What's the trick to get the radiator back in on the M52 engine?
What's the trick to get the radiator back into the M54 engine?
Here's my running "diary", which is showing that it's NOT easy to get the radiator in (the DiYs that say "insert radiator" seem to be missing the 'trick'). It was nearly impossible to get out for the same reason. The hoses to the steering and automatic transmission on the driver side and the air conditioning hoses on the passenger side hang it all up. Here's my ad-hoc diary: Re-install radiator: Compare the old and new radiator. The new radiator comes with attached blue drain plug The new radiator comes with detached lower fan shroud plastic clips The new radiator does not come with the lower rubber bumpers. With the old radiator lying flat with the bottom facing you, lay the new radiator on top in the same orientation. With whiteout, write the date in the place where the oem sticker was on the original radiator. Notice the old radiator has two lower plastic black clips attached. Notice they fit only one way, with a twisting action. Insert the new radiator fan shroud plastic clips in place & twist.(NO!) --> I broke the passenger side radiator clip on the AC compressor! Take a look where the lower bumpers go on the radiator and on the vehicle. Transfer rubber bumpers from the bottom third of the old radiator to the new radiator. NO! --> One of my bumpers fell off near the underside of the PSP and I had to dig for it for ten minutes to find it (black on black). Lower the new radiator into place. drat! It was too hard to drop the radiator in from the top. So I went underneath and tried to push it up. Double drat! Soon I disabused myself of that notion. Back from the top I go ... So, ummmm... what's the trick? Last edited by bluebee; 11-23-2010 at 05:09 PM. |
Try angling one side of the radiator down and past any piping or other obstacles, then swinging the other side into place (so the bumpers are aligned on the spots they slip into. It's a 3D maneuver I think, just can't recall exactly how....
You're definitely right about that!
At least, it's fresh in my memory. Here's my DIY diary ... Back from the top I go ... OK. It's in but this is gonna be hard to explain. Put the radiator in from the top, and push toward the drivers side hoses and wiggle, and push toward the passenger side hoses, and wiggle. Then, when you have about 10 inches still out, drop under the car, and, get this, PUSH UP! Then, wiggle. Finally it dropped into place. Since I broke one of the new flimsy black plastic lower radiator clips I decided to move the old seemingly sturdier clips to the new radiator. They twist off with some difficulty (I was worried that these were one-way twists, but they came off with a clockwise 90 degree twist (facing the clip) and went with a 90 degree counter clockwise twist. I had to push them and tilt them from the back to disengage from the radiator. Well, putting the passenger side rubber bumper turned out to be easy; but the drivers side was nasty. So, I take back what I said about not putting the driver's side bumper on first. That was not easy, but, I had to remove the radiator about half way, and put the drivers side bumper on. Then reposition it, and then put the passenger side bumper on. I can easily envision an indy who would just give up on those bumpers and not put them in where, over time, the additional stress that might result could break a plastic radiator component. From below, double check the bumpers are in place and that they are fully seated in their pans. At first, both bumpers were hanging over the edge, so make sure that the bottom metal of the radiator links up and overlaps the edge of the transmission cooler in front of it at the bottom (hard to explain). Install both topside radiator clips with one 8mm bolt and two rubber wells each and hand tighten. |
Ah, one thing, probably explains why the rad install didn't create as much drama for me. My car is a manual transmission, and thus unlike your automatic doesn't have the ATF cooler piping connections on the side.
It's tough! Two person job, one on top, one below lining up the damned rubber bits that hold it in the bottom is how I did it. A fair bit of force was applied to the transmission and power steering lines.
