The X5 SAV Forum
Old 03-09-2010, 05:17 AM
ohiostate1999 ohiostate1999 is offline
Mein Auto: 2006 X5 4.4
Fog light replacement
I have a 2006 X5 4.4 E53. How do I take off the trim cover on the front bumper to get to the bulb??? I feel like if I pull it, its going to break. Please help???
Old 10-23-2010, 05:15 PM
Tom Reyes Tom Reyes is offline
Mein Auto: X5
I have the same issue. I just replaced my front brake pads and I did some looking around
before I put the wheel back on. It looks like it may be accessible if you remove the wheel-well liner. It's plastic, held on w/ sheet metal screws. The light is not that much but the dealer wants $350 or so. I'll be watching your post to see if you get any info from a real expert. Good Luck, Go Bucks
Old 10-24-2010, 07:46 AM
2000X5 2000X5 is offline
Mein Auto: X5
Take out the headlights and you should be able to sccess the foglight bulb.
Old 11-02-2010, 07:46 PM
m5james's Avatar
m5james m5james is offline
Send a message via AIM to m5james Send a message via MSN to m5james Send a message via Yahoo to m5james
Mein Auto: 98 740iL - Tweaked a bit
It pops off, just pull harder. Look on www.realoem.com if you want to see what the foglight dressing looks like removed from the vehicle.
640hp 10 X5///M, Alpine White/Sakhir Orange - Gutted cats, muffler delete, Eurocharged tune
325hp 98 740iL, black/black - Eatin 540's & $hittin 318's
PERFORMANCE:///M5 6spd swap, Iron sleeves, L/W Teflon coated pistons, 3 angle valvejob, P&P head, cams, electric fan, CF intake tube w/aluminum heatshield, Magnaflow 14816'd
INTERIOR:
Hardwired V1 above rearview, 12" RE Audio DVC sub, MTX 81000D, silver trim, 5% tint
EXTERIOR:19" Beyern Mesh staggered, Shadowline kidneys, Axxis pads
Old 11-03-2010, 04:07 PM
Areyoudreaming Areyoudreaming is offline
Mein Auto: 2001 X5
Pretty easy to get out
Once the plastic cover is popped off you can take the screw out and then lift the housing up and pull out. It has a snap in type fitting so you can't pull it straight out.
The bulb is $4.00 at checkers most auto parts stores. It took me about 5 min to do both fog lights. Do them together as the other one is about to go.
Old 11-04-2010, 11:49 AM
Jap Scrap Jap Scrap is offline
Mein Auto: X5
SORRY FOR TH HI JACK but where can the spotlight bulbs be bought than match the low beams blue in colour
Old 11-04-2010, 11:51 AM
m5james's Avatar
Most likely your lowbeams are HID's vs a halogen you can get at any autoparts store.
INTERIOR:
