E36 (1991 - 1999)
Old 11-28-2010, 08:54 PM
crisscross's Avatar
crisscross crisscross is online now
Just living MY dream
Mein Auto: 1995 M3 Boston Green
That was my thought too, I swapped with some others I had in the garage, but that didn't help... I'm gonna try the boots first and see if that makes it stop
-Alan
Member #2 of the Boston Green Mafia BMW-CCA #457574
1995 BG M3 2000 TiAg 4.4l X5
-I do the things today that others won't do, so I will have the things tomorrow that other won't have....
Old 11-28-2010, 09:09 PM
nothing.
Mein Auto: ItAintUrShtYUCare?
You need the NGK +R's
thats what it says on the plug... idk the code for em
nothing.
Old 11-28-2010, 09:12 PM
FenderBender's Avatar
FenderBender FenderBender is online now
Needs Boost
Mein Auto: Red Sled
So, the other plugs didn't help?
Oil must be in there.
Take each coil out, and take an air compressor and blow in there until they are completely dry.
Turbo Build Here
Parting Out Complete 96 328is
Old 11-28-2010, 09:23 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
The NGK BKR6EK plugs are the ones to get. Strange though. Someone on my local BMW CCA forum recently had issues with skipping, and it wound up being a bad CPS. It's worth thinking about, anyway.
1998 BMW 328is
1966 Pontiac GTO
Old 11-29-2010, 05:57 AM
crisscross's Avatar
Hmmm, ok thanks guys. I'll get all the oil out before I put the new boots on.
I have the NGK BKR6EK plugs in there now, and they have the +R on them Franklyn. I guess it could be failing coil wire harness too.
-Alan
Old 12-01-2010, 01:34 PM
crisscross's Avatar
Ok got lots of parts, now just need time to install them.
Will update with pics as i get stuff done
-Alan
Old 12-01-2010, 08:59 PM
E36youngster's Avatar
E36youngster E36youngster is offline
blank
Mein Auto: 07 e92 335i
this thread doesn't have nearly enough pictures to be a build thread!
Old 12-02-2010, 03:59 AM
crisscross's Avatar
I know, but its too dark when I have time!
In other news, I have dinan throttle body (3" version)
Valve cover gasket, new spark plug boots, and clean ICV fixed my miss at idle!
M-contours are on the way, along with a new cluster and sun visors too
-Alan
Old 12-02-2010, 05:44 AM
blank
i happen to have an M3 MAF sitting in the shop if you happen to need one..
Old 12-02-2010, 04:03 PM
crisscross's Avatar
Thanks man!
Ok so I failed smog today, hydrocarbons 328 max allowed 220.
Help me smog experts! The good thing is that a Check engine light came on. Will edit after I read it.
*Edit: Mass air sensor, but I threw that code when I unplugged it once while running. More research is in order.
-Alan
Old 12-02-2010, 04:23 PM
Needs Boost
Mein Auto: Red Sled
Sooo glad I don't have to do that crap.
Seems pretty high, everyone else says seafoam, so why not right?
Turbo Build Here
Old 12-02-2010, 04:28 PM
crisscross's Avatar
I have the can in the garage, I just haven't gotten around to it yet.....I guess I'll try that soon.
-Alan
Old 12-02-2010, 04:43 PM
Needs Boost
Mein Auto: Red Sled
Does it cost to redo your smog?
Turbo Build Here
Old 12-02-2010, 06:56 PM
blank
Originally Posted by crisscross View Post
Thanks man!
well how coincidental! lol hope it works out dude, no emissions test here so i have no idea what you are going through
Old 12-02-2010, 06:58 PM
Mr Gusta's Avatar
Mr Gusta Mr Gusta is offline
Fireballs inc.
Send a message via AIM to Mr Gusta
Mein Auto: 11:1 hx40 s50b28 sedan
do you have cats?
