Old 11-17-2010, 05:47 PM
Swat17 Swat17 is offline
Mein Auto: 2001 BMW 530i
Exclamation BMW 530i 2001- cylinder 1 2 3 misfiring. Please help!
When I bought the car it had a very rough idle and it woud stall.
So I did some research on the forum and found it to be the ICV. So I replaced it and my stalls went away.but my car still idles rough, but doesn't stall atleast. I checked the codes and it said cylinder one two and three misfiring with fuel cutoff, o2 sensor bank 1 sensor 1 bad ckt. So far I've replaced my vanos seals,intake and exhaust cps, bank1 o2 sensor.I've cleaned my disa valve and replaced my head gasket. I replaced all 6 sparkplus to nkg platinum. And I tested my coils and they all work. I need help big time. I don't know what I should do next.
Old 11-21-2010, 03:33 PM
Bump
Old 11-21-2010, 03:50 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
Originally Posted by Swat17 View Post
found it to be the ICV... but my car still idles rough...I don't know what I should do next.
I do not know the answer; but I myself am trying to get those who know to help outline a general diagnostic procedure for debugging misfires.
- General diagnostic procedure for a single or multi-cylinder E39 misfire?
BTW, how did you test the ICV?
Old 11-21-2010, 03:53 PM
poolman poolman is offline
Mein Auto: 525i station wagon
Well first--you replaced your head gasket or valve cover gasket--which is it--you should start by moving the coils from the three cylinders that are missing to the other three that aren't to see if the miss moves--bet they don't and I think you have a large vacuum leak and thats causing your problem--you have to have the codes reset to turn the fuel back onto the engine for the affected cylinders--lets start there--if by chance you have indeed had your head gasket replaced we need to look at a few other things
Old 11-22-2010, 12:42 PM
After looking at this again you stated that you replaced the Vanos seals--I think you have an air leak and it's coming from the CCV valve and one or more of the 4 hose's that hook up to it--probably was aggravated
and made worse when you changed out the valve cover and again when you replaced the Vanos seals--also when replacing the valve cover--did you purchase the 15 rubber bolt grommets that are needed to do that job correctly?
Old 11-22-2010, 12:48 PM
dalekressin's Avatar
dalekressin dalekressin is offline
Mein Auto: 2010 M3
If his replacement set was missing 2-4 rubber bolt grommets; where can he get the additional ones?
94 530i sold (That was difficult for me)
01 530i >144,500+ miles SOLD
06 330XI winter's especially fun drive (SOLD)
10 M3 Sedan (sweet)
13 Nissan GT-R Black Edition
14 Porsche Cayenne Platinum Diesel
15 Porsche GT3
16 Porsche GT4
BMWCCA 4215
Old 11-22-2010, 03:13 PM
Think EACTuning might have those available, that would only have a small air leak problem--thniking that the CCV valve's main hose from the valve cover down to the ccv is the culprit here--thats the first one to go in most cases because it gets handled alot and becomes brittle faster--also I think it's thinner plastic.
Old 11-22-2010, 07:41 PM
mmm635's Avatar
mmm635 mmm635 is offline
Mein Auto: '02 525i Sp/5, 95 FJ80 LC
Try looking further upstream like the MAF. Take it off and clean it and then reinstall making sure all connections are good. Also, as mentioned in a previous post, check all of your vacuum hoses well. This is what will cause your car to run lean at first and then the ECU will cause the engine to run rich as a result in the closed loop operation lean signal feedback. It would not hurt to run a good quality fuel system cleaner for the injectors.
If you have a rich condition as a result of a dirty MAF or unmetered air, then it will easily gunk up the ICV with carbon and make it stick as well as cause poor detonation. Rarely does the ICV go bad - just a good cleaning will allow the valve to move freely. That said, the rich condition gets to your exhaust and goes unburned laying a nice coat of soot on your O2 sensors and on to your cats - not good.
Also, do a hard reset by disconnecting your battery terminals and connecting the with a bridge for 10 minutes.
Old 11-23-2010, 09:39 AM
I was hearing a clicking noise in that area so I did some research about it. It turned out to be related to the icv, also others have had the same problem. So I checked it out and it had alot of buildup inside it. Tried cleaning with carb cleaner. Didn't help so I just replaced it. After that my stalls whent away, except my rough idle/misfire
Old 12-03-2010, 03:06 PM
i have checked my ccv hoses and found the hose with the red arrow extremely pinched. it was not cracked. i replaced that hose and the one that goes from the valve cover too just incase. now when the cars rpm gets low i hear a loud knock in the engine. when i rev up the engine, after a few seconds the rpm's start dropping by themselves, and then it knocks again. before replacing my vaccum hoses the car still made the knocking noise, but now it worse.
ID:	257090   Click image for larger version
Old 12-04-2010, 04:20 PM
I would replace the entire CCV valve and the hose's--sounds like the CCV is getting ready to go out--don't know how you replaced the hoses without cracking others--cylinders 1 -2 -3 would be the first to gain air from a vac leak coming from the CCV valve.
Old 12-04-2010, 07:11 PM
bluebee's Avatar
Originally Posted by mmm635 View Post
a dirty MAF ... will easily gunk up the ICV ...laying a ... coat of soot on your O2 sensors
Hi Michel,
Even though I know nothing about misfires, I've just now added this advice to the general debugging procedure to follow to isolate the cause of an E39 misfire.
- General diagnostic procedure for a single or multi-cylinder E39 intermittent misfire?
Please check it out for accuracy! Thanks.
OK. I added this. Easy enough to do. But is this a hail mary play?
Do you really believe this will do anything useful?
What?
Old 12-04-2010, 07:14 PM
bluebee's Avatar
I added a link to this suggestion to the nascent misfire debugging procedure.
Old 12-04-2010, 07:18 PM
bluebee's Avatar
I added this suggestion to the misfire diagnostic.
Please check for accuracy.
Old 12-11-2010, 03:07 PM
Ok i changed my ccv and all hoses. I don't think I have a vacuum leek anymore. One thing I noticed is that if Either one of my cps sensors are disconnected (intake or exhaust) the car seems to be idling smooth. Why is that? -- ( I replaced both of them with the original OEM)
Old 12-12-2010, 02:31 PM
Well lets look back behind the intake on hte drivers side--you will need to remove the cabin air ducts and have a small mirror and a flashlight--check back behind the intake with the mirror and there should be two hose's back there--if they have never been replaced--bet you have another vac leak there ---
Old 02-22-2011, 02:36 PM
Its been a while and i still cant fix the car. I have been waiting for a while and got my ECU replaced. It got rid of all my misfires on cylinder 1 2 and 3. But, my PreCat O2 Bank1Sensor1 code doesn't wanna go away (car idles a little rough too). I'm 100% sure i don't have a vac leek anymore because a mechanic did a smoke down test and found nothing except for my oil tube gasket which got fixed. Please help me, i don't want to give up although i think its impossible. what could be causing this?
misfire, o2 sensor
