Old 11-05-2010, 05:44 PM
beanerbimmer beanerbimmer is offline
Mein Auto: Bmw 745li
Transmission sleeve leaking??
Hi, I am new to the forum. I did a search to see if anyone has done a transmission sleeve replacement for a 05 745li with no results. The service advisor at the dealership said it was a transmission sleeve that was leaking. I am looking to replace it my self if possible or maybe get a idea of how much this repair would cost. Any info is appreciated. Thanks
Old 11-06-2010, 02:12 PM
racerock racerock is offline
Mein Auto: 745Li 330i K1200LT TL ...
Yep, it is on here, search better... You have to drop the pan. If you are not mechanically inclined and have a good bit of experience around cars - have someone do it...
Old 11-07-2010, 04:32 PM
jbhoot jbhoot is offline
Mein Auto: 2006 750Li
It's not so difficult to do - I did mine (2006 750LI). This link will help you
http://www.zftranspart.com/images/custom/mecha.pdf
As racerock mentions, you have to drop the pan - in which case you may as well change it. The filter is part of the pan. I would also change the transmission fluid. A couple of suggestions/recommendations
1. Make sure you remove/loosen the filler plug first. Otherwise, if you won't be able to get the transmission fluid back in - if you can't open it - you don't want to be stuck with the no transmission fluid.
2. Put some oil on the sealing sleeve - it's a real pain to get back in.
Here is BMW's TIS
http://www.bimmerfest.com/forums/att...5&d=1273726276
Old 11-08-2010, 03:34 PM
Thanks for all your suggestions guys. I think I'm going to take on the challenge myself. I went to the dealership and talked to the mechanic who looked at my car and what do you know! It's a buddy of mine I used to work with at a different dealership. He told me if I need help he can help. So that makes me feel alot more comfortable (just in case). The links are awesome jbhoot! Thanks again
Old 11-08-2010, 05:07 PM
revrun revrun is offline
Mein Auto: 2004 745i
I just did this repair with the help of a buddy. One thing that didn't sufficiently arise in searches and DIY is the fact that improperly installing the wiring connector can cause damage to the mechatronic. There is a notch in the harness at about 5:00. This is an alignment notch that makes sure you don't damage the pins. A damaged pin may require a new mechatronic. Good luck.
Old 11-08-2010, 08:32 PM
What I did there is look very closely at the markings on the outside of the original one, and used sharpie to mark on the body where the mold mark lines up...
There are three mold marks and it you rotate your new one, and look closely at the numbers/lettering, you will see that one lines up with about 5 - 6 oclock on the outside. On the inside, there is a notch and I thought it ended up at 6, but it could have been 5.
Thing is that there is no way to look in there like the pix. Also - there is an alignment pin on the outside of the sleeve as well. It is small.
Lastly - use o-ring grease on the sleeve o-rings.
Old 11-09-2010, 08:35 AM
Good luck - let us know how it goes.
Old 11-25-2010, 03:56 PM
Everything went smooth guys. I really appreciate all your help/suggestions, everything came in handy. Thanks again. No more trans leak YAY!! Now I think I'm leaking oil from my oil filter seal
Old 01-09-2011, 05:51 AM
Koenvw Koenvw is offline
Mein Auto: 630i convertible
Hello,
I have olso a oil leak on that plug on the megatronic...
So I don't need a new megatronic? Only new seals?
Greetings,
Koen Vw
BMW 630i convertible 2006 | Stratus Gray
Opel Speedster #2981 | Lotus Titanium Silver
Susuki swift sport (for the wife)
Audi convertible 2.6 V6
Old 01-09-2011, 07:33 PM
mbz1 mbz1 is offline
Mein Auto: bmw e66
I just did my sleeve and pan on my 2004 645ci WHAT A B.. no room to get the old sleeve out and in.. fixed all the leaks as far as i can tell
Old 01-09-2011, 08:22 PM
Originally Posted by Koenvw View Post
Hello,
So I don't neet a new megatronic? Only new seals?
If it's just a oil leak. Then that's right you just need a new sealing sleeve. No need for a new Mechantronics.
