E46 (1999 - 2006)
The fourth generation 3 Series (E46 chassis) was introduced in 1999 and set the standard for engineering and performance during it's years of production including being named to Car & Driver's 10 best list every one of those years! ! -- View the E46 Wiki |
#26
It's like that one, Mrmaico. But, instead of purchasing the single wrench from Amazon for $17, you can get the 5 piece set from Harbor Freight for $27. I am hard on tools and I have large sets of Craftsman and Kobalt sockets and wrenches, but the ones like this set that I purchased from Harbor are not too bad, considering even the more expensive ones you purchase are Made In China. And the Harbor ones are lifetime warranty. Anyway, another each to his own when it comes to tools. But that little 10mm you have there will prevent you from having to lower the tranny or remove the intake manifold. Here is a link for the full set
http://www.harborfreight.com/5-piece...set-68953.html And Iskoos, I try to spend as little time under a car as I can too, you never know when something is going to give. Normally, when I have a car on stands, I have the floor jack on one side so in case of a problem, I can get out of there safely. |
#27
Great Post . I'm about to experience this .
#28
Hey, good luck with that change there, 01E46er. Try it the way I posted and you might find it pretty easy. Might be worth the drive to Newport to get that set if you don't have one. It will make quick work out of it. Here is the sequence I used:
1: Disconnect battery and raise car 2: Remove splash pan (philips) and skid plate (16mm) 3: Remove exhaust flap vacuum canister (13mm). While you are there, check the vacuum lines going into the canister. One of mine was rotted. I think it was 5/32" line. 4: Disconnect battery connection to starter 5: Deal with the top bolt first. Get your 10mm flexhead ready. Reach up around the bell housing and about 11 o'clock you will feel the top bolt. If you run a finger to the starter plate, you will feel the other end of the bolt. Slide your hand up with the 10mm and when you get the ratchet on the bolt, bend it just enough so you aren't rubbing your hand on the firewall. When it is moving freely, remove the wrench and try turning it with your fingers. This way you don't lose either the wrench or the bolt on top of the tranny. If you do, don't sweat it. (I always have aluminum 1" flatbar laying around for other projects) Just get something like flatbar and reach over the tranny with it. It will drop right off. 6: Do the bottom bolt. You will need to almost 90 the flexhead to do it but it is easy. 7: Really Important Here! When you are removing the starter, be careful. There are vacuum lines that are a PITA to replace there and also, your Crank Position Sensor wiring is right below it. If you nick a wire pulling it out, you could send a CPS fault to the ECM and then the fun starts! Rock the starter just a little, enough to get the bottom bolt area away from the bell housing, and use a large screwdriver to pry the starter away. 8: Bring the starter down facing you so you can remove the remaining two solenoid connections. 9: Before reinstalling the starter, goose out the guide hole a little. Find a bit that is just oversize of the hole. This way it will remain fairly tight but you will be able to use hand force to put it back. Just reverse the process and you are done. 10: Before installing vacuum canister, do a final look for anything you might have accidentally unplugged or damaged. That's it. You know, it is a little tight down there, but, big but here. The only thing that really seems in the way is the control arm. I am not sure why, since you already have the car up, you wouldn't unbolt the control arm and get it out of the way instead of dropping the tranny or removing the intake manifold. Anyway, just me and the way I think. If the arm wasn't there, you would have a lot more working room. Good luck guys! |
#29
Thanks for all the info !!!! I wonder if it is a little easier removing the intake manifold and doing it from the top ? I installed Dinan high flow throttle bodies a few months back but never looked to see if i can even see the starter .
#30
Well going to replace this along with the driver side control arm tomorrow!
:/ thank god I came upon this otherwise I would replaced the control arm and took apart the top of the engine lol. Now I just have to get those wrenches you said would help and hopefully this will all go by nicely. Thank you everyone
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
