Autounlock feature lookup table (Peake,Carsoft,Easy-DIS,GTI,INPA,EDIABAS)
I'm confused. I'm sure others are too.
What software can set and unset the autolock feature of the BMW E39? I'll embarrass myself by making a stab at which programs can set and unset E39 automatic doorlocks (please correct my errors!) and I will add corrections as they come in (EDIT: Here was a great correction.) KEY: NO = Does not set or unset BMW automatic door lock features YES = Does set and unset BMW automatic door lock features SUMMARY: YES: GT1, Progman, Easy-DIS v44 only, NCS Expert, INPA, Carsoft (v7.x & v8.x only) NO: Peake, Carsoft v6.x, Easy-DIS versions after v44 Recommended: ~$250: Carsoft, version 7.x & 8.x, CarsoftInternational (not earlier versions) ~$500: GT1, version DIS SSS?, BMW group tester 1 ~$???: Progman, v?, seems to have superceded Easy-DIS Not Recommended: ~$???: NCSExpert, version?, by from ?, not user friendly ~$450: INPA, version 2006?, buy from ?, not user friendly ~$???: Easy-DIS v44 only (later versions do not unset autolock), seems to have been superceded by Progman Note: I'm not sure I know what these "things" are, and some look like a subset of the others (which shows my ignorance); so a short explanation of each would also be useful from someone who knows what they are. Note: EDIABAS is the communication protocol used by Easy-DIS & GT1 & INPA for diagnostics/programming but is not actually a program. But using the EDIABAS protocol allows for any type of coding/programming to occur. Note: Carsoft 6.x does actually program the car memory - it just doesn't code the key hence where problems arise for many. The only memory settings available for the key pertains to the Central locking. Disclaimer: This thread is not intended to 'debate' the merits of WHY anyone would want to set or unset any particular feature which already exists aplenty elsewhere (1) (2) (3). Last edited by bluebee; 11-18-2010 at 09:08 PM. Reason: I will update the table in this first post as new information comes in so that we have a comprehensive list (if possible). |
I highly recommend going through the parked threads in the Diagnostic Software forum on the other site. By following the instructions (+computer skills) I have INPA, DIS, NCSExpert, amd Progman running with an ODBII interface for about a $25 investment.
I have since used my setup to install and code an ABS module.
2003 525i 5spd/PP/SP/CWP/Xenons/Sapphire/Black CDV Delete Dice Silverline TCU Bluetooth |
This doesn't answer the question but it does give some new software to consider. So, I added these names (previously unknown to me) to the table in the first post so we have a more comprehensive list
The member "aca84" kindly provided some input in this post, which I reproduce below and will add to the table in post #1 above so we can grow our combined knowledge. Quote:
Do you have a direct link to the interface one should get for about $25 to use these programs?
http://forums.bimmerforums.com/forum....php?t=1505990
Thanks again! |
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWNX%3AIT I am not skilled enough with a soldering iron to do the transistor mod. I just got another interface from Germany that should allow full programming with DIS. I was overwhelmed as well and but stuck with it and got things installed after a few evenings of working on it. The first step is INPA which installs right on windows. After that the VM installs for EasyDIS and Progman are a bit trickier.
2003 525i 5spd/PP/SP/CWP/Xenons/Sapphire/Black CDV Delete Dice Silverline TCU Bluetooth Last edited by nutterdog; 11-18-2010 at 08:26 PM. |
![]() ).Wonder if this is the same as the Ebay one? Last edited by dvsgene; 11-18-2010 at 08:48 PM. |
The cable I use is similar to the picture attached below. There are many sellers selling these on ebay (search for EDIABAS cable). For those without a 16pin OBDII port, most sellers include the 20pin to OBDII converter also which should work. Of course, the above cables need to be used on a computer with an RS232 (serial) port. There are many threads dedicated to installing/troubleshooting programs. As far as installing Easy-DIS is concerned, the only 3 sources I had to use (in the end :P) were: 1. Installing INPA 2. Install Easy-DIS 3. Search for user DavidMC's READ THIS FIRST document <-- most invaluable! Bluebee, also although it's true that later versions of Easy-DIS cannot perform programming/coding, I'm not sure of the exact versions. What I do know is that v44 was easily located and seems to be the most popular version. Last edited by aca84; 11-19-2010 at 01:12 AM. |
For the record, since it's related, but not obvious, it appears a 120 ohm resistor in the DME may have something to do with a disabled auto-doorlock feature.