Old 01-10-2011, 09:31 PM
JimGarrett JimGarrett is offline
Mein Auto: 745li
Just had mine done at a cost of $500
Old 01-11-2011, 06:42 AM
I buy the sleave yesterday, for about 17 euro.
The pan I didn't buy, it was 170 euro... So I only take the rubber gasket for the pan, this is leaking to I gues, because I have a lot of oil leaking.
Greetings,
Koen Vw
Old 01-12-2011, 02:44 AM
If the pan is leaking, can you see it verry wel that it is the pan?
Because it is expansive I didn't buy it, I don't see damage to it... So it must be the sleave and the gasket of the pan...
Greetings,
Koen Vw
Old 01-12-2011, 08:38 AM
The pan also contains the filter. If I were you, I would also change the pan as well. You have to take it off anyway.
Old 01-12-2011, 01:46 PM
Mein Auto: bmw e66
That is what i did in my car changed the pan as well and added new fluid
Old 01-13-2011, 12:14 AM
Hello,
Olso in the plastic pan? I don't think it has a filter in it?
Greetings,
Koen Vw
Old 01-13-2011, 03:47 AM
t_clealy t_clealy is offline
'' Blue Pill Tester ''
Mein Auto: 05 BMW 745Li
Wow...It seems like almost everyone having to do the dang sleeve. I knew mine was seeping a little from there, so I used the brake cleaner to wash it off and one day last week, I brought it to AAMCO. They checked, cleaned and tightened all the pan bolts and seems to be ok now. Even after I first initially cleaned offf around the sleeve and later, I dodn't see any more leaks. Maybe no more in the tranny ? lol
THE ONLY STUPID QUESTION,
IS THE QUESTION NEVER ASKED
Beautiful car is hard findBeautiful girls are just around the corner.
Old 01-13-2011, 09:09 AM
Hello,
The plastic pan definitely has the filter in it. Here is a picture.
http://www.zftranspart.com/index.php...id=10&parent=6
Old 04-19-2011, 05:56 PM
ZoomnNowBeemn ZoomnNowBeemn is offline
Send a message via Yahoo to ZoomnNowBeemn
Got Lucky with mechatronics sleeve repair
Took my 2006 750 Li in for its annual service. Was thinking about asking them to change tranny fluid since I was at 50K miles but decided to put it off. They called me and told me the mechatronics sleeve was leaking and it was fully covered under my aftermarket warranty . I know the BMW instruction for this repair has them save the fluid drained for refill after the repair - however it appears they did a refill with fresh fluid since they billed the warranty company for the pan gasket, drain plug and Qty of 1 - BMW 83-22-0-142-516 20L which is the 20L container of tranny fluid. So it looks like I got my tranny fluid changed after all. Sometimes you get lucky!
Old 04-19-2011, 08:24 PM
USALEXUSBMW750's Avatar
USALEXUSBMW750 USALEXUSBMW750 is offline
Little Odessa
Mein Auto: bmw
Thats why BMW claim there trans fluid lifetime
Old 04-20-2011, 07:58 AM
MOPAULY's Avatar
MOPAULY MOPAULY is offline
Mein Auto: Many things
See my other thread for DIY trans sevice - or go to www.thectsc.com
Old 04-12-2013, 01:53 PM
pmpn8ez's Avatar
pmpn8ez pmpn8ez is offline
Mein Auto: 04 BMW 745Li E66
Where is the sleeve located?
2004 BMW 745Li e66
22" Beyern Mesh
Eibach Springs
Spacers 20mm Front 30mm Rear
Akebono Brake Pads
JL Audio 500/1 Amp
2 Type R 10" Subwoofers
Old 08-14-2014, 11:21 PM
springwater springwater is offline
Mein Auto: Gremlin
What he said.
Old 08-15-2014, 07:13 AM
A B Able Truck's Avatar
A B Able Truck A B Able Truck is offline
Mein Auto: 2006 550I (N62TU) V8
Originally Posted by springwater View Post
what he said.
The early bird may get the worm, but the second mouse gets the cheese.
