Old 12-14-2011, 06:09 PM
dEN1 dEN1 is offline
Mein Auto: e39 530i auto
Hello Folks.
I am from England U.K. and I am amazed at the detail that has gone into this thread!!!...A big Thanks!!
I ham having the SAME PROBLEMS as you people here!
I have a 2002 e39 3.0i auto and the level indicator stick in mine has also disappeared.
I have a new expansion tank being delivered & I will probably have to get the bottom sensor as well
Could anybody please tell me WHY??? BMW didn't fit a CLEAR/OPAQUE tank??
Also...How do I detach the 2 bottom rubber tubes...will I need new circlips//
Thanks...My 1st post Dennis.!
Southampton, Hampshire, England U.K.
Old 12-14-2011, 06:26 PM
Blight67 Blight67 is offline
Mein Auto: 2002 530i Sport Pkg
Detaching the 2 bottom rubber tubes is similar to the upper / lower radiator hoses. There is a metal clip that needs to be pulled back (not removed, but it's ok if it does fall off) to unlock the hose connector. Once unlocked, it's just a matter of gently working the hose off.
Old 12-14-2011, 06:41 PM
Originally Posted by Blight67 View Post
Detaching the 2 bottom rubber tubes is similar to the upper / lower radiator hoses. There is a metal clip that needs to be pulled back (not removed, but it's OK if it does fall off) to unlock the hose connector. Once unlocked, it's just a matter of gently working the hose off.
Thanks Very much for the reply!!
I have just looked at my car (1:36am night) and the cable for the sensor is missing ??
I don't know if there is something sinister from the previous owner about this (Loss of coolant??) or just not wanting to replace the sensor/tank.
Would any body happen to know where the sensor cable/wires go to??
Thanks Dennis.!
Old 12-15-2011, 09:06 AM
Thanks Dennis.!
Update........I phoned the BMW main dealer who used to service the car & it appears the car never had a expansion tank sensor fitted in the first place!!
Apparently..not all BMW had them...they were an optional extra!!
Old 03-15-2012, 07:44 AM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
To crosslink for the convenience of others, this somewhat related pictorial failed-expansion tank thread was opened recently:
> E39 (1997 - 2003) > 97 528i Expansion Tank questions w pics
Old 08-26-2012, 04:12 AM
bluebee's Avatar
RDL posted an autopsy photo of his bleed screw, which failed up the middle!
-> E39 (1997 - 2003) > Leaking Bleed Screw
Originally Posted by rdl View Post
I've seen posts mentioning broken and leaking bleed screws, but had always assumed that the heads had broken &/or leaked around the O-ring under the screw's head. I'm posting my experience so that others may check before replacing an expansion tank.
I popped the hood this morning to check oil level and found the dreaded white anti-freeze spatter around the expansion tank. There was also liquid coolant on the top ledge/seam of the tank. The bleed screw was dry with no visible defect. I was sure I had a cracked tank.
To make a long story short, I found the fault was the bleed screw leaking through the centre; not past the O-ring seal and not the tank. But, liquid would bubble up from the bottom of the large X in the screw head when the engine was running and up to normal temp, i.e. pressure. The screw has a crack through the centre although for the life of me I can't find it, even with a jeweler's loupe and a dental pick under a bright light.
Anyway, I replaced the screw for a few dollars & no more leak after a 30 minute drive.
The red arrow indicates the leak. The blue arrow points to the seam with standing liquid. There was liquid around the entire perimeter of the tank. You can also see some of the white spatter deposits on the engine and tank.
Old 09-25-2012, 06:02 PM
bluebee's Avatar
I'm beginning to wonder about Behr ... considering this recent Fudman quote:
Originally Posted by Fudman
"Don't buy an expansion tank other than the dealer-supplied Behr!". Not a supplier Behr. A dealer Behr."
Originally Posted by bluebee View Post
Well, it's 'my' turn again!
I noticed a puddle on my driveway today ...
So I started looking for the telltale white spots:
And, watching for a while, I found the culprit!
Note: I last replaced my Behr expansion tank in 2010 as noted by the markings on the side.
