Old 11-26-2010, 10:50 PM
mikegalang mikegalang is offline
Mein Auto: 1996 523i
alarm keeps going off
hi everyone! i currently own a 5 series E39. my alarm keeps going off every 5 minutes or so. i followed my friend's advice and opened and then closed all doors including the trunk and locked the doors using the wireless remote key. it didn't seem to solve the problem. can anyone give me any ideas on how to solve it? i'm getting really frustrated already. thanks!
Old 11-26-2010, 11:09 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
Unplug the switch on the left cabin filter housing. If the alarm stops, you've found the problem. The switch may be bad, or it's not being fully stroked.
Old 11-26-2010, 11:40 PM
QSilver7's Avatar
QSilver7 QSilver7 is online now
Ditto ^^^ As restated time & time again when this question is asked...check your hood alarm sensor. It may be the culprit from going bad or not being seated properly because the piece that secures it to the filter housing is cracked...or it could be that the insulation (in the hood above the tip) has worn away.
You'd think that the tip of the sensor should be pressed down by the exposed metal on the hood....but the tip misses the metal by a few inches and is actually pressed down by the insulation in the hood.
Unplug the sensor and see if the false alarm triggers stop:
Q {BMW CCA Member #191509}
(SOLD)
Old 11-27-2010, 02:49 AM
to edjack and Qsilver7:
thanks for the tip! i appreciate it fellas.
Old 11-28-2010, 02:15 PM
HotRodRuss HotRodRuss is offline
Mein Auto: 1997 528i
Wow. Mine just started doing that, once in a while. I charged the battery the other day reading other post. But now I will check that switch. Thanx
Old 11-29-2010, 04:18 AM
geiristudio geiristudio is offline
Mein Auto: BMW 540 e39
My alarm goes off at any random time. I'm not really sure what's causing it but I've found a way to make it stop. Every time I lock my car I press the lock key again and the red LED on your mirror turns red for a couple of seconds. By doing that you disable the motion sensor in the car. Works at least for my e39 540i.
Old 11-29-2010, 08:22 AM
5150_holmes 5150_holmes is offline
Mein Auto: 528 Auto
Have you checked any of the door latches attached to the car (not the door)?? Each one has a micro switch/tab that is activated when the door is open or closed thus telling the car if a door is open and allows interior lights to come off and on AND will activate the alarm.
I had random alarm problems on my old E36 coupe along with the drivers window moving up and down as if the door was being opened.
A new latch switch solved this and the E39 uses the same type of latch
see part number 6 here...
http://www.realoem.com/bmw/showparts...26&hg=41&fg=40
Old 12-29-2010, 09:23 AM
540indiana's Avatar
540indiana 540indiana is offline
Mein Auto: 2000 540i Sport
Very helpfull thread. Thanks a million
Old 12-29-2010, 12:13 PM
golferjohnm's Avatar
golferjohnm golferjohnm is offline
Mein Auto: '01 540i 6sp '01 X5 4.4
this has been extremely helpful, for both of our BMW's...this forum ROCKS!!!
