Old 11-02-2010, 01:49 PM
rwrice rwrice is offline
Mein Auto: 2006 325i
Cooling System air bleed procedure
Had an issue that was cleared when a wire to the temp sensor was repaired but the troubleshooting procedure that the tech performed included bleeding the air from the system. The procedure was explained to me so I am passing it on, hope its of value.
Open the hood and remove the radiator cap
Key fob inserted, no brake pedal, press Start
Driver and Pass air temp controls all the way to max temp
Press the defrost button to turn it on
Manually adjust the fan speed to the slowest setting (not off)
then hold the gas pedal down all the way for 10 seconds.
The water pump will begin to pump water slowly at first and faster within a few seconds
The water will squirt from a very small opening just under the cap threads in the reservoir
If there was any air in the system, this will purge it and will show you that the pump is operational as well.
I had to put the cap back on after about 15 seconds as it started to splash out from the force.
This should work on any electric powered water pump cars according to the tech
Old 11-02-2010, 02:27 PM
Bcube's Avatar
Bcube Bcube is offline
Combat Commuter
Mein Auto: 2007 E93 335i
Pretty good memory. Except the cap and bleed screw are closed. Here is the procedure.
Adding coolant:
Note:
Open vent screw (1).
Fill coolant expansion tank up to lower edge of filler neck with
recommended coolant.
Observe mixture ratio.
Close bleed screw (1).
Close cap on expansion tank.
Only when venting!
Note:
Do not open the coolant expansion tank cap during the venting
procedure.
1. Connect battery charger.
2. Switch on ignition.
3. Set heater to maximum temperature and turn fan down to
lowest speed.
4. Press accelerator pedal for 10 seconds to floor. Engine
must not be started.
5. The venting procedure is started when the accelerator pedal is
pressed and takes approx. 12 minutes.(Electric coolant pump
was activated and shuts down automatically after approx.
12 minutes).
6. Then top up fill level in coolant expansion tank with 100 ml
above max (see illustration).
7. Check cooling system for leaks.
8. If venting has to be carried out again (e.g. if cooling system is
leaking), allow DME to fall completely (leave ignition key
removed for approx. 3 minutes), then repeat from Point 3.
-Brian
"Used cars are our entry cars." - Luca di Montezemolo
Old 11-16-2011, 06:30 PM
Ricardo567 Ricardo567 is offline
Mein Auto: BMW 1994 325IC
DIY: How to add & bleed a Coolant for BMW E46/E39 3 Series 2000-2006
Old 09-16-2014, 06:05 PM
Thanks Kyshhhagsa,
It feel good when someone gave me very good comment.
You have a great day.
Old 02-23-2017, 04:27 AM
528iAut 528iAut is offline
Mein Auto: 528i
Old thread, but in my expansion tank there is no floater to indicate the level of coolant. On the expansion tank, about halfway down on the tank there is a line, indicating level.
I am a bit confused, if the tank is filled to the line, about half way full, then the bleeder opening is not covered with coolant, isnt it supposed to be covered? This means that the tank must be full but when the car then hets up and the coolant expands, where can it then go if the tank is already full?
E39 528i Steptronic 1996, Comfort seats, Rear curtain, Oxford Green.
Old 02-23-2017, 04:53 AM
CALWATERBOY DUE's Avatar
CALWATERBOY DUE CALWATERBOY DUE is offline
Reregistered User
Mein Auto: 09 E93 335i somewhat mod
You speak of a 1996 model? This forum's at least 10 years later....
Old 02-23-2017, 06:35 AM
Mein Auto: 528i
Well, did not see it was not an e39 thread...but it should not matter much, or?
Was just wondering and was going to follow the procedure shown in the video.
Old 02-23-2017, 10:50 AM
Reregistered User
That's the thing: Dunno! BMW does evolve their engineering....10+ aņos leaves the door open for change....