Old 03-12-2013, 11:49 PM
bluebee's Avatar
This was posted today which might help others:
Originally Posted by Runner303 View Post
Hello everyone,
In light of the recent discussions on cooling system leaks, pressure, 1.2 bar caps etc. I'm digging up an old thread again to share some findings with my replacement Behr rad and how I fixed my rad based on something I'd read on here.
Was working out some coolant leak issues last June. Replaced water pump and rad hoses up front. Found another leak at the driver's side end tank on the rad, at the bottom. A forum search quickly revealed this to be an issue with replacement Behr rads made in South Africa, as mine indeed was back in 2008.
Here is the leak:
I'd read on here someone's theory that these rads were fine but not crimped quite tight enough, like a process flaw where they needed to turn up the machine a little. So I grabbed my trusty Channel Locks...
... and gave the end tank a little extra squeeze, crimp by crimp around its perimeter - ever so gently now! I don't think the aluminum will take much 'working' before it fatigues and weakens.
Grabbed my camera part way through the job and snapped this pic showing "before" and "after". You see how the gap between the aluminum "tab" and the plastic tank is reduced.
In full disclosure, be advised that I switched to Evans NPG+ at the same time as doing this repair. Regardless, it's been 9 months & ~3,000 miles and a once-leaky rad is now clean and dry. I bet this would benefit an aqueous solutioned car as well.
JP
ID:	366141   Click image for larger version
ID:	366142   Click image for larger version
ID:	366143   Click image for larger version
Old 03-27-2013, 01:19 PM
Jason5driver's Avatar
Jason5driver Jason5driver is offline
Mein Auto: E39 hamster w/ pin-wheel
Here I've placed the float in the "too full" position.
Notice also that there is an incomplete bulkhead on the other half of the expansion tank (much as was seen in the Titanic's six front watertight bulkheads which were only watertight horizontally, not vertically).
At the moment, I surmise this thin plastic bulkhead (incomplete at the top) apparently separates the overflow operation of the expansion tank with the level-sensing operation.
In my tentative summary, I assume the following operational explanation (which I invite others to help flesh out in detail).
Surmised operation:
- The expansion tank has at least three different operations, namely visual level sensing, electrical level sensing, and overflow operation (if there are more, let me know).
- The electrical level sensing is apparently triggered when a float containing a slightly magnetic disc with a hole in the center, envelopes the tip of the electrical sensor.
This apparently triggers the "low coolant" warning.
- That same float also contains a loosely glued on bobber stick, which indicates visually the coolant level. A typical failure is for that stick to disengage from its float. This disables visual level sensing; but it does not seem to have any effect on electrical sensing unless the stick itself causes the float to hang up in operation.
- In practice, it is very difficult to remove an old expansion tank overflow hose clamp without breaking the nipple, even though that expansion tank nipple is metal reinforced against that happenstance.
If you're going to remove the expansion tank hose, you may as well assume you're going to replace the expansion tank.
I recently have checked my Reservoir, and while looking inside, I noticed that the plastic wall for the overflow section within the reservoir was cracked vertically.
I wonder if the crack prevents the Reservoir to function correctly...?
Old 03-27-2013, 01:47 PM
bluebee's Avatar
To date, NOBODY has been able (to my knowledge) to explain HOW that second black section works, in the expansion tank (mine is a 2002 M54).
However, it does have a bunch of holes in it, so, I would think (guessing here) that a crack would not be meaningful from the standpoint of leaking fluid from one chamber to another.
However, just the fact that a crack exists in the bulkhead would be cause for concern, in that I would wonder HOW it got there.
Interestingly, you'll notice MINE (below) has a crack in the black bulkhead; but I have no idea if I caused that crack when I cut it open.
Old 03-27-2013, 02:13 PM
bluebee's Avatar
For the crosslinked record, JimLev kindly posted an expansion tank autopsy here:
> E39 (1997 - 2003) > 540 Expansion Tank issue. Bluebee U were looking for this info
Originally Posted by JimLev View Post
I posted this same info over on Roadfly, unless you have an account there you can't view the pics.