Details here. |
Today, someone asked what Carsoft can do (over here in the OBDII freeware thread) so I pointed him to the VERY best of E39 Links but the Carsoft threads weren't easy to find in the VERY best of E39 Links ...
So I just now added the following to help others (as always): - Description of Carsoft, GT1, INPA, DIS, EDIABAS, & Peake (1) & which can modify the auto-lock car door feature (1) & what does Carsoft do anyway (1) (2) (3) (4) |
Hi,
Where can I download INPA and Easy-DIS>? Thanks! |
Look here.
http://forums.bimmerforums.com/forum...play.php?f=233 You will find lots of links to INPA and EasyDIS downloads as well as guides for install and use. One download site with excellent instructions http://www.4shared.com/account/dir/7...ng.html?rnd=93 password is wilma82 Regards RDL Last edited by rdl; 01-27-2011 at 09:15 AM. Reason: added download site |
For the record, I just found out about the "Launch X-431" from this thread:
- E39 Steereing Angle Sensor HELP Specifically the information was related to the steering angle sensor: Quote:
Anyone know? |
I will check today. I am pretty sure though that it won't, since the auto-lock is controlled by the general module. I am pretty sure my scanner cannot go that deep into the electronics.
2004 BMW 330ci Silvergray Sport Package, Cold Package, Xenon Headlamps, Premium Package, 6 Speed Manual, Build Date 9/03 Sold - 2003 325i Sedan Japanrot 5 Speed 8k Xenon Headlamps Build Date 11/02 |
I just got back from work. It seems that my scanner can program the auto lock, daytime running lights, alarm options, high beams with fogs, etc on my 530i. I can do a whole lot of things like keeping the radio light up with the time even if the radio is off. Another option I found interesting was turning on the low beams when the car is unlocked in the dark to help you find your car and aid in visibility. It will only work with cars that have automatic lights and a light sensor on the windshield.
Woo hoo! We have a (another) winner!
Thanks for performing that test. It's nice when a thread is complete and consistent! Now we can go to an Indy and ask if they have the scanners that we know can program the auto-unlock auto-lock feature to have it programmed the way we want! PS: I absolutely HATE that auto-lock feature. Every time it locks on me, I say to myself "Jeez Louise! ... Where does BMW think I live? In the middle of a war zone?". I can't stand that 'feature'; yet I'll be darned if I'll pay the dealer just to reset it. I'd rather buy a tool (if it's around the same price); or find an Indy to do it for me (but my car hasn't ever been to an Indy and hasn't been to the dealer since they ripped me off years ago). Last edited by bluebee; 04-02-2011 at 07:07 PM. |
So the $25 usb cable to obd2 can code bmw modules like the LKM and ABS? Im so confused now..
Jimmy what would you recommend for a a serious DIY'er? My main concern is being able to code the modules and be able to program other BMW specific features like auto locks? Key programming would need another device totally CORRECT??
Andreas Queens NY BMWCCA# 186796 86 325es (wrecked by careless driver) 87 325 300k (project for life) aka 1BADETA/Christine 00 540is 6spd 202k (daily driver) |
http://forums.bimmerforums.com/forum...play.php?f=233 You will find help on software to do coding & programming; not diagnostics only. This thread will help clarify some of the options http://forums.bimmerforums.com/forum....php?t=1391667 Regards RDL |
I'm almost to the point of 'trying' those recommended sofware methods!
