Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series & 4 Series > E21 (1975 - 1983)
E21 (1975 - 1983)
Old 11-25-2010, 12:24 PM
RoycE21 RoycE21 is offline
Mein Auto: 1982 320i
320i change gear oil
Does anyone know how to change gear oil in a 1.8l 320i? Or at least an easy way to do it?
Old 11-29-2010, 11:49 AM
conv440 conv440 is offline
Mein Auto: 1983 320i
If you mean the differential fluid then it's actually pretty easy. I just did mine this weekend. I drove the rear of the car up on ramps. Crack open the filler plug on the diff cover with a hex socket, I forget what size 13MM? Get a drain pan and open the lower plug and drain the diff. Replace the lower plug and refill with gear oil. I needed about 2 quarts and used Mobil synthetic 75W90. All together took about 20 minutes including cleaning the diff housing.
Old 12-01-2010, 12:54 PM
Thanks man. I was under my car yesterday and saw it once I jacked it up. Now I need to get a big enough socket or possibly an Allen wrench
Old 12-01-2010, 07:45 PM
No problem. Here's a pix after cleaning the diff cover.
Old 12-11-2010, 12:45 AM
asanjuan asanjuan is offline
Mein Auto: 1981 320 S-Pack
Hi - Is there a gasket for the cover?
Old 12-13-2010, 10:50 AM
Yes, there is a gasket for the cover part #2 in the picture. You don't need to remove the cover to do a oil change. There are 2 aluminum washers/gaskets on the drain & fill plugs #14 that should be replaced.
