Old 01-11-2004, 08:39 AM
thez3man thez3man is offline
Mein Auto: Z3 2.5I 2001
Exclamation Z3 Removing Center console
How easy is it to remove the center console and where can i get info on removing it. Thanks
Old 01-11-2004, 09:30 AM
JonM's Avatar
JonM JonM is offline
Moderator
Mein Auto: 01 Mc, 08 M3, Motorrad x2
For FAQ purposes, I'll respond to this one.
Some key words for future searches on this: Z3 center console radio HVAC oddments box
Thanks to Ron Stygar for taking the time to host these images.
From now on, when someone asks for this, refer them to the search function or to the FAQ.
Jon Maddux
08 E90 M3 | 06 M Coupe | 01 M coupe | 99 M coupe
http://coupenut.blogspot.com/
http://x5nut.blogspot.com/
Old 08-21-2005, 03:07 PM
DannO's Avatar
DannO DannO is offline
Mein Auto: //M Coupes
More info on the gauges and lighter plug here...
http://www.bimmerfest.com/forums/sho...d.php?t=108755
And another set of instructions here...
http://www.waycoolinc.com/z3/book/console.html
Old 05-14-2006, 08:52 PM
Ruprect Ruprect is offline
Ruprect
Mein Auto: 1997 Z3
can anyone add instructions for an automatic transmission
Ruprect
"If I'm curt with you, it's because time is a factor here. I think fast, I talk fast, and I need you guys to act fast if you want to get out of this. So, pretty please - with sugar on top..."
Old 05-28-2007, 10:17 AM
thesource83 thesource83 is offline
Send a message via AIM to thesource83
Mein Auto: 97 Z3 2.8l
Exclamation
yea does anyone have the instructions for the automatic transition?
Old 05-28-2007, 07:19 PM
cngizbleevng's Avatar
cngizbleevng cngizbleevng is offline
hardtop potentate
Mein Auto: 2002 Z3 3.0i 5 speed
I removed the center console and I have AT. It's the same.
Old 05-28-2007, 07:29 PM
ok, how do i take apart the shifting.. because i got the back part my the seats to lift up but nothing wanted to move by the counsel area.. any tips?
thanks,
-=SAMI=-
Old 05-29-2007, 09:08 AM
hardtop potentate
thanks,
-=SAMI=-
At the rear of your leather shift boot (bottom edge) push it forward and lift. The front part can lift up then as well. Pull the shifter back to Neutral and pull hard straight up to release it from the console (careful not to hit yourself in the face).
Old 05-29-2007, 11:44 AM
but i dont have a leather shift boot.. its plastic...
-=SAM=-
Old 05-29-2007, 08:49 PM
hardtop potentate
Ahh, yes, I didn't notice you have a '97. Sorry, but I don't have a good answer for you.
Old 05-29-2007, 08:58 PM
alright... thanks anyway...
Old 10-02-2012, 06:18 PM
jcard412 jcard412 is offline
Mein Auto: BMW Z3
I saw that link but its not my z3 console
Old 10-03-2012, 04:49 AM
resunoiz resunoiz is offline
Mein Auto: 520i E60
in my non-automatic Z, I removed the center console without removing shift knob. only needed some more care to pass over it. your plastic "boot" think is simpli fixed with connectors same of the leather one..you just have to give a look at it
maybe is just the same
Old 10-03-2012, 08:05 AM
JonM's Avatar
Moderator
Originally Posted by jcard412 View Post
Removal instructions are the same. Once out of the car, turn it over and the console trim pieces can easily be removed with screws.
Jon Maddux
Old 06-02-2014, 07:54 PM
ClayMan ClayMan is offline
Mein Auto: 325is
Is there an easier way to do this on the M Coupe/Roadster? E.g., without removing the radio?
Old 08-20-2016, 10:56 PM
billbmsn billbmsn is offline
Mein Auto: 2000 Z3 2.3
I have a 2000 Z3 roadster. Trying to remove the console following the directions in the first post, I can get it to pivot up from the rear, but the console will not drop away at the front. It is stuck at the top. Seems something else is holding it at the top. Ideas?
TIA,
Bill
Old 08-21-2016, 05:32 AM
vintage42's Avatar
vintage42 vintage42 is offline
BMW CCA 1405
Mein Auto: 1997 BMW Z3 1.9 5MT
Originally Posted by billbmsn View Post
... Trying to remove the console.. I can get it to pivot up from the rear, but the console will not drop away at the front. It is stuck at the top. Seems something else is holding it at the top. Ideas?
Raise rear of console slightly while pulling to rear. Pull back only as far as needed to disengage front locking clips. Remove cigarette lighter wiring. Slide console to left, rotate to clear parking brake handle, then remove console.
Old 08-21-2016, 11:50 PM
Front locking clips??
When I lift the rear and pull on the console to the rear it will not come free at the front top edge under the vent. It feels like something else is holding it on.
Old 08-22-2016, 03:54 AM
vintage42's Avatar
BMW CCA 1405
... When I lift the rear and pull on the console to the rear it will not come free at the front top edge under the vent. It feels like something else is holding it on.
Could that something be the front locking clips?
https://docs.google.com/viewer?a=v&p...NWFjNjA0NDFhNw
Old 08-22-2016, 12:33 PM
Sure could be. I'm not sure where they are. That's why I wrote "Front locking clips??" above.
Old 08-22-2016, 01:10 PM
vintage42's Avatar
BMW CCA 1405
Maybe it's in the steps here under Remove Center Console...
http://www.bimmerforums.com/forum/sh...ntire-interior
Old 08-22-2016, 03:09 PM
NZ00Z3 NZ00Z3 is offline
Mein Auto: 2000 Z3 3.0i
The locking clips are two pins, one each side of the console. They are approx 4 to 6 mm diameter and 10 to 12 mm long.
Haven't read all of the previous posts, making the assumption that you have removed 4 screws through the radio opening. 2 for the heater controls and two pointing up that hold the console to the dash.
Old 08-22-2016, 06:46 PM
I followed the instructions in the first post and as shown in the Bentley service manual. Rear console screws on each side, shifter surround, handbrake surround, console bin, screw under console bin, then radio, the 2 screws above radio that appear to hold the console to dash, then loosen 2 screws so the climate control to pivot back. That's all called for. Don't see the locking clips. Noticed two other clips with screws on either side of the radio hole, where the screw heads are facing forward, so removal is convoluted, but I took them out. Still not able to free the console from the dash at the top. Will look at that other linked thread which is total dash and console removal. [EDIT - and i did the 2 screws on each of the front sidepanels. Sorry, I forgot that.]
Sorry for all the trouble. I must be stoopid.
Old 08-22-2016, 07:09 PM
vintage42's Avatar
BMW CCA 1405
... Will look at that other linked thread which is total dash and console removal...
Yes, do take a look at the link in #21 where it says...
f) Once all those screws are removed, very carefully lift at the back of the center console enough to free it loose
NOTE: Though the screws are removed, the front part of the console is still secured to the dash by two hard plastic prongs that slide into holes in the dash
g) Once the back part is loose, very carefully try to slide console back and up from the front to the back of the carů.be aware of the prongs at the front, may need a little shifting up and down/left and right on the front side to get it loose; biggest thing is you don't want to use excessive force and break the prongs or the holes in the dash (once you get it loose, just take a closer look at your set up to see what I'm talking about)
Old 08-22-2016, 08:20 PM
Have you removed the 4 screws (2 each side) in the foot wells? They will be under little plastic caps?