- Diagnostic Software (DIS, INPA, EDIABAS, IBUS, CANBUS, CARSOFT) Just to summarize, here's where I think we are on this quest: KEY: YES = The tool will set and unset the BMW automatic door lock feature. NO = The tool will not set or unset the BMW automatic door lock feature. Note: It appears most USB-to-serial adapters don't work; but I'm told (via a PM) that the "Keyspan US19H" works well (with INPA at least). SUMMARY: YES: GT1, Progman, Easy-DIS v44 only, NCS Expert, INPA, Carsoft (v7.x & v8.x only), Launch X431 NO: Peake, Carsoft v6.x, Easy-DIS versions after v44 Less expensive: ~$250: Carsoft, version 7.x & 8.x, CarsoftInternational (not earlier versions) ~$500: GT1, version DIS SSS?, BMW group tester 1 ~$???: Progman, v?, seems to have superceded Easy-DIS ~$450: INPA, version 2006?, buy from ?, not user friendly (INPA codes the VIN kind of stuff more so than Carsoft) More expensive: ~$3,000 Launch X-431 ~$???: NCSExpert, version?, by from ?, not user friendly (I'm told it has a steep learning curve!) ~$???: Easy-DIS v44 only (later versions do not unset autolock), seems to have been superceded by Progman Last edited by bluebee; 04-09-2011 at 05:18 PM. |
OK After 2 hours of reading, I think ive come to the conclusion that this is the way to go if i want to be able to code new parts such as an ABS or Light control module.
Am i correct????? http://cgi.ebay.com/ebaymotors/NEW-E...motiveQ5fTools
EDIBAS is BMW's interface language to its modules, some call it an API. All the application programs below use EDIBAS to talk to the various car modules; except for ISTA where I don't know. EDIBAS isn't run directly; it does have to have it on the computer so application programs have it's instructions available. In BMW speak, "programming" as a noun is the set of instructions stored in a module to give it functionality. Programming as a verb refers to loading a more recent version into a module as BMW releases them rather than actually writing instructions to tell a module how to perform. "Coding" is setting the options that the programming in a module will recognize & permit, i.e. options available in a module. For example: turn on/off daytime running lights, setting "Car and Key Programming" options (which is misnamed in strict BMW speak.) The door lock feature mentioned in Bluebee's post is turned on/off by coding. All the applications below are available free as internet downloads, except ISTA. All cover every BMW model sold up to the the release date of the version, or at least those with electonic modules. So the E39 is covered by all applications. All will work with the round 20 pin engine bay plug as well as the OBD II plug. All will address every module in the car; most aftermarket applications skip several or many. GT1 is a hardware/software bundle for BMW dealers. The s/w was DIS / Progman. SSS is the h/w s/w bundle that superceeded GT1. Confusingly, also the name of software that replaced DIS/Progman. DIS BMW dealer software. It is user friendly. It will do diagnostics, read modules for version, read modules for DTCs, activate function tests, display live data, propose and step through tests to isolate faults for a DTC. Up to V44 DIS would also do coding & programming. YES to the door lock feature. With V45, DIS became the diagnostic module only. Progman became the module used for coding & programing, but confusingly the version numbers start in the low 30s, while DIS version continued upward from 44. Each new version would contain revised module programs. YES to the door lock feature. SSS Superceed DIS & Progman - same functionality but improved user interface. Since it's a later version, any programming available will be later versions than available in DIS. YES to the door lock feature. DIS, Progman & SSS run in UNIX & are tricky to install on Windows machines. There are very detailed step by step guides to help one through the maze. ISTA is the current BMW dealer software. Not available "in the wild" EasyDIS is DIS V44 modified to make the UNIX/Windows steps easier for installation. I thought YES to the door lock feature but if Bluebee has better info, I defer to her. INPA is nice user friendly diagnostic module reader. It is dead easy to install in Windows. A good first program to get started. Will read module h/w and s/w version, read error memory (DTC / fault codes), clear errors. It will activate functions within modules to test them, e.g. command DME to turn auxillary fan on to check functionality. Will also display live data from car modules. But not as full featured as DIS diagnostics. NO to the door lock feature. NCS Expert will read and write module coding only. Limited documentation available. Definitely not intuitive or user friendly; actually risky since you can code options that contradict one another and all the option statements are in German & German abreviations. Some people report they have "bricked" modules. A free program named "NCS Expert for Dummies", written by a power user named Revtor, is front end that translates options into English & helps create the input file and provides the best explanation of how to use NCS Expert. Oops, Revtor is 3rd party. ![]() YES to the door lock feature. Regards RDL Last edited by rdl; 04-02-2011 at 11:31 PM. Reason: typo |
My post above has some explanation. Regards RDL |
Is there a kit that comes with everything i need?
#25
The ultimate scanner depends how much money you want to spend. If you want a nice scanner, you will have to spend a lot, but you will have a whole bunch of features that are very helpful in diagnosis like an oscilloscope, built in circuit tester, etc.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
