Old 11-09-2010, 12:46 PM
Nube1kenobi's Avatar
Nube1kenobi Nube1kenobi is offline
U of Dawgs
Mein Auto: 08 535iA Spt/11 X5 35i
Question 2011 nav dvd
Got my postcard from BMW regarding the new DVD. Has anyone tried it yet? Your thoughts?
Nube1Kenobi
2011 X5 35i Sport Activity|Plat Gray/Beige/Dk Poplar|Conv Pkg|Cold WX Pkg|Tech Pkg|Prem Sound|Comfort Seats|Hitch|
2008 535i Mon Blue/Dakota Blk/Dk Poplar|Sports Pkg|Prem Pkg|Cold WX Pkg|Nav|RTTI|PDC|L7|HD|I-Pod/USB|PWR Rr shade|Sports Auto - paddles|Active Stg|Comfort Access|F/D R/seats|Rr DMS Airbags|Adaptive Xenons
Do not argue with an idiot else he lowers you to his level and beat you down with experience..
Old 11-10-2010, 04:40 PM
HokieXDriver HokieXDriver is offline
Mein Auto: 2013 BMW 335i M Sport RWD
I'm not sure if it is the same - I have the 2010 HDD navigation system. I did ask for the map update. It has noticeably better coverage in Northern Virginia. Many roads that were just plain missing from last year's maps are there now.
As I said, this is the HDD version, so not sure if the DVD gets the same updates.
Old 11-10-2010, 06:21 PM
U of Dawgs
Thanks... I got the 2009.1 Pro DVD but I want to see what other people think about the 2011.1 Pro DVD. I do not want to buy it and find out later that it has issues like some 2010's.
Nube1Kenobi
Old 11-10-2010, 06:55 PM
Munich77 Munich77 is offline
Mein Auto: 2014 E550 4matic
I have been looking at one of the aftermarket ones where the map has been modified to also list speed traps and red light cameras (see http://www.bmwnavigationmaps.com/index.html) I am kind of leary to go the non-OEM route so.
Old 11-10-2010, 07:41 PM
U of Dawgs
Police speed traps - this is exactly the feature I am most interested in and want others' opinion. Not that I speed a lot, mind you.
At $199, the cost is little prohibitive but compared with a traffic ticket...
Nube1Kenobi
Old 11-10-2010, 08:15 PM
Ok2Drive Ok2Drive is offline
Mein Auto: '08 528
Man i'm still stuck with a 2007 disk...
I also have a side question if any of you guys can answer it. Is it normal for the dvd slot to be in use, I mean mine is making noises so I'm assuming its spining the dvd, without the key any where near the car? I actually took out my nav dvd without turning on the car. Kind of wierd I guess since I expect most of the electronics to be turned off. I hope its not running 24/7...
Old 11-10-2010, 08:42 PM
U of Dawgs
Mine spins as soon as I open the door... I figure that is a normal boot up process. The computer checks the peripherals for proper operation. If you are not getting errors, I would think you are fine...
Nube1Kenobi
Old 11-10-2010, 08:50 PM
0xSe7en32 0xSe7en32 is offline
Mein Auto: BMW528xi
Got mine from this site, worked like a charm.
Old 11-10-2010, 09:23 PM
Mein Auto: '08 528
Ohh alright, thanks. Guess its normal then.
Old 11-11-2010, 06:28 AM
StaticPrime's Avatar
StaticPrime StaticPrime is offline
Mein Auto: 2008 528i
I'm weary of that site. Is it the actual DVD from BMW? For that price, looks like no.
If you only knew the power of a BMW!
Old 11-11-2010, 10:41 PM
U of Dawgs
Did the real time traffic info and speed traps warning work normally?
Nube1Kenobi
Old 11-12-2010, 09:21 AM
Robert A Robert A is offline
Mein Auto: BMW 535d
Mine does it too, and the dealer says it's normal. I hear it even when the car is fully off while the key is in the ignition.
Robert A
BMWCCA Member
Current
2014 535d, M Sport, Space Gray/Mocha Nappa
Prior
2007 530i, White/Black, 6MT
2001 530i, Orient Blue/Beige, 5MT
1994 325is, White/Black 5MT
1984 325e, White/Black 5MT
1983 318i, Delphin/Beige 4MT
Old 11-12-2010, 07:07 PM
Mein Auto: BMW528xi
No, it's a copy disk. I believe its called "backup" disk.
I'm in Toronto. Not sure if traffic info works here. What should I take note so I would know if traffic info is working or not?
As for the speed trap, I can see that there are blue "stars" in some intersections. I assume these are the speed traps?