'99 528i ('98/12 build). 174,000km BY29428/Royalrot Breaking My Wallet since 2009 Mods: Stoptech SS brake hose, 280piece toolkit resting on trunk floor, Beisan VANOS seals '99 540i (grandfather's)
I was worried I'd break a hose because I had to push very hard against the almost immobile driver side set of hoses (automatic transmission? power steering?) and push hard against the more mobile (air conditioning?) hoses on the passenger side. Basically, the 'trick' is to get an inch of space by removing the bumpers, ('cuz my driver's side bumper got knocked off anyway); keep the plastic clips off ('cuz I broke one of mine on the AC compressor); and then drop it down from the top 'till about 10 inches or so is left; then scoot below and wiggle back and forth 'till it gets close. Note to self: The Nissens plastic clips at the bottom of the radiator are more flimsy than the Behr OEM plastic clips. Then, at one critical point, FORCE is applied (in each direction, successively), and the thing just plops down almost into place like Archie Bunker on his favorite chair. I had to replace the bumpers and then scoot the radiator forward by about a half inch on each side, but, after that, it settled nicely where it belongs. Moving on, on this chilly evening where I'm warming my hands on the floodlight metal housing, I dated the lower radiator hose with whiteout, I lubed the two rubber o-rings with Leslie's Pool and Spa Lube, and I squished a dribble of di-electric grease into the electrical connector for the new FAE temperature switch, and clicked the lower radiator hose into place. While most DIYs then say to re-install the upper radiator hose, I'm gonna skip that step 'till later so that I have more room. I still need to tackle removing the old OEM fan and putting it on the new fan clutch. BTW, both the new fan clutch and the new expansion tank both say both Behr and Hella. Is Behr the same as Hella? And, the old hoses are nearly identical (almost exactly) to the new ones, even down to the writing, except the new ones seem to have all the BMW symbols scratched out. What's with that? Last edited by bluebee; 11-23-2010 at 07:20 PM. |
[A quick google shows they've got a joint-venture....]I'm waiting for you to get to the shroud; probably a good idea you left the upper rad hose off for now. Last edited by pleiades; 11-23-2010 at 07:37 PM. |
Fan clutch in and out is a 10 min job. Note orientation before installing the new clutch. PB Blaster was necessary on my salt-encrusted car. Both the fan installation and the rad installation were easier with two people working top and bottom.
I suspect the BMW logo scratched out was the old mold edited to make OEM rather than OE parts.
Have engaged in this "Me against the Radiator" wrestling match three times now. First time, hands a bit bloody, thought I won the match only to find one of the rubber bumpers on floor when I backed my car out of the garage. Where the hell does this thing go? Match two, not as much blood loss, replaced the rubber bumper and learned the bumpers are not symmetrically placed on the sides of the radiator. Match three (patience is a virtue I don't normally possess), I jiggled and juggled, lifting one side of the radiator then the other up and down until it magically dropped into position. My hands, only skinned this time, were still able to open mutiple cans of beer, German and domestic.
I just spent the last hour removing the last few components because the radiator just didn't settle in right, even though it looked right before I bolted everything back up. Add to that the fact that I should have put the expansion tank hoses on BEFORE I hooked up the expansion tank; I forgot to leave an extension in my tape for the cn90 fan nut rope trick; and I crossed the two bottom hoses before I knew it, etc. The one GREAT thing about a DIY is I was muttering to myself, as I tore it apart again, that an Indy would NEVER spend this kind of time to get it right. As long as the radiator wasn't bouncing around, I'd wager the Indy would leave it at about a half inch off kilter. So, thank God for the DIY! |
This is how I remember doing it with NeverSayNever (Chris). I was underneath lining everything up and he was lowering into place. Definitely easier to have a second pair of eyes and hands assisting.
It's not a DIY. It's what happened. The way I created it was I copied the text of all the appropriate DIYs into a single (rather messy & redundant) just-for-me DIY; and then, line by line, I attempted the tasks. When I (invariably) screwed up, I didn't go back to fix it; I just mentioned it at the time of the screwup. This will help me write a DIY that is "idealized", i.e., the DIY assumes everything works perfectly because the user is warned around the mistakes. |
- E39 (1997 - 2003) > Notes from my cooling system overhaul Quote:
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! |
For the cross-linked record, here's another OP who had a difficult time getting the radiator BACK IN the car!
For the record, another person had a devil of a time getting the radiator back in on the I6 today:
-> Help..New Behr radiator from Autohausaz vs. dealer Behr from dealer
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
