks/Ireland Engineering sway bars/K&N air filter/"high flow" cat/dodge shadow radiator/ANSA resonator/3.46 LSD/CERAMIC brakes/Dinan chip/Shaved Head/Ported Intake manifold) = sex on wheels
Old 04-26-2011, 01:42 PM
First time's Avatar
You wouldnt put the effort, but I will. If you would have read what i have previously stated as to why i am putting this much effort into rebuilding the motor is because i am trying to get the car back to its original status. The PO didnt take care of this car at all. So while i have the motor apart to change the head gasket. I might as well take it a small step forward and just freshen the motor up completely. I just want a fully functioning engine/car again. This car will remain mostly stock (including the engine) because its really not worth buying aftermarket upgrades to TRY and increase this already anemic motors capability.
Also i stated that i will be picking up another e30 here shortly. That will be my track whore.
Old 04-26-2011, 01:44 PM
First time's Avatar
Everycar someone owns doesnt have to be fast. Take in point your jeep. Not hating just saying whats true. His car deserves a nice "going over" until i am satisfied with the results.
Old 04-26-2011, 06:48 PM
anstead610 anstead610 is offline
dream chasin'
Send a message via AIM to anstead610
Mein Auto: 24v e30 -88 toyota pickup
I have a 88 truck with like 50whp
This e30 is now being parted out. NO body panels are for sale, bumpers/fenders/hood/mirrors/valance or front turn signals. Everything else is up for grabs. Euro grills/cluster are sold, suspension/brakes/LSD/rear tails are already spoken for.
Old 04-26-2011, 06:59 PM
First time's Avatar
Exactly my point LOL!
Old 04-26-2011, 09:26 PM
First time's Avatar
Well, I ordered a bently manual today which should have been ordered before I started this rebuild. But anyway, Not much really happened today. Just stripped down the head (except for the valves which I need to get a valve spring compressor)
The stupid rocker arm axles were giving me a little trouble since they are pressed in, but nothing that my "custom" tool (along with a hammer) couldn't solve.
The "tool": A 1/2" breaker bar
And viola! all out.
And in very good condition considering the 250K miles on them
The head is very clean!
And all this will get thrown away and replaced.
Stay tuned! thanks.
Old 04-28-2011, 07:42 AM
leecrosson leecrosson is offline
Mein Auto: 1972 2002, 1987 325iS
So much M10 bashing. There are leagues of 02's out there shaking their heads at you folks. Show some respect ...
Old 04-28-2011, 08:11 AM
markseven markseven is offline
an audience of One
Mein Auto: BMW M Power
M10 in a 2002 is good. M20 in a 2002 is better. M10 in a E30 is okay. If the M10 was deserving it would have continued on
WTB:
Minty Seat Belt Receptacles - Front
Old 04-28-2011, 08:56 AM
I'm happy I have an M20 in my 3 series, I have no doubt it's a lot more fun, but I wouldn't want one in my 02. There is more to my love of these cars than power - if there wasn't I could go to just about any car dealership out there and find a new Honda with more power than either of my BMW's. It would still feel like a piece of plastic junk. On the other hand, I could go out and find a 1600 with a fraction of the pep and love it to pieces (I'm sure I'm not alone). I respect FirstTimers purist approach. Love what you got. Most of us are here because we like driving a car that still gives a solid connection to the engineering - both while driving it and working on it. Two extra cylinders doesn't change anything in that regard ... I'll take my 02 at 60 in 3rd gear over my 325 any day of the week ....
Old 04-28-2011, 09:00 AM
... And I have no choice but to say that by the logic of 'If the M10 was deserving, it would have continued on' one could say 'If the E30 was deserving, it would have continued on'. I'm sure there are plenty of folks out here who would have something to say about that.
(I'm no trying to be combative - I just love a good discussion )
Old 04-28-2011, 09:01 AM
Spinning Vinyls
Mein Auto: e39(01) e36(97)
My m20 had has a broken head bolt for five years solid runner
send from space command
01 540I
97 328is
live Thursday and Saturday night
www.ukbassradio.com
Old 04-28-2011, 09:14 AM
fcsteve's Avatar
fcsteve fcsteve is offline
610EUROs
Mein Auto: 90' 24v, 89' 325is
my disrespect for the m10 comes from personal expierence. its a crapshoot to work on and nothing is less satisfying then flooring it and barely moving. if i put work into a car or buy a car in general .. id like its motor to be able to compete with a 4 year old pushing on a razor scooter.
if you want to lead the orchestra, you must turn your back on the crowd
build: http://www.bimmerfest.com/forums/sho...d.php?t=382667
Old 04-28-2011, 09:22 AM
ouch
Old 04-28-2011, 09:35 AM
an audience of One
Like I wrote earlier, an M10 in a 2002 is good.
WTB:
Old 04-28-2011, 12:10 PM
First time's Avatar
Thanks for all the "chatter" lol
Old 04-28-2011, 05:44 PM
First time's Avatar
While true the M10 has since been stopped. It was in service for a long time. Longer than the M20. There just comes time when a motors job is done. Please dont think im a hardcore M10 fan (im very much not) but just stating some words.
Old 04-28-2011, 06:03 PM
East Bound And Down
your words are dumb... if i wanted your car to be fast i would have said drop an M60 or S52 in it... I just thought you would appreciate a decent amount of power to go with the decent handling of the car...
MY JEEP (which you tried to make fun of) Is not for going fast, it is for dealing with SNOW, Rivers, and other obstacles i encounter on a daily basis... my displacement is 4 liters and i can drive over your car with my 33" tires and 9 inches of lift
and i would put every penny i own on it having a higher top speed than your piddly M10
STOP USING WORDS and do your build... i appreciate that you are taking the time to restore your car i was just stating that I would not put that amount of work into a terrible drivetrain
Old 04-28-2011, 11:10 PM
First time's Avatar
cry somewhere else. I will build my car on my terms when i choose.
If I wanted MY car to be fast (which obviously I dont) the M10 would get thrown away, you must have difficulty reading about why I am using my time how I choose on this car.