Old 11-12-2010, 07:13 PM
U of Dawgs
Does it warn you of traffic congestion or accidents ahead and suggests a detour or alternative routes?
Nube1Kenobi
Old 11-12-2010, 07:25 PM
Mein Auto: BMW528xi
Haven't used it extensively yet. I will post it here if it warns me of traffic congestion.
Old 12-16-2010, 01:03 PM
legend700's Avatar
legend700 legend700 is offline
Mein Auto: 2008 535i
I just installed disc 1 of the 2011 Version. It is part No. 65 90 2 199 843 Professional and OEM through eBay. Neither The Red Light & Speed Cameras nor the Police Speed Traps show up as POIs in iDrive as advertised. I figured maybe I need to also initialize disc 2 to get that working, but both discs seem to be independent of each other. I could not just switch between both discs, but after inserting a disc you have to shut down the system, wait at least 5 minutes and re-start. Can't imagine what a PITA that must be navigating in most Mid-Western states. I am not selling my old 2009.1 Version yet.
The 2011 discs did not come with instructions, so maybe I am doing something wrong.
2008 535i Monaco Blue
PP, SP, SAT w/paddles, ARS, CA, L7,
NAV, PDC, Heated F Seats, SIRIUS,
iPod+Aux, Bamboo Anthracite Trim,
Gray Dakota Leather
Old 12-16-2010, 05:24 PM
You need a software update. These features are only available on the latest software at your dealership. The NAV DVD contains the locations of these, but your Nav software is old and does not contain the correct software to use the speed trap locations. The upgrade I think might cost you a couple hundred dollars. Not sure exactly on the price. Since I pretty much know the speed traps where I drive (and I don't usually travel outside of my normal travel areas), I have yet to justify the update. But if I do some distance traveling, I probably will then.
Old 12-16-2010, 07:43 PM
mancho mancho is offline
Black Beastie
Send a message via AIM to mancho
Mein Auto: 2008 550i DINAN
Originally Posted by AntDX316 View Post
thepiratebay.org/torrent/6038074/BMW_Nav
it wont let me in piratebay... probably its down
2010 is on usenet...
Sent from my DROIDX using BimmerApp
1980 320i | 1989 735il | 1995 740il | 2001 740il | Current 2008 550i - No Texas comfort, all brutal HP
Old 12-17-2010, 12:18 PM
legend700's Avatar
Unless the software upgrade contains other improvements as well I will not have it done just for the speed trap stuff. Just installed Trapster on my Hero smart phone and will give that a try.
Gray Dakota Leather
Old 12-17-2010, 02:55 PM
Abjane10 Abjane10 is offline
Mein Auto: 535i
Nav Questions
I bought the 2010 535i and I guess the maps on the Nav are 2009 (when the car was built). I have couple of questions
1) Does the dealer update the maps based on which year they sell the car?
2) My nav only alerts me with freeway names, for most local streets or intersections it doesn't take the names. For ex: it would announce 'Now turn right' or ' Right turn in 700ft' or so. It never takes the street name for ex: 'Turn right on Saratoga Ave' or some thing similar.
3) Are they supposed to give me a DVD for the Nav ver I have pre-loaded on the car?
Old 12-17-2010, 08:17 PM
legend700's Avatar
This from the guy I bought the 2011 discs from:"OEM BMW navigation discs DO NOT contain red light camera data. Those are only available to those who burn the data onto the discs themselves."
Gray Dakota Leather
Old 12-19-2010, 07:18 PM
repoman75 repoman75 is offline
Mein Auto: 2008 535 xi
I bought the 2011 version here for my 2008 535xi.
The police traps show up, as do the red light cameras. However, I live in a house that's 5 years old (in a new development) and there are about 14 houses on my street - the disc still only shows one (and it isn't mine). Little annoying.
But works fine.
Old 12-28-2010, 07:20 AM
apline550 apline550 is offline
Mein Auto: 550 i
From what i have read this happens because of radio readiness. The iDrive system turns on in advance when a keyfob is close or the doors are unlocked. When locked, as long as your bluetooth phone is disconnected/logged off, the system will power down.
Old 12-28-2010, 08:05 AM
nsoltz nsoltz is offline
Mein Auto: 2010 535XiT
I am very discomforted with a discussion of pirated software. I wonder how many participants here would like reading procedures and sources for stealing your intellectual property.
Old 12-28-2010, 08:16 AM
Ohio55 Ohio55 is offline
Mein Auto: 2008 550i sport
How do you like the rest of the new disc vs. your old one? Are the graphics the same or did you notice any improvement? I am interested if there are improvements beyond the street updates.
____________________
2008 550i Sport/Carbon Blk/Blk
