E36 (1991 - 1999)
Old 11-19-2010, 01:00 PM
cetsch cetsch is offline
Mein Auto: 87 325is, 93 325is
Defrost but no heater
I have a 1993 E36 with what appears to be a heater control problem. Temp comes up to center in reasonable amount of time. Radiator has been bled, no bubbles.
If you have the climate control on max heat and the knob in the full defrost position, you get plenty of heat through the defrosters. If you then turn the control to the dash outlets, you'll get a brief amount of heat but it quickly turns cold! Any thoughts on how to get the heater turned on?
Old 11-19-2010, 01:06 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Sounds like a stuck duct flap.
1998 BMW 328is
1966 Pontiac GTO
Old 11-19-2010, 01:11 PM
How do you get to and unstick the duck flap?
Old 11-22-2010, 04:33 PM
Fixed, I tried cycling the heat from defrost about 3 dozen times and it finally freed up the flap. Heat is back to norma!!
Sent from my ADR6300 using BimmerApp
climate control, heater