Turbo lag is actually a headstart to make it fair
Old 12-02-2010, 07:32 PM
kanovic's Avatar
kanovic kanovic is offline
His Name is Carlos
Mein Auto: 98 M3
omg me neither yayyyyyy
Old 12-02-2010, 07:38 PM
crisscross's Avatar
Yes I have a cat, not two....someone replaced it at some point.....that could be it.
I found another code for the intake air temp sensor, so i'll swap it from the 325 and see if that works.
Does anyone know if intake air temp sensor would cause a missfire? I know def know it would cause a closed loop rich idle, and I guess that could cause a missfire?
Thoughts?
-Alan
Old 12-10-2010, 07:01 PM
crisscross's Avatar
Ok so I got contours and tires all mounted up last night....I will post pics tomorrow after I get home from skiing tomorrow and get her all washed up. I may try to smog again tomorrow....I'm slowly making progress on all the little things.
So far I have done:
New sun visors
Replaced cluster
Fixed side skirt
Replaced rear suspension with sach's shocks and H&R springs
Sparks plugs
Coil boots
Intake air temp sensor
No name CAI
Found out I have Dinan throttle body
Contours and new tires
Replaced fog lights
Turner RSM's
Replaced missing panels in the trunk
Fuel filter
Mobil one oil change
Cabin air filter
Vavle cover gasket
Cooling system overhaul
And I have only dirven it about 600 miles
-Alan
Old 12-10-2010, 08:29 PM
Needs Boost
Mein Auto: Red Sled
Good job!
How does it drive now?
Turbo Build Here
Old 12-10-2010, 08:59 PM
David-C David-C is offline
Mein Auto: 1992 BMW 325i
Wat is the seafoam thing i keep reading about and wat does it do?
Sent from my PC36100 using BimmerApp
Old 12-10-2010, 09:51 PM
TRaV MaNN's Avatar
TRaV MaNN TRaV MaNN is online now
Somebody stop me....
Mein Auto: EW/// 86
google: seafoam
alan, thats an impressive list for 600 miles. Hurry up and make it pass smog now
You can’t spend all your time worrying about where your next Twinkie is going to come from, so follow rule #32 and Enjoy The Little Things.
Old 12-11-2010, 06:51 AM
crisscross's Avatar
Yeah it costs to redo it whether you pass or fail. Its around 20 bucks, and we have to do it every year.
Good job!
Thanks! It pulls really hard now.....I just want to mod the hell out of it, but I need to get it registered and all my maintenance done first.
Originally Posted by TRaV MaNN View Post
google: seafoam
I may try again today, it seems like its not idling as rich now that I repaced the IAT sensor that threw my CEL.
-Alan
Old 12-11-2010, 06:59 AM
drivinfaster's Avatar
drivinfaster drivinfaster is online now
bimmerfest Supporting Member
Mein Auto: rescued bmw's
Thoughts?
no. i have not come across any instance where the air intake temp sensor caused a misfire. running rich would also not cause a miss. it would bog, run like poo, and co would be through the roof, not hc.
hc is a misfire indicator, so i would be looking faulty ignition (coil/plug/boot), or, if caused by a lean mis, faulty injector.
a cat would not cause a misfire, so i would not worry about that at this time.
find the cylinder that is missing and then do this. swap the coil with one cylinder, and the plug with another cylinder. see if the miss moves. if it does, then you have found the defective part. if it stays at the same cylinder, then you car going to be looking injector or valve issue.
good luck.
df
Old 12-11-2010, 07:16 AM
crisscross's Avatar
Thanks df, I am having a hard time locating the misfire...its OBD1 and I'm not getting a code. Should I disconnect one plug at a time when its misfiring and see if I can locate it that way, or do I need to have it hooked up to a computer?
It seems to only miss at idle after running at constant rpm when the engine is warm, like on an offramp after driving on the freeway. It doesn't miss when cold.
The car seems to run alot better after I replaced the IAT sensor.
-Alan
Old 12-11-2010, 09:46 AM
Needs Boost
Mein Auto: Red Sled
Have you checked for leaks around the ICV or cleaned it?
Turbo Build Here
