Old 02-20-2014, 09:59 AM
troublemaker troublemaker is offline
Mein Auto: BMW E46 325
Unhappy E39 3.5l 2000 -Mass Flow Meter Sensor problem
Hi everyone !!!
i have a problem with my BMW E39 3.5L 2000 make.
It was chip tuning recently and power up.
After a while (like 25 days since purchase) i started to have a problem with Mass Flow Meter Sensor,i replaced one and it lasted 25 days, next one 15 days, and i've chaged 4 of em . maximum wor duration is 15-25 days then it dies. Now i'm about to go and purchase 5th one. Problem mainly occurs when i step on the pedal to the flor (kick down). Anybody has any ideas what is causing its malfunctioning? and what actions are prefferably to make?
Old 02-20-2014, 10:12 AM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
Any stored codes? Some aftermarket MAF sensors have proven to be of poor quality.
Old 02-20-2014, 10:21 AM
not at all,after replacement all was erased. i tried duplicates, original staff, doesn't work. same situation.
Old 02-20-2014, 10:35 AM
Have you considered that this might be the problem?
Old 02-20-2014, 10:39 AM
just guessing, suspecting, im not the only one who made chip tuning, never heared such problems, but also i know that chip tuning vehicle is problematic than the one without.
Old 02-20-2014, 10:57 AM
ANY Ideas PPL?
Old 02-20-2014, 02:32 PM
Flightmedic Flightmedic is offline
Mein Auto: 525i
Question: What is telling you the MAF is bad?
The computer wiring of sensors nearly always provide a constant voltage to one terminal, and it is up to the sensor to modulate this into a usable signal. I can't imagine that a) this voltage is altered with changes in the computer mapping.
b) that you have encountered 5+ "bad" MAFs.
Chances are, something related is showing as a bad MAF. That is almost always a crack in a rubber boot or hose allowing unmetered air to enter the system around the MAF. Self diagnostics assume that no leaks exist.
So, disassemble the tract between airbox and manifold and physically inspect all components for cracks or other deterioration before buying more sensors. Look also at Crankcase Ventilation system for cracked hoses, along with the smallest hidden vac hoses.
