Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M5 & M6 > E39 M5 (1998-2003)
E39 M5 (1998-2003)
Old 11-15-2010, 11:01 AM
brz28 brz28 is offline
Mein Auto: Charger
E39 Service Schedule
Guys... trying to hunt down a service schedule for a 2003 M5.
Something that says:
60k do this
70k do that
80k do more of this
90k new clutch ( got that figured out on my own )
100k do what?
Thanks,
Brandon
Old 11-15-2010, 12:29 PM
mark_m5's Avatar
mark_m5 mark_m5 is offline
Overly Intellectual
Mein Auto: 2002 M5, 2001 996 Turbo
I'll look in my manual and post it.
PS: Still on original clutch at 102k miles
Mark
Grammar: The difference between "knowing your sh*t" and "knowing you're sh*t."
"A world that is 'idiot proof' is a world that is only fit for idiots." - Racer X / 6'er
Old 11-15-2010, 01:03 PM
mark_m5's Avatar
Overly Intellectual
Your mileage may vary. The dashboard indicators tell you when you need service, for the most part; based on sensory inputs and the way you drive.
I do oil changes every 10k miles with 6.9 quarts of synthetic 5W-30 whether it tells me to or not. The Inspection I and Inspection II haven't come up, but I did the spark plug change at 100k and do whatever it needs as needed.
The description for what Inspection I and Inspection II cover is kinda lengthly...
Mark
Old 11-15-2010, 06:48 PM
Mein Auto: Charger
Thank you...
Yeah man... the service manual.
Showing lotsa check this, check that...
Found this as must do's:
Replace brake fluid every 2 years ( due for me... 08 was last change )
Replace coolant every 3 years ( still good, done in 08 )
Replace Oxygen Sensor at 100k
Replace Spark Plugs at 100k
Replace Sealant Cartridge ( for M-Mobility System ) every 3 years
Replace ATF every 100k, since mine is a manual maybe longer... maybe not.
Again, appreciate your help.
Brandon
Old 11-24-2010, 09:41 PM
cataclysmicvoid cataclysmicvoid is offline
Mein Auto: 2003 Le Mans Blue BMW M5
Good idea to check the power steering fluid, maybe every 2-3 years to see how it is doing (color wise). Xenon headlamps probably around 5 years or so to keep them at high brightness (they won't die out for longer, but a noticeable difference when they are replaced).
