BMW Diesel Owners / Enthusiasts
Do you own a diesel powered BMW? Maybe a 335d or a BMW x35d? Come and talk about what makes your car great! |
#51
I believe the X5 tool kit has the special adapter/wrench, but mine simply screws-off by hand and didn't require to special wrench..
#53
Did you have fuel filter changed at the second oil service as well?
335d produced after 3/09 should have diesel fuel filter changed every 2nd oil change according to SIB000408 updated July 2009, just wonder if that happened Thanks
T ![]() 2010 335d e90 Flickr300, LCAD, ZPP, ZSP, 2XA, 302, 465, 494, 4B9, 609, 655, 677, 6FL, 6NF |
#54
Sent from my iPhone using BimmerApp
Colonel (Ret) US Army / Hagerstown, MD 2010 Z4 s30i Alpine White/Beige PP/SP/CWP/6MT/CA/NAV/ipod/USB ED 1-29-10/Redelivery 3-8-10 (weekend car) 2013 Audi A6 Quattro (daily driver) 2011 335d (Ret) 2009 335i vert (Ret) 2007 335i vert (Ret) 2000 740iL (Ret) 1998 328iC (Ret) 1990 535i (Ret) 1988 635CSi (Ret) |
#55
In my case they didnt change diesel fuel filter after 2nd oil change. I enquired and talked around but didnt get definitive answer. If any of you gets it or has info on when it will be changed or cleaned please post it here
#56
I'll have to look for the work order and verify that. Thanks. |
#57
Is there a way to get a copy of that SIB? I asked specifically about fuel filters during my second change and they had no answer as to when it is ever done.
--Aaron |
#58
And as luck would have it, my car was made before that date. So my mystery of fuel filters will probably continue.
--Aaron |
#59
Attached SIB, I'm gonna remove it shortly, don't want to get in trouble... also there could be newer version out there..... I just realized Service Warranty Booklet for 2010 model on page 9 states the fuel filter needs to be replaced every 2 oil change. Any owner should have that document, if not in hard copy, soft copy can be downloaded from bmw website....
T ![]() 2010 335d e90 Flickr300, LCAD, ZPP, ZSP, 2XA, 302, 465, 494, 4B9, 609, 655, 677, 6FL, 6NF Last edited by tlak77; 05-11-2011 at 05:16 AM. |
#60
This is interesting, from that pdf:
"Use of B10 or higher biodiesel, kerosene, or mixing with small amounts of gasoline is not permitted!" |
#61
--Aaron |
#62
I called up BMW customer relations again because I just recently had my 2nd scheduled oil change (~20400mi) and my dealer mentioned that the fuel filter is changed every 3rd scheduled oil change -My warranty booklet says every 2nd oil change (pg9 my2011 X5d).
BMW customer relations said they have documented my complaint and will go in review process. I told them I have not received an official document or addendum describing the changes to the BMW Maintenance Program, I told them that This was what I agreed to when I purchased my vehicle and you are now changing those terms of the contract. They also cannot provide me any current documentation of the changes at the time I called them. They did call the dealer to verify why they did not perform the service -the dealer mentioned that they are going by my key-fob information through the computer and it tells them what is due. My air filter was not changed either.
#63
All of this is making me wonder where the heck my warranty booklet is. Will have to go searching for it this weekend.
--Aaron |
#64
Chip4, you're in AZ? Phoenix area? If you don't mind saying, which dealer are you working with: Phoenix, Chandler, or Scottsdale?
#65
but they don't fallow their own guidance in this case.
#66
And from page 4, ULSD with minimum 51 cetane. I know I don't have 51 cetane fuel available anywhere near me. The vast majority of us in the US are violoating that BMW fuel standard.
#67
I thought that was the case for a long time. But if you really go digging you will find elsewhere that BMW says you can run a lower cetane and that the car adjusts for it. I do not have the page on their website bookmarked that states that but it is out there if anyone wants to go searching for it.
--Aaron |
#68
People often talk about biodiesel and cetane. Don't forget that USA fuel standard is also below BMW/Bosch spec wrt lubricity.
#70
I've twice encountered the warning between oil changes. 1000 miles is plenty of advanced notice. Both times my dealer topped me off at no charge. They eat this cost, which is minor labor doubled as training, plus near nothing for parts. The second time I drove away as soon as they were done topping off DEF. I was told the warning would go away in approx 8 miles and to call if it did not. It went away in 9 miles give or take 1/2 mile. Apparently the normal procedure is for them to drive the car for 8-9 miles so that it is returned to the customer with no warning light. I thought that was unnecessary. |
#71
#72
'11 335d M-sport/Le Mans/Oyster/Glacier/Titanium angel eyes Lifetime avg fuel economy: @27,000 miles, 35 mph, 28.0 mpg Pollution is bad, but carbon isn't pollution! |
#73
This is quite a nice document. Thanks for the info. It will take a couple days to digest all the details.
#74
Hey guys & gals I know this is an old post and don't know if anyone is still following it but I'm new to owning a 335d. I haven't even got the car tagged yet and the low def light is on. My question is simple I know how to via other forms what to use and how to refill both def tanks. But how do I pop off the circular cover? Do I push it in or get something thin like a flat head and pull it out? I don't want to break it off and drive around with a hole on the side of my car :/
#75
Push on it with your hand.
--Aaron |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
