Old 11-30-2010, 12:08 PM
bheppy67 bheppy67 is offline
Mein Auto: 1999 528i
temp sensor 1998 528i
I trying to find where the outside temp sensor is located.. I have a 1998 528i
Old 11-30-2010, 12:47 PM
cn90 cn90 is offline
Search forum using keyword "ambient temp sensor relocated".
I relocated mine to a higher position to avoid repeat damage from curb side.
Old 11-30-2010, 01:42 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
To the OP,
Here's cn90's pic of his relocated ambient temperature sensor.
Old 11-30-2010, 01:50 PM
Temp sensor
So, the temp sensor is located inside the right side wheel well?.
Old 11-30-2010, 01:52 PM
bluebee's Avatar
Not inside. But near.
Did you read any of the zillions of threads (many with pictures) on "ambient temperature sensor"?
Old 11-30-2010, 01:56 PM
bluebee's Avatar
Sorry to be short with you ... but this question is really really really common. So, to answer it again (and again and again) wouldn't be useful.
BTW, a hint (that has often been proposed) for those who can't find their own ambient temperature sensor (because it's not there), is simply to go to a parking lot at the mall.
Then, just duck under the nearest similar model BMW's right front and you'll SEE their ambient temperature sensor.
Probably you can't find it because (as is said in all the threads), either your plastic underhousing (I forget what it's called) is missing entirely or because the sensor was ripped off on a curb.
Do the search. In less time than it takes me to write this, you'll have two dozen pictures of the thing in place. And you don't even have to go farther than the first thread in this forum (the bestlinks thread).
Good luck.
Old 11-30-2010, 02:05 PM
The Factory location is as below. It is Murphy's law, if it happened to you, it WILL happen again if you simply replace the sensor to the Factory location.
I move it up a few inches inside the same compartment as the Air Pump (see Bluebee's pic above).
Anyway, this is factory location, which I don't advise you to use:
Old 03-25-2013, 06:40 PM
bluebee's Avatar
For the record, this related question was asked today:
Originally Posted by MichaelNash View Post
Anyone know where the thermostat fuse is in the glovebox or trunk? Mine is currently reading -40 degrees on the dash. If my fuse turns out to be good anyone know where that thermostat is located in the car so I can check if it is disconnected.
See also:
DIY: 1998 528i AMBIENT Temp Sensor Hiding Place:
I wrote this DIY in 2006 including my trick to relocate the AMBIENT Temp sensor to a safer place. It is in the place just in front of the passenger's side wheel well plastic cover (remove the passenger's side wheel well plastic cover and you will see the Secondary Air Pump in there).
AMBIENT TEMP SENSOR HIDING PLACE:
http://forums.bimmerforums.com/forum....php?t=1418124
