The X5 SAV Forum
Old 11-09-2010, 10:26 AM
stigst3r's Avatar
stigst3r stigst3r is offline
Mein Auto: e39
2001 e53, 3.0 climate control does not function
Hi Fellas,
i been trying to figure out why this X5 that im with the climate control does not work.
before it failed it seemed like the blower motor would turn on by it self from time to time. i have replaced the final stage resistor thinking that might fix it. but still no heat in the car =\
any suggestions how to fix this?
RIP: 1998 540i sport 6spd | daily: 1999 528 m-sport 5spd
Old 11-09-2010, 02:45 PM
Jetblackstreak Jetblackstreak is offline
Mein Auto: 2001 X5, 1996 328is
when you say no heat you mean no air flow at all? Are there any other symptoms/issues with the vehicle?
Old 11-10-2010, 11:30 AM
stigst3r's Avatar
Mein Auto: e39
yes, no heat, no ac, the blower that should blow air into the cabin does not work at all. the car also has a oil leak somewhere i been trying to trouble shoot that as well, on top of that before there use to be an after market alarm and sound system on that car that looked like it was wired up by kids, there was a good amount of exposed wires danging around behind the panels and im sure some of the wires might have been shorting out. also the battery cracked/exploded with acid in the trunk taking out the head unit radio module.
any suggestions how to get this to work again ?
