Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > E60 (2004 - 2010)
E60 (2004 - 2010)
BMW 5-Series (E60 chassis) was first seen in the Unites States in the fall of 2003 with a 2004 Model Year designation. The E60 is now available as a 528i, 528xi, 535i, 535xi, 550i and a 535xi sports wagon! -- View the E60 Wiki
Old 12-03-2012, 05:04 AM
BMW-530-i BMW-530-i is offline
Mein Auto: BMW 530i
Exclamation Shaking and rough driving after hard acceleration
I drive a BMW 530I (E60) model 2006. It has automatic transmission with steptronic.
The problem I have is that when I accelerate hard on automatic (gear changes happening above 4000 - 5000 RPM) I get lots of power but when I lift off, the car quickly and sequentially up shifts to the appropriate gear and then shudders a lot upon my pressing the accelerator. It feels like quite a loss of power at that time. If I do keep it floored, the shuddering in less at higher speeds. This continues for a few minutes and then goes away, or goes away if I immediately stop, switch off for a minutes and then restart the car.
If I do not accelerate hard, there is no problem under gentle acceleration (shifting automatically at about 3000 RPM).
The issue first appeared about 6 months back and the dealer told me that they would change the spark plugs and take it from there. The spark plugs were changed but the problem reappeared 2 months afterwards (very intermittently) and have not been back as I did not know how to reproduce the issue till about 2 weeks ago, i.e. now I am sure it will shudder when pushed hard.
Any advice would be welcome as to what could possibly cause something like this, as I wanted to be a bit more knowledgeable before I go back to the dealer.
Cringing at the thought of getting a large repair bill, so I really want to have enough knowledge not to be gypped.
Thanks in advance.
Old 12-03-2012, 06:47 AM
Mein Auto: BMW 530i
Update:
I tried the "25s gas pedal press trick" that I found on the forums. It was supposed to help with jerky transmission shifting, but I thought it wouldn't harm anything to see what it does. The theory was that this trick resets the transmission control and makes shifting smoother
I drove the car after that, and accelerated three or four times up to 5000 plus RPM, and wonder of wonders after I lifted off, the car up shifted as it should, and when I floored it again there was no shuddering
I do not know whether it's a permanent fix, but if the shuddering was only due to the transmission wondering which gear to upshift to upon second acceleration my problems may be over.
Fingers crossed.
acceleration, e60, shuddering