540 Expansion tank problem and dissection
A few weeks ago I helped a friend change his lower oil pan gasket on his 2000 540ia.
He mentioned that when driving on the highway and then needing to slow down because of traffic the heat would sometimes go cold and the temp gauge would start to rise. Throwing the car into neutral and giving it gas would bring the temp gauge back down and the heat would return.
After the oil pan gasket job was done I took the cap off the expansion tank. Looking inside the level didn't look right.
The left side of the tank was almost empty, it should be 1/2 full. This is the section that fills the waterpump/engine.
The section of the tank that the stick is in was full to the top part that the stick traverses thru. Didn't look right to me.
We dumped more coolant in even though the stick showed it was overfilled.
He ordered a new expansion tank. The previous tank was installed in '08 and was not an OEM BMW tank.
Last Sat. we installed the new tank and all is well.
We then cut the tank open to find out what the problem was. This tank seems way more complicated than it needs to be...must be the German way of doing things?
There are 4 sections inside the tank which should all be connected to each other thru openings in the lower wall partitions.
3 of them were connected, but the important section wasn't.
If you purchase a non-BMW tank pour a little water into the tank before you install it. It should run out the bottom hose connection that goes to the waterpump.
Anyone ever run into this problem before?
Thanks JimLev, for the expansion tank autopsy, and, for the picture of the passageway that was never cut out at the factory.
This information can be helpful for this thread:
- Does anyone have a BMW description of HOW the E39 M54 expansion tank actually works?
So that this information is found easily in the future, I will cross reference this thread to the existing expansion tank autopsy threads - so that we can get a better handle on how the thing works.
- Behr radiator and Behr expansion (aka surge) tank autopsy (1) (2) & request for another autopsy to understand the function of that second (black) chamber & pinned float (1)
It would be nice if someone can explain with an exploded picture HOW the expansion tanks works (at least the flow of fluid, with arrows going in and out).
I, for one, still don't understand at all how the "black" section works!
ID:	368567   Click image for larger version
ID:	368568   Click image for larger version
ID:	368569   Click image for larger version
ID:	368570   Click image for larger version
ID:	368572   Click image for larger version
Old 03-27-2013, 02:20 PM
bluebee's Avatar
Old 03-27-2013, 02:27 PM
Right.
Regardless, I still plan on replacing the Reservoir.
I think the vertical crack was caused when I accidentally dropped the reservoir when working/ replacing my power steering system...
See your modified picture, showing where the crack is on my Reservoir (running vertically, almost identical to the line shown on your reservoir):
Name:	surgetank_autopsy_07 Sketch.jpg
Old 03-27-2013, 04:47 PM
dms540i's Avatar
dms540i dms540i is offline
Mein Auto: 1999 BMW 540iA
I sure hope a BMW engineer reads these posts!
BMWCCA#401441
Old 12-19-2013, 05:01 PM
bluebee's Avatar
For the record, folks in this thread are trying to ascertain, it seems, what was already figured out here on the tank markings ...
> E39 (1997 - 2003) > Genuine BMW Behr radiator
Old 01-13-2014, 07:11 AM
97e39blue528i 97e39blue528i is offline
Mein Auto: 1997 528i
Bluebee, Incredible quality of work in this thread -several factors better than the e39 shop manual! thank you!
Old 11-01-2014, 09:32 PM
Allen Nugent Allen Nugent is offline
Mein Auto: E39 540i
Smile
I agree. My plastic nipple was so brittle that almost anything would have broken it off.
... So, if anyone has a less damaging way to remove the hose clamp, let us know!
BB
Here's an idea: Don't remove the hose at all -- cut it.
Make the cut about two inches from the end of the nipple. When refitting the expansion tank, slip a generic hose clamp over each of the cut ends and join the ends over a tight-fitting piece of aluminum or stainless tube (ideally with the same inner diameter as the hose). Tighten the clamps and Bob's your uncle.
I haven't actually tried this myself (on a car), but I can't see why it wouldn't work. It may sound backyard, but it's really just installing an auxiliary pipe fitting that is much more robust than the original.
