E46 (1999 - 2006)
Old 11-09-2010, 09:56 AM
wyt168 wyt168 is offline
Mein Auto: 325, X5
Question Steering Wheel Shakes When Braking
The steering wheel of my '02 325i, 125k mi) would shake when I brake. It started a few weeks ago. And it shakes more violently the harder the braking is. My guess is the control arm bushings?! Or the rotors? Not too sure but this may be obvious to any trained mechanic or anybody who is (auto) mechanically inclined. Any suggestion as to what component(s) may be at fault here? I just want to get an idea of what could be wrong, and more importantly, a ball park figure of what it might cost to get it (them) fixed? The car is 8 yr old and got 125k under its belt. So I don't know whether it's worth it to fix the thing.
Thanks,
Old 11-09-2010, 10:23 AM
Fast Bob's Avatar
Fast Bob Fast Bob is online now
Keeping it surreal
Could be any or all of the below:
CABs
Tie Rod Ends
Ball Joints
Pad deposits built up on rotors (bed your brakes to eliminate this possibility)
See here: http://www.zeckhausen.com/bedding_in_brakes.htm
The road goes ever onward....
(R.I.P. Jever)
Old 11-09-2010, 10:51 AM
Mein Auto: 325, X5
CABs
Tie Rod Ends
Ball Joints
Are CABs Control Arm Bearings?
Somebody mentioned it (control arm) in another thread.
Any ball park figure as to how much it would cost to fix any of the components you mentioned if I bring it in?
Just want to have a rough idea before I bring it in.
Thanks,
Old 11-09-2010, 11:25 AM
Fast Bob's Avatar
Keeping it surreal
Thanks,
Control arm BUSHINGS
Depends on what you mean by "bring it in"....dealer or indie ?
(R.I.P. Jever)
Old 11-09-2010, 11:49 AM
SJBimmer's Avatar
SJBimmer SJBimmer is offline
Living Life At The Beach
Mein Auto: 2004 325 Convertible
Classic symptoms of control arm bushings shot, although you may need the other parts Bob mentioned as well. Should be about $400 at indie or $600+ at dealer. An easy DIY although I had mine done for around $300 at indie. YMMV
Old 11-09-2010, 04:04 PM
jcjdavis1's Avatar
jcjdavis1 jcjdavis1 is offline
Mein Auto: E46 1999 323i auto
Hi. I would have the front wheels off and check your rotors and pads to see what condition they are in, cheapest thing to start on and easy diy. Jim
The older I get the wrong bit gets stiff!!
Old 11-09-2010, 05:54 PM
aleks's Avatar
aleks aleks is offline
Mein Auto: 2004 330xi
As someone who's having the same issue and about to DIY, I can tell you most likely your CABs. Take a peek under your car behind the front tires and you'll see the bushings bolted onto the subframe with the control arm (L-shaped) coming out and curving inwards and then out to the wheel. Have a buddy grab your tire and wiggle it (it'll take some force) in-out and you will most likely see the arm move inside the bushing. THe movement shouldn't happen if the bushings are in good shape.
<(OO) ||| ||| (OO)> 2004 330xi ZPP Titanium Silver
Old 11-09-2010, 06:01 PM
Fast Bob's Avatar
Keeping it surreal
Or, another "dynamic" test is to have a friend drive 15 or 20 mph while you stand on the curb, and just before they get to your position, have them nail the brake pedal while you watch the front wheel....chances are, you`ll see it move back in the wheel well a couple of inches as the bushings deflect....a sure sign of bad bushings.
(R.I.P. Jever)
Old 11-09-2010, 06:32 PM
mi5t mi5t is offline
Detroit's Finest!
Send a message via AIM to mi5t
Mein Auto: 2001 Bmw 325i
i have the same problem and do you think it is the bushings?
Old 11-09-2010, 09:50 PM
Mein Auto: 325, X5
Thank you all for the feedback.
Now it looks like it's most likely bad CABs (Control Arm Bushings), if that's not the only thing.
I found a YouTube video that describes how to detect bad CABs, exactly as Fast Bob described in his posting.
There is even a video that describes how to replace them.
@aleks: you might want to check the video out since you are going to DIY.
The comments there mentioned that you will need a 4+ton press to push the old bushings out or press the new ones in. I don't know whether that is true or not. You might want to check it out first before making the plunge to DIY.
I will probably shell out the $400-$600 to have it done at a shop. Hopefully that's the only thing that needs to be replaced.
Old 11-10-2010, 05:17 AM
MicahO's Avatar
MicahO MicahO is offline
In my own cars again
Mein Auto: 330i ZHP
You can buy CABs from many sources already pressed into the lollipops. They cost another $50 per set that way, but it's definitely worth the labor that is saved.
--Micah O'C
CCA 193374
'88 M5, Bilstein Sports/ST Springs, staggered BBS RS, Euro conversion
'92 M5 Touring - BL01001 - first M5 Touring ever built
2017 M2 V887285 - Mineral Grey, 6MT
'04 330i ZHP, Jet Black 6spd, hot seats, LightWerkz TFX-Xenon, Bilstein PSS10
UUC Strut/SwayBarbarians, PowerFlex CAB/TAB, Performance Gearing 3.38 LSD
Old 11-10-2010, 05:57 AM
heztheone heztheone is offline
Mein Auto: ///M
if the car is shaking only around 55 mph or 75 mph, it could simply be ur wheels need alignment ...
Old 11-10-2010, 07:46 AM
Fast Bob's Avatar
Keeping it surreal
Or pad deposits on the rotors....re-bedding the brakes *is free*, and is a good place to start.
(R.I.P. Jever)
Old 11-10-2010, 07:50 AM
aleks's Avatar
I'm having a local auto shop press the bushings in. They'll do it for about $35.
Thanks for the video links. I'll take a look when I get home (YouTube is blocked at work )
brake, steering wheel shake
