E36 (1991 - 1999)
Old 11-19-2010, 06:54 PM
crisscross's Avatar
crisscross crisscross is offline
Just living MY dream
Mein Auto: 1995 M3 Boston Green
Thanks Matt!
I will try to get pics tomorrow, but its supposed to snow 1-2 feet over the weekend......so not too sure about that.
Thanks Randy, I still need to do cooling system overhaul to fix fan clutch, so I probably won't smog until next week sometime.
-Alan
Member #2 of the Boston Green Mafia BMW-CCA #457574
1995 BG M3(sold) 2000 TiAg 4.4l X5(sold)
-2000 F250 V10
-2004 GMC Yukon Denali
-I do the things today that others won't do, so I will have the things tomorrow that other won't have....
Old 11-20-2010, 11:39 PM
crisscross's Avatar
Ok so like a good e36 owner, I went through my cooling system completely today. I replaced the thermostat housing, waterpump, fan clutch, and flushed the system. It's a good thing I did the waterpump, since when I pulled it out, the plastic impeller basically fell apart.
I also determined that I need to find a gauge cluster from an obd1 6 cylinder with around 130k miles to swap with mine.....there is no way to get the right mileage without going to the dealer (my local dealer sucks, and won't do the reset) on the obd1 clusters.
Also found out that my alarm has the older style key fob with three buttons instead of two....so if anyone needs a key fob with two buttons, I have one for 20 plus shipping
Then went and drove it like I stole it until it started to snow :devil:
I <3 my S50
-Alan
-2000 F250 V10
Old 11-21-2010, 06:59 AM
FenderBender's Avatar
FenderBender FenderBender is offline
Needs Boost
Mein Auto: Red Sled
Turbo Build Here
Old 11-22-2010, 10:48 PM
crisscross's Avatar
Ok update time:
I seem to have developed a miss at idle since replacing the bosch plugs with NGK coppers.....wtf? Maybe small valve cover gasket leak has ruined the boots causing the plugs to not fire properly? Thoughts anyone?
Also, added a new clutch stop, and its soooo much better. The best ten bucks I have spent on either e36 so far
And this weekend I am picking up a complete sachs suspension setup with about 20k miles.....can't wait to get rid of the racelands!
Next stop.....wheel town!
-Alan
-2000 F250 V10
Old 11-22-2010, 11:27 PM
Hellawut??
Mein Auto: who knows?
Are you trying to make money off the racelands?
text me 315 398 two,eight,four,four.
-Franklyn
Old 11-23-2010, 02:42 PM
crisscross's Avatar
I will let you know franklyn when I get the new stuff this weekend. I'm not ready to sell yet.
-Alan
-2000 F250 V10
Old 11-23-2010, 02:52 PM
series88 series88 is offline
Mein Auto: 325i
allan, i finally saw it....woohoo! boston with yellow fogs...yey!
Old 11-23-2010, 03:01 PM
crisscross's Avatar
Haha, yeah its boston green, but the yellows are gone...they looked like crap IMO.
I'll get some new pics up when I get the suspension this weekend
I finally get to do burn outs now!
-Alan
-2000 F250 V10
Old 11-23-2010, 04:34 PM
Mein Auto: 325i
wait...no more yellows? how bad are they?
Old 11-28-2010, 07:35 PM
crisscross's Avatar
They aren't too bad, I swapped them to the 325i. The light isn't as good as the white ones, I put silverstar bulbs in and it works the best in the clear lenses. I'm going to sell them with the 325i.
So tomorrow, new (used) Sachs suspensions will be going in, and i'll investigate the front sway bar.
Also, I have a fairly rythmical miss at idle that started when I replaced the bosch +2 plugs with the NGK copper two prongs. So far I have cleaned the MAF, and swapped the coils with some that I had around. I am going to replace the coil boots and clean the ICV to see if that will help. It seems like its every 2-3 revolutions, anyone have some ideas?
I think I'll just make this my official build thread since everyone else seems to have one
-Alan
-2000 F250 V10
Old 11-28-2010, 07:37 PM
Needs Boost
Mein Auto: Red Sled
Well since it started when you swapped the plugs, I'd take a wild gander and say they're the problem.
Turbo Build Here
Old 11-28-2010, 07:38 PM
TRaV MaNN's Avatar
TRaV MaNN TRaV MaNN is offline
Somebody stop me....
Mein Auto: EW/// 86
Maybe the engine got used to the plugs. Unplugging battery for like 30 min?
Heard that works sometimes
You canít spend all your time worrying about where your next Twinkie is going to come from, so follow rule #32 and Enjoy The Little Things.
Old 11-28-2010, 07:59 PM
crisscross's Avatar
Yeah, that was my guess too, I'll try to switch back to those horrible bosch plugs and see if the problem stops.
-Alan
-2000 F250 V10
Old 11-28-2010, 08:04 PM
Needs Boost
Mein Auto: Red Sled
Or get proper plugs instead
What does everyone here run? I'm FI so I'm different I'm sure.
Turbo Build Here
Old 11-28-2010, 08:05 PM
TnT817's Avatar
TnT817 TnT817 is offline
Mein Auto: 1993 325i 4dr
Forget the exact model, but NGK iridiums
Old 11-28-2010, 08:07 PM
crisscross's Avatar
The NGK are the right plugs (ordered them from pelican about a day after I got the car), thats why I'm confused. I'll try the boots and VCG before I swap back. There is a little oil in the plug holes, but not enough to cause a short I think
-Alan
-2000 F250 V10
Old 11-28-2010, 08:10 PM
TnT817's Avatar
Have you tried to go beat on it for a little bit?
Old 11-28-2010, 08:12 PM
Needs Boost
Mein Auto: Red Sled
Might as well get all the oil out, completely out, and try again.
Have you driven it a lot since the new plugs?
Turbo Build Here
Old 11-28-2010, 08:15 PM
crisscross's Avatar
Tried the iridiums in the 325i, and I didn't care for them, its seems that they don't run as well. In older cars, iridiums tend to get carbon build up faster, and wear out faster since the surface area of the electrode is smaller than a regular copper plug. The NGK coppers are great in my 325, just don't seem happy in the my m3
-Alan
-2000 F250 V10
Old 11-28-2010, 08:17 PM
crisscross's Avatar
Not too much, it has completely bald tires and it has been snowing alot around here. I'm in the market for some snow tires now. I think I just put the second tank in it today. Oh and I ran some concentrated techron though it to see if that would help.
-Alan
-2000 F250 V10
Old 11-28-2010, 08:35 PM
Gooby's Avatar
Gooby Gooby is offline
Sexy Sax Man / Kebab Lord
Mein Auto: 1995 M3
I'd just buy OEM sparkies...
Instagram | @randytheus
Old 11-28-2010, 08:46 PM
crisscross's Avatar
Are the NGK copper not oem?
What are the oem ones?
-Alan
-2000 F250 V10
Old 11-28-2010, 08:48 PM
Gooby's Avatar
Mein Auto: 1995 M3
i dont know...... ithnk NGK
Old 11-28-2010, 08:51 PM
crisscross's Avatar
Haha, thats why I put them in.....from my research, the ones I have are the oem ones, but the car runs like crap at idle.
It seems to pull really well though and it doesn't miss at revs higher than idle.
Thinking about turning up the idle, but I'm not too sure how that will affect my smog passing abilities
-Alan
-2000 F250 V10
Old 11-28-2010, 08:53 PM
Gooby's Avatar
Mein Auto: 1995 M3
your coils could be bad...causing the misfire...
