Old 10-30-2010, 08:01 AM
holmeng holmeng is offline
Mein Auto: 1998 528i
528i fuse diagram
Need a glovebox fuse diagram for a 1998 5281
Old 10-30-2010, 10:21 AM
edjack edjack is online now
Mein Auto: '97 540i 6 speed
Here ya go:
http://forums.bimmerforums.com/forum...1&d=1028207939
Old 01-26-2011, 11:34 AM
Stackaholic Stackaholic is offline
No0b to BMW's
Mein Auto: 90 Civic boosted, 97 528i
doenst work
Old 01-26-2011, 11:35 AM
cn90 cn90 is online now
SEARCH forum, I posted the diagram before!
Old 01-26-2011, 11:38 AM
No0b to BMW's
Do I go by the first number or the 2nd
Old 01-26-2011, 12:46 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
At this point...perhaps you should provide a bit more detail...like what are you doing and why do you need the fuse info...especially since the simple fuse diagram causes you to ponder a question.
With a better understanding of why you need the info...we can provide more detail and perhaps answer a question that you may have in the future....or even direct you to a DIY that will give you a step by step procedure.
Q {BMW CCA Member #191509}
(SOLD)
Old 01-26-2011, 06:01 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
I know NOTHING about the fuses ... (I've never replaced a single one in my 2002 525i); but I do know that Q is right on in that there are various specific 'fuse-related' tribal-knowledge issues that you might be having ...
For example (from the VERY best of E39 Links):
- Secondary air pump, troubleshooting and the famous fuse #107
- How to test the cooling system auxiliary electrical aux fan & the infamous fuse 75 (1) (2) (3) (4)
- Low oil level, the oil level sensor sends a signal to blow fuse 15, so you cannot start the car (1)
etc.
Old 01-27-2011, 09:27 AM
No0b to BMW's
i was going to try to figure out what is wrong with my wipers. as they dont work. i replaced the 2 relays under the passenger filter under the hood. the 2 fuses for the wiper system. i think its 4-2 they are good. what esle is there to check
Old 01-27-2011, 09:58 AM
pleiades pleiades is offline
Mein Auto: '99 5-spd
Here's one set, not sure how generic it is .... use at your own risk.
http://www.540i6.com/fuses.html
Some more links in this thread....
http://forums.bimmerforums.com/forum...ad.php?t=41315
And for manuals....
http://www.bmwtips.com/OwnersManuals/manuals.htm
Old 09-14-2012, 11:16 AM
alandra516 alandra516 is offline
Mein Auto: 528i
Rearwindow Heater quit working
I have a yr 2000 528I. My rear window heater quit working also the push button for the heater on the dash. I cant seem to find any fuses blown either. can anyone steer me in the right direction?
Old 09-14-2012, 12:13 PM
jygesq jygesq is offline
Mein Auto: 2015 Audi S4. BMW is gone
what is the external temperature guage showing?
if it if -40 degrees external temp sensor is bad, /that will cause malfuntion for rear window heate and heater.
Old 09-15-2012, 11:11 AM
Mein Auto: 528i
Extranl temp seems to be acurate. I live in NEB and the temp has been 50 in the am and 80 in the pm so there is no reason not to belive the guage. Any other suggestions?
Old 09-15-2012, 07:51 PM
JimLev JimLev is offline
Mein Auto: 540/6, Tribeca
There is a big fuse for the rear window at the end of the fuse block in the trunk. It's a big one, iirc it's a 40 amp fuse. It's at the tail light end of the fuse block, think its green.
2000 540/6 Slightly tweeked...everywhere
Old 09-15-2012, 09:55 PM
bluebee's Avatar
We posted a picture of every single fuse in the E39 with a description over here:
- Where to find E39 fuse boxes (1) (2) (WDS) (WDS.ru) & how to find the front passenger seat undercarpet fuse panel (1)
Old 09-16-2012, 04:18 AM
That's not the one I'm talking about.
Old 09-16-2012, 10:07 AM
QSilver7's Avatar
Alandra516...are you sure that fuse #66 (40 amp fuse in the trunk) is NOT blown? Check your car's trunk fuse index in case there's any difference between e39 models
(images previously posted & linked to above...in this thread...that leads you to the trunk areas fuses and fuse index)
(trunk fuse index...should be on back of battery compartment door)
(page from owners manual that shows the location of the trunk fuses above the battery)
(SOLD)