Old 11-01-2014, 10:26 PM
bobdmac bobdmac is offline
Older than old school
Mein Auto: 2001 540i/6, '90 k75s
The trouble with this is that the hose itself oxidizes and deteriorates, and you don't want to leave that brittle hose end in the system. It has to come out.
BMW--giving new meaning to the phrase "disposable income."
Old 01-07-2015, 12:17 PM
valtersboze valtersboze is offline
Mein Auto: e39 540its
has anyone really figured out e39 540 expansion tanks for m62tu?
do they break internally? what happens with mine is the upper rad hose is always full with air. if I turn on heater, take cap off, and squash the upper rad hose a few times, it gets filled with coolant. but 5 minutes later its full with air again, if I leave the cap off, I even see how the level stick slowly goes up.
what I think is happening -
a) radiator is sucking air from the small hole in the ET neck, eventually levels out with expansion tank coolant level
b) expansion tank inner tube or walls have come apart, thus sucking air through overflow hose
p.s. whenever I start the car, the level stick disappears far down in expansion tank. I guess its supposed to do that since waterpump sucks coolant in?
Old 01-07-2015, 02:30 PM
HTK12 HTK12 is offline
Mein Auto: E39 540i
Either you got a leak or you haven't bleeded the system properly. Upper hose should be full of coolant when the system is working as intended.
Old 01-07-2015, 07:17 PM
i post in this topic because my guess of internally failed ET could be just another type of m62 cooling systems failures, either it be expansion tank or the cap. i will try to get a transparent tube tomorrow and see how the air travels back to radiator.
i dont see how a small leak ( i dont see any puddles under car) or unbled system would cause this scenario. it doesnt make sense to me at all. i am talking about dead cold engine, without even starting it. if i turn on the heater pump, which gives some pulling from ET i guess, and squeeze the hoses a few times, i can "pump" the system (hose and radiator) full with coolant. as soon as i stop this pumping, it slowly (fully in some 2 minutes) gets air back in radiator and upper hose (levels out with ET lower coolant level), and i think system is sucking air through the "overflow" hose. if it happens, my guess is that there is some internal problem with the expansion tank, e.g. the yellow tube should connect the overflow nipple to bottom of ET tank, maybe this tube has an air leak on top of it? and then there is the small hole in ET neck - cant really tell from the other user pictures - is this really connected to overflow nipple? if so, then why? if anyone knows the answer, chime in, dont just guess, cause nobody really knows the answer -> http://www.bimmerfest.com/forums/sho...4&postcount=89
this system is just nuts. in a few months i plan to go with modded 840ci thermostat and NPG coolant and simply overfill a gallon and forget it, but for now i just want to fix the system.
attached is a GUESS of m62/540i flow.
if it is proper guess, it doesnt make sense to me why the overflow/blood would be connected to the ET neck hole.
Old 05-02-2015, 11:33 AM
bluebee's Avatar
Here is a related question...
> E39 (1997 - 2003) > Question about "no O-ring" for coolant level sensor.
Originally Posted by 540iman View Post
When I went to finish my water pump DIY on my 2002 540, I was surprised again (done this job on other 540s) that there was no O-ring for the level sensor at the very bottom of the expansion tank. I looked for quite a while for a left-over O-ring amongst my left over parts to go back on the car and I found there was none left behind on the expansion tank or the sensor. The sensor just seems to twist onto the bottom with a snug fit, but no seal which I expected to find. Real oem does not show an O-ring for this connection either. Appears just plastic against plastic. I just can't wrap my head around this. Is there supposed to be an O-ring here?
Old 04-13-2016, 05:54 PM
blakpantha007 blakpantha007 is offline
Mein Auto: 2002 BMW 525i
Bluebee, you are the best and I admire your art of deduction. You really have examined this from all the relevant angles. Thank you! My 525i is down as a result of a radiator failure. I have ordered a Nissens but that will not arrive until the next two weeks or so. But as usual, my 1997 Suzuki Baleno GLX is up to the task, and by the way, she has a copper radiator for the past 15 years and has never skipped a beat!
