X5 E70 (2007 - current)
Talk about the latest generation X5, codenamed E70, with other BMW owners here. |
My 2011 35d came without the lift shock under the cargo cover. So I have to hold it with my hand every time I open it. It is a common miss from BMW, based on many threads here.
Thanks penguin for providing useful information in an early thread. I took the dive and ordered these two parts from a local dealer: 1. Gas pressurized spring, part number 51476980060, $49.58 2. Spring bracket, part number 51479138212, $8.07 When I picked up these parts at the dealer, I found the bracket came in without the screws. So I asked nicely at the dealership and actually got them to put it on for me. It is so straightforward that they did it for free. It took just a few minutes to mount it on. I attached a few before and after pictures. Note in the before picture, there are holes pre-drilled on the cargo cover for the bracket (red cycle 1). The spring will hook up with bracket and the other end of the spring goes to the pre-existing hook-up (red cycle 2). The last picture shows now the cover can stand up by itself! what a relief. ![]() Still can't believe BMW pre-drilled the holes, then choose not to install the parts. |
4 screws required?
not only did they drill the holes, they also installed a threaded insert into each hole (to receive the machine screws) did your x5d come with the cargo cover? Last edited by Popdisplay; 11-12-2010 at 03:15 PM. |
yes, I got cargo cover came in with my x5 35d. At least that is good.
And yes, I was surprised about BMW's approach: drilled the holes, but not installing the $50 spring. Sold the springs and brackets, but not providing the $0.50 mounting screws. |
mctavish, Can you tell me what the gas spring pressure rating is on the part you installed? I have the brackets, I just need to pick up a spring. Plan to get it at the hardware store. Thanks!
I am not sure about the rating. Is it supposed to be labelled somewhere on the part? If yes, I can look it up on my car later today.
no? |
Yes it should be on the cylinder. Thanks again. No rush.
If you do a search, someone in an earlier thread had this info, including the part number of the cylinder he used. Or maybe it was on xoutpost. It's in one of those places. P.S. Found it! http://www.xoutpost.com/bmw-sav-foru...oor-2010s.html Message #53 Note that I mail ordered part #4554 for $15 and it was different than described and I could not use it, wasting $15. I ended-up just buying the BMW part for $40. So if you want to try a substitute, I suggest buying locally, so you can return it easily if it has the wrong end on it. Last edited by Penguin; 11-15-2010 at 01:24 PM. |
Exactly my point. The end that attaches to the car (not the panel) has a specific fitting on it. I don't think it's an off the shelf item. However, it has been reported that this strut works: AutoZone Part # is 4554 for the gas strut cost me $13.99 Last edited by Popdisplay; 11-15-2010 at 02:03 PM. |
One really needs to inspect the particular cylinder before buying. But even with the correct fitting, I would be concerned about getting the correct spring force and length. For the price difference, just going with the OE part is probably best. If you order it from a discount mail order place and combine it with something else you need, to cut down on shipping cost, it's probably no more than $20 more to get the BMW part. |
Autozone # 4554:
http://www.autozone.com/autozone/par...er=946768_0_0_ Part Number: SG314033 Weight: 0.88 lbs Warranty: Limited Lifetime OEM Brand: AMV Description: Gas-charged lift support Extended Length: 465 mm. Compressed Length: 295 mm. Rod Diameter: 10 mm. Tube Diameter: 22 mm. Rod End Fitting: Ball socket Tube End Fitting: Ball socket Shipping Information: Overnight and Two Day shipping are not available for PO Box, APO/FPO/DPO or US Territory addresses. Price: $21.99 Ground(3-5 business days) - $5.20 Last edited by Popdisplay; 11-15-2010 at 02:18 PM. |
As I noted, I ordered part #4554 and it would not work. Why? Well it appears the original posted got a #4554 which had ball connectors on both ends, and a bracket which adapted one end of the cylinder to the particular "4554" application (which, if I remember right, was a Mitsubishi of some type). But the one I received simply had the Mitsubishi bracket staked onto the end permanently, rather than an adapter. So I could not use the "4554" cylinder I received, i.e., it was accidental that that particular version of the 4554 cylinder would work on the X5 by removing the adapter. Hence my advice to be sure to do a visual inspection of the cylinder and not mail order it, if trying to do a substiution.
Penguin, thanks again for digging out the thread with BMW part number in it. Without you help, I would probablly have to spend tons of time to go through OEM parts jungle. |
X535DMjrTorque - with the information provided by Penguin on non-OEM gas spring, do you still need the reading off the OEM one?
Many thanks to mctavish for the post with photos and parts #s. I just installed a cargo cover lift shock in my X35i and it's great. So much more useful storage when the cargo cover actually stays up on its own after you open it.
It took less than 5 minutes to install and was very easy. Be sure to order the 4 screws needed to hold the bracket (part # 07-12-9-903-027 ISA SCREW), and have a torx T30 screwdriver to install them. |
Or, if you forget to order them, just stop by the local ACE hardware and get some allen head equivalents, as I did. They are a standard metric thread. |
And Autozone part #4554 from above is NOT the correct spring. 4554 is at least twice the length that's needed for this installation.
2011 X5d Last edited by Popdisplay; 12-03-2010 at 04:57 AM. |
Is there any 2011 X5 that has this installed as a standard feature?
I toured the factory yesterday and also asked the instructors at the PCD.
BMW wants/expects their customers to hold open the cargo cover with their heads whilst extracting their cargo and/or 30 pound spare tire. BMWBMW BMW
2011 X5d Last edited by Popdisplay; 12-03-2010 at 07:26 AM. |
Easiest mod ever!! Wife is thrilled she can actually use the space below without getting her fingers slammed!
I Like it! - I looked on RealOem to get the part numbers the other day and it says that gas shock is "ended" not available.
Could you post the part numbers and prices please. Thanks |
got the parts from tischer let me find the posting again where I got the part numbers from
Their price = $39.18 bracket = 51479138212 Their price = 6.40
2011 ///M3 Sedan Alpine White/Bamboo Beige/Piano Black ED 9/16/2011 2011 X5d Alpine White/Cinnamon/Bamboo PCD 6/21/2010 2007 335i Coupe - 6MT Alpine White/Saddle Brown ED 5/23/2007 (retired) ED Trip Report W/ Pics (And Engagement Story/Pics) Last edited by 335i; 01-13-2011 at 02:28 PM. |
#25
07129903027 Screw 2008 - 2010 if you want the original screws - just make sure you order 4
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
