Which Valve Cover Gasket Kit for 2002 M Roadster (S54)??? - Bimmerfest - BMW Forums
Old 03-17-2016, 08:08 PM
Caribmon71 Caribmon71 is offline
Mein Auto: 2002 BMW M Roadster
Can anyone make a good recommendation on a valve cover gasket kit for a 2002 M Roadster (S54)? There's a small leak at the rear, so since I'm replacing the gasket, I'd like to know if there is anything else I should replace/address while I'm doing this job. Does anyone know of a quality kit? I know I'll need replacement bolts too, but I'm wondering if I should address anything else. The car has 42,000 miles. Spark plugs? Any other gaskets or seals?
Thanks in advance!
Old 03-18-2016, 07:47 AM
JonM's Avatar
JonM JonM is offline
Moderator
Mein Auto: 01 Mc, 08 M3, Motorrad x2
I would just buy OEM BMW parts.
http://www.realoem.com/bmw/enUS/show...diagId=11_6254
How long have you owned the car and do you know it's history? The spark plugs should have been changed at 25-30K miles and you won't need to replace them, and a valve adjustment should have been done. To replace the valve cover gasket, I would use:
11127832034 QTY 1
11127831271 QTY 1
11127830972 QTY 13
11121437395 QTY 2
07119963129 QTY 2
But, you also need some sealant. The correct sealant is:
https://www.ecstuning.com/b-genuine-...9/07589062376/
You will need it in the rear as the 4 corners of the half-moons in the gasket and also at the front where the casting has seams.
Jon Maddux
08 E90 M3 | 06 M Coupe | 01 M coupe | 99 M coupe
http://coupenut.blogspot.com/
http://x5nut.blogspot.com/
Old 03-18-2016, 05:56 PM
Thank you, JonM!
Old 03-18-2016, 06:31 PM
JonM, quick question. Where do 07119963129 QTY 2 (gasket rings) go? I could not locate them on the diagram you provided (link). That part number is found on a crank case ventilation/oil separator and on a fuel filter/pressure regulator.
Thanks!
